    DWC not starting after update try
    Firmware installation
    899
    • Tinchusundefined
      Tinchus @chrishamm
      @chrishamm It didnt worked. I renamed the config.g as you instrected me. DWC still doent worked, I rebooted also with no sucess either.
      I checked config.g, no change to the fie was done, I even manually inserted a G21 command to be sure it is in mms, and it didnt helped.
      How can I downgrade from the ssh console to the previous version of the softwares that created this mess?
      Right now there is nothing to upgrade, I tried the sudo upgrade method but it says everything is up to date.
      Logs:
      Sep 06 15:06:21 PU-LT-4590 DuetControlServer[1778]: [info] Application has shut down
      Sep 06 15:06:21 PU-LT-4590 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
      Sep 06 15:06:21 PU-LT-4590 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
      Sep 06 15:06:22 PU-LT-4590 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
      Sep 06 15:06:22 PU-LT-4590 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 11.
      Sep 06 15:06:22 PU-LT-4590 systemd[1]: Stopped Duet Control Server.
      Sep 06 15:06:22 PU-LT-4590 systemd[1]: Starting Duet Control Server...
      Sep 06 15:06:23 PU-LT-4590 DuetControlServer[1846]: Duet Control Server v3.4.1
      Sep 06 15:06:23 PU-LT-4590 DuetControlServer[1846]: Written by Christian Hammacher for Duet3D
      Sep 06 15:06:23 PU-LT-4590 DuetControlServer[1846]: Licensed under the terms of the GNU Public License Version 3
      Sep 06 15:06:25 PU-LT-4590 DuetControlServer[1846]: [info] Settings loaded
      Sep 06 15:06:26 PU-LT-4590 DuetControlServer[1846]: [info] Environment initialized
      Sep 06 15:06:26 PU-LT-4590 DuetControlServer[1846]: [info] Connection to Duet established
      Sep 06 15:06:26 PU-LT-4590 DuetControlServer[1846]: [info] IPC socket created at /run/dsf/dcs.sock
      Sep 06 15:06:27 PU-LT-4590 systemd[1]: Started Duet Control Server.
      Sep 06 15:06:29 PU-LT-4590 DuetControlServer[1846]: [fatal] Abnormal program termination
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: [fatal] Update task faulted
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: System.ArgumentException: Requested value 'in' was not found.
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boole
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.TryParse(Type enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result) Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase) Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, T
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.Serialization.JsonConverter1.TryRead(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOption Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.Serialization.JsonConverter1.ReadCore(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStac
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.Serialization.JsonConverter1.ReadCoreAsObject(Utf8JsonReader& reader, JsonSerializerOptions options, Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan1 utf8Json, JsonTypeInfo jsonTypeInfo, Nullable1 act Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan1 json, JsonTypeInfo jsonTypeInfo)
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.ObjectModel.ModelCollection1.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties, Int32 offset Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.ObjectModel.ObjectModel.InternalUpdateFromJson(String key, JsonElement jsonElement, Boolean ignoreSbcProperties Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.ObjectModel.ObjectModel.UpdateFromFirmwareJson(String key, JsonElement jsonElement, Int32 offset, Boolean last) Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updat Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: [fatal] Update task faulted Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: System.ArgumentException: Requested value 'in' was not found. Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boole Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Enum.TryParse(Type enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, T Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.Serialization.JsonConverter1.TryRead(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOption
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.Serialization.JsonConverter1.ReadCore(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStac Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.Serialization.JsonConverter1.ReadCoreAsObject(Utf8JsonReader& reader, JsonSerializerOptions options,
      Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan1 json, JsonTypeInfo jsonTypeInfo) Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options) Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian Sep 06 15:06:30 PU-LT-4590 DuetControlServer[1846]: at DuetAPI.ObjectModel.ModelCollection1.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties, Int32 offset
      Sep 06 15:06:34 PU-LT-4590 DuetControlServer[1846]: [info] Application has shut down
      Sep 06 15:06:34 PU-LT-4590 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
      Sep 06 15:06:34 PU-LT-4590 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
      Sep 06 15:06:34 PU-LT-4590 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
      Sep 06 15:06:34 PU-LT-4590 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 12.
