    Homing Y moves the Z motors + 1LC are not connected not detected
    Firmware installation
    347
    • VoodooBaneundefined
      VoodooBane
      I am having some problems with my setup of a Duet 3 Mini 5+ with the added Expansion mini 2+. But I also have the tools distro board with two 1LC v1.2. The printer I am building is a V-cast v1.5 so it has two Y-Axis driven with belts.
      So here are my problems;
      My firmware is 3.41
      Problem 1= when I press home Y the two z motors spin. I have edited and tried different drivers sockets and etc.. I am pretty frustrated at this point. I will have my config file posted below:
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Tue Jul 19 2022 13:41:07 GMT-0400 (Eastern Daylight Time)
      G4 S1   ;wait 1 second for expansion boards to start
      ;M575 P1 S1 B57600                                 ; enable support for PanelDue
      M111 S0                    						   ; Debugging off
      G21                       						   ; Work in millimetres
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M550 P"Matt's IDEX"                                ; set printer name
      M552 S1                                            ; enable network
      M586 P0 S1                                         ; enable HTTP
      M586 P1 S0                                         ; disable FTP
      M586 P2 S0                                         ; disable Telnet
      M569 P0.0 S1                                       ; physical drive 0.0 goes forwards X1 motor
      M569 P0.1 S1                                       ; physical drive 0.1 goes forwards X2 motor (U)
      M569 P0.2 S1                                       ; physical drive 0.2 goes forwards Y1 Motor
      M569 P0.3 S1                                       ; physical drive 0.3 goes forwards Y2 Motor
      ;M569 P0.4 S0                                      ; physical drive 0.4 goes forwards
      M569 P0.5 S1                                       ; physical drive 0.5 goes forwards Z1 Motor
      M569 P0.6 S0                                       ; physical drive 0.6 goes backwards Z2 Motor
      M569 P121.0 S1                                     ; physical drive 121.0 goes forwards E0 motor
      M569 P122.0 S1                                     ; physical drive 122.0 goes forwards E1 motor
      M584 X0.0 Y0.5:0.6  Z0.2:0.3 U0.1 E121.0:122.0      								; set drive mapping
      M350 X16 Y16:Y16 Z16:Z16 U16 E16:16 I1             									; configure microstepping with interpolation
      M92  X80.00 Y80.00:80.00 Z400.00:Z400.00 U80.00 E562.00:562.00          			; set steps per mm
      M566 X900.00 Y900.00:900.00 Z180.00:Z180.00 U900.00 E120.00:120.00        			; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00:6000.00 Z180.00:Z180.00 U6000.00 E1200.00:1200.00    		; set maximum speeds (mm/min)
      M201 X500.00 Y500.00:500.00 Z20.00:Z20.00 U500.00 E250.00:250.00       				; set accelerations (mm/s^2)
      M906 X1200 Y1200:Y1200: Z1200:Z1200 U1200 E450:450 I30               				; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            									; Set idle timeout
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X300 Y300 Z300 S0                             ; set axis maxima
      M208 X0 Y300 S0                            		   ; set axis maxima Extruder 1 (X0.1)
      M208 X300 Y0 S0                           	 	   ; set axis maxima minima 2 (U0.2)
      M574 X1 S1 P"!io0.in"                             ; configure switch-type (e.g. microswitch) endstop for low end on X1 via pin !io0.in (X1)
      M574 U2 S1 P"!io1.in"              			      ; configure switch-type (e.g. microswitch) endstop for low end on U2 via pin !io1.in (U2)
      M574 Y0.5:0.6 S1 P"!io2.in"						  ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin !io3.in (Dual Y)
      M574 Z1 S2                                        ; configure Z-probe endstop for low end on Z
      M558 P8 C"121.io2.in"  H0.7 F1000 T6000 A20 S0.005  ; SuperPinda probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5									; Correct me for 8mm inductive prob - set Z probe trigger value, offset and trigger height (Super Pinda)
      M557 X25:300 Y25:300 S25                            ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
      ;M307 H0 A286.0 C164.4 D2.9 S1.00 V24.0 B0		   ; AC Heater 0 PID adjustment (Heatbed)
      M308 S1 P"121.temp0" Y"pt1000"                     ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1                             ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S300                                       ; set temperature limit for heater 1 to 300C
      ;M307 H1 A286.0 C164.4 D2.9 S1.00 V24.0 B0	       ; Extruder X1 Heater PID adjustment
      M308 S2 P"122.temp0" Y"pt1000"                     ; configure sensor 2 as PT1000 on pin 122.temp0
      M950 H2 C"122.out0" T2                             ; create nozzle heater output on 122.out0 and map it to sensor 2
      M307 H2 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H2 S300                                       ; set temperature limit for heater 2 to 300C
      ;M307 H2 A286.0 C164.4 D2.9 S1.00 V24.0 B0	       ; Extruder X2 Heater PID adjustment
      M950 F0 C"121.out1" Q500                           ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 C"Heatsink fan 1" S1 H1 T45                ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"121.out2" Q500                           ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 C"Part cooling 1" S1 H-1                   ; set fan 1 name and value. Thermostatic control is turned off
      M950 F2 C"122.out1" Q500                           ; create fan 2 on pin 122.out1 and set its frequency
      M106 P2 C"Heatsink fan 2" S1 H2 T45                ; set fan 2 name and value. Thermostatic control is turned on
      M950 F3 C"122.out2" Q500                           ; create fan 3 on pin 122.out2 and set its frequency
      M106 P3 C"Part cooling 2" S1 H-1                   ; set fan 3 name and value. Thermostatic control is turned off
      M563 P0 S"Extruder 1" D0 H1 F0:1                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"Extruder 2" D1 H2 F0:3                   ; define tool 1
      G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      ;NeoPixel LED Stip
      M150 X3 Q3000000     								 ; set LED type to NeoPixel and set SPI frequency to 3MHz
      M150 B255 P255 S30 f0    							 ; set first ALL (30) LEDs to Blue, half brightness
      ; Panic power loss and Resume
      M911 S20 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"   ; set voltage thresholds and actions to run on power loss
      Problem 2= 121 and 122 are not being detecting. they keep timing out.