      Sep 06 15:06:34 PU-LT-4590 systemd[1]: Stopped Duet Control Server.
      Sep 06 15:06:34 PU-LT-4590 systemd[1]: Starting Duet Control Server...
      Sep 06 15:06:35 PU-LT-4590 DuetControlServer[1920]: Duet Control Server v3.4.1
      Sep 06 15:06:35 PU-LT-4590 DuetControlServer[1920]: Written by Christian Hammacher for Duet3D
      Sep 06 15:06:35 PU-LT-4590 DuetControlServer[1920]: Licensed under the terms of the GNU Public License Version 3
      Sep 06 15:06:37 PU-LT-4590 DuetControlServer[1920]: [info] Settings loaded
      Sep 06 15:06:38 PU-LT-4590 DuetControlServer[1920]: [info] Environment initialized
      Sep 06 15:06:38 PU-LT-4590 DuetControlServer[1920]: [info] Connection to Duet established
      Sep 06 15:06:39 PU-LT-4590 DuetControlServer[1920]: [info] IPC socket created at /run/dsf/dcs.sock
      Sep 06 15:06:39 PU-LT-4590 systemd[1]: Started Duet Control Server.
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: [fatal] Abnormal program termination
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: [fatal] Update task faulted
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: System.ArgumentException: Requested value 'in' was not found.
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boole
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.TryParse(Type enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result) Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase) Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, T
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.Serialization.JsonConverter1.TryRead(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOption Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.Serialization.JsonConverter1.ReadCore(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStac
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.Serialization.JsonConverter1.ReadCoreAsObject(Utf8JsonReader& reader, JsonSerializerOptions options, Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan1 utf8Json, JsonTypeInfo jsonTypeInfo, Nullable1 act Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan1 json, JsonTypeInfo jsonTypeInfo)
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options)
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ModelCollection1.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties, Int32 offset Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ObjectModel.InternalUpdateFromJson(String key, JsonElement jsonElement, Boolean ignoreSbcProperties Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ObjectModel.UpdateFromFirmwareJson(String key, JsonElement jsonElement, Int32 offset, Boolean last) Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updat Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: [fatal] Update task faulted Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: System.ArgumentException: Requested value 'in' was not found. Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.TryParseByName(RuntimeType enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, UInt
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.TryParseInt32Enum(RuntimeType enumType, ReadOnlySpan1 value, Int32 minInclusive, Int32 maxInclusive, Boole Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Enum.TryParse(Type enumType, ReadOnlySpan1 value, Boolean ignoreCase, Boolean throwOnFailure, Object& result)
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.Utility.JsonLowerCaseStringEnumConverter.JsonLowerCaseStringEnumConverterInner1.Read(Utf8JsonReader& reader, T Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.Serialization.JsonConverter1.TryRead(Utf8JsonReader& reader, Type typeToConvert, JsonSerializerOption
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.Serialization.JsonConverter1.ReadCore(Utf8JsonReader& reader, JsonSerializerOptions options, ReadStac Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.Serialization.JsonConverter1.ReadCoreAsObject(Utf8JsonReader& reader, JsonSerializerOptions options,
      Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.JsonSerializer.ReadFromSpan[TValue](ReadOnlySpan1 json, JsonTypeInfo jsonTypeInfo) Sep 06 15:06:43 PU-LT-4590 DuetControlServer[1920]: at System.Text.Json.JsonSerializer.Deserialize(String json, Type returnType, JsonSerializerOptions options) Sep 06 15:06:44 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ModelObject.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties) in /home/christian Sep 06 15:06:44 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ModelCollection1.UpdateFromJson(JsonElement jsonElement, Boolean ignoreSbcProperties, Int32 offset
      Sep 06 15:06:44 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ObjectModel.InternalUpdateFromJson(String key, JsonElement jsonElement, Boolean ignoreSbcProperties
      Sep 06 15:06:44 PU-LT-4590 DuetControlServer[1920]: at DuetAPI.ObjectModel.ObjectModel.UpdateFromFirmwareJson(String key, JsonElement jsonElement, Int32 offset, Boolean last)
      Sep 06 15:06:44 PU-LT-4590 DuetControlServer[1920]: at DuetControlServer.Model.Updater.Run() in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetControlServer/Model/Updat
      Sep 06 15:06:46 PU-LT-4590 DuetControlServer[1920]: [info] Application has shut down
      Sep 06 15:06:46 PU-LT-4590 systemd[1]: duetcontrolserver.service: Main process exited, code=exited, status=70/SOFTWARE
      Sep 06 15:06:46 PU-LT-4590 systemd[1]: duetcontrolserver.service: Failed with result 'exit-code'.
      Sep 06 15:06:46 PU-LT-4590 systemd[1]: duetcontrolserver.service: Service RestartSec=100ms expired, scheduling restart.
      Sep 06 15:06:46 PU-LT-4590 systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 13.
      Sep 06 15:06:46 PU-LT-4590 systemd[1]: Stopped Duet Control Server.
      Sep 06 15:06:46 PU-LT-4590 systemd[1]: Starting Duet Control Server...
      • chrishammundefined
        chrishamm administrators @Tinchus
        @Tinchus Then please try to restart your board and make sure config.g is not executed on start-up. From your log I can clearly see DSF tries to deserialize in [which DSF thinks should be inch] and there is no other reference to "in" in RRF so I strongly suspect there is G20 somewhere in your files (maybe by accident, I don't know):
        If it still fails to start after power-cycling/resetting the Duet, try to erase the firmware and flash RRF 3.4.1 manually as per these instructions and a USB cable: https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
        The bug that makes DCS crash in this particular case will be fixed in the next version.
        Duet software engineer
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @chrishamm
          @chrishamm Hello. Just in case: my setup is a SBC duet 3 with a raspi connected. So the software problem is on the raspberry. Can I just put a sd card with a backup I had. Version on that sdcard is 3.4.1, and firmware on the duet is already 3.4.1
          Would that fix it?
          Or: is there a y way I can reload everything through the ssh connection?
            @tinchus Can you connect a USB cable to the Duet and collect the output of M409 K"inputs" F"d99vn" from a serial console?
            • Tinchusundefined
              Tinchus @chrishamm
              @chrishamm Im not that skilled jajajajjaa. This duet3 is conected on SBC mode to a raspberry. If I connect directly to the USB port on the duet board, how do I access the interface? Everything on my setup is done for SBC mode. Do I need to disconnect all cables from the duet?
              Right now I dont have personall access, but can find a way (is a printer I assembled at the school, that is why if I can do things remotly would help me a lot)
                @tinchus I understand it is connected via SBC but I am still not convinced that you don't have G20 anywhere in your config/job files. Showing the output of that command should confirm the origin of this instruction. See https://docs.duet3d.com/en/User_manual/Troubleshooting/Terminal_Emulators
                Tinchusundefined 2 Replies Last reply Reply Quote 0
                • Tinchusundefined
                  Tinchus @chrishamm
                  @chrishamm I have checked config.g and I can say there is no G20 command there or any "inch" command o mention. I have not checked the jobs folder. I can just erase all gcodes on the printer from that folder and see what happens?
                  • Tinchusundefined
                    Tinchus @chrishamm
                    @chrishamm I do have ssh connection to the printer, is there any way I can aluch that command from that ssh conection console in the printer?
                      @tinchus You can now try to upgrade your system using apt update/apt dist-upgrade. The version that we released today should fix your issue, and the upgrade command does not query the affected object model key.
                      • Tinchusundefined
                        Tinchus @chrishamm
                        @chrishamm Hello. The update fixed the issue. Sadly, I had scheduled the execution of your requested command for monday, so I cant provide you with the output of that command in order for you to fully diagnose the problem.
                        But this update did the magic. THANKS!