      If I click "run config file" after saying the errors are below:
      9/5/2022, 7:53:04 PM 	Error: Response timeout: CAN addr 122, req type 6027, RID=50
      Error: Fan number 2 not found
      Error: Response timeout: CAN addr 122, req type 6027, RID=52
      Error: Fan number 3 not found
      9/5/2022, 7:52:58 PM 	Error: Response timeout: CAN addr 122, req type 6026, RID=44
      Error: Heater 2 not found
      Error: Heater 2 does not exist
      Error: Response timeout: CAN addr 121, req type 6027, RID=46
      Error: Fan number 0 not found
      9/5/2022, 7:52:50 PM 	Error: Response timeout: CAN addr 121, req type 6031, RID=38
      9/5/2022, 7:52:43 PM 	Error: Response timeout: CAN addr 121, req type 6042, RID=31
      Response timeout: CAN addr 122, req type 6042, RID=32
      9/5/2022, 7:52:41 PM 	Error: Response timeout: CAN addr 121, req type 6042, RID=29
      Response timeout: CAN addr 122, req type 6042, RID=30
      9/5/2022, 7:52:39 PM 	Error: Response timeout: CAN addr 122, req type 6018, RID=28
      9/5/2022, 7:52:38 PM 	Error: Response timeout: CAN addr 121, req type 6018, RID=27
      Important note via diag LEDS: The 122 toolboard is flashing fast red with solid blue light. But the 121 toolboard is just solid blue light. Doing a m115 command shows them not connected.
      Please note:
      -I have used a multimeter to check the connection on the Bus cable which is a twisted ribbon cable (2 wires) + "RJ-12" , connectors I crimped it myself. This checked it via continuity test and it is good
      -I have checked the connections with the 4 x small connector from the tool boards to the distro board(the jumpers ARE removed for the ones in use) This checked it via continuity test and it is good
      I guess the thing to start with Problem 1. Then go from there.
      Thank you so much for your help!
        jay_s_uk @VoodooBane
        @voodoobane post your homing files so we can see what's going on.
        And it sounds like you may not have a straight through RJ11 cable and that the middle 2 pins are swapped. I suggest changing that cable. You need to make sure it's one designed for ADSL
        VoodooBaneundefined 1 Reply Last reply Reply Quote 0
          VoodooBane @jay_s_uk
          @jay_s_uk
          Please see the below:
          ; homex.g
          ; called to home the X axis
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jul 09 2022 21:54:56 GMT-0400 (Eastern Daylight Time)
          G91               ; relative positioning
          G1 H2 Z10 F6000   ; lift Z relative to current position
          G1 H1 X-305 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F6000    ; go back a few mm
          G1 H1 X-305 F360  ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-10 F6000  ; lower Z again
          G90               ; absolute positioning
          ; homey.g
          ; called to home the Y axis
          G1 H1 Y-305 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y5 F6000    ; go back a few mm
          G1 H1 Y-305 F360  ; move slowly to Y axis endstop once more (second pass)
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.3.10 on Sat Jul 09 2022 21:54:57 GMT-0400 (Eastern Daylight Time)
          G1 H1 Z-305 F1800 ; move Z down until the endstop is triggered
          G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
          ;G91              ; relative positioning
          ;G1 Z10 F100      ; lift Z relative to current position
          ;G90              ; absolute positioning
            @voodoobane said in Homing Y moves the Z motors + 1LC are not connected not detected:
            so in homey, your Z motors are expected to move 10mm. Is this what you're seeing?
              @jay_s_uk
              That would make a lot of sense...kind feel dumb dumb at the moment... I ha build other printers before and I did seem to have this confusion...lol
              I'll will get back to you ASAP.
              Thank you
                VoodooBane @VoodooBane
                @jay_s_uk
                I have one more problem... So I can get 1 tool board to detect and register to 121 and I updated the firmware to tool board 3.41 from 3.30. but when I plug the 2nd tool board both do not connect... any ideas? Please and thank you.
                  Nevermind... I wired the 4x conductor connection wrong for the other tool board.
                  VoodooBaneundefined 1 Reply Last reply Reply Quote 2
                    This Topic has been solved.
                    • Phaedruxundefined Phaedrux has marked this topic as solved
                      VoodooBane
                      Update:
                      Turns out my Distro board was bad. I just replaced it. Everything is working as it should be now!
