    Can't Connect to Duet 3 over wifi after firmware update
    Firmware installation
    1.4k
    • CorvoDewittV2undefined
      CorvoDewittV2 @T3P3Tony
      @t3p3tony I update through the Pi, got all the way to the end, the last line was "done.". I still can not connect to the duet web control. My panel due 7i will also not connect. What should I do now?
      Nevermind it just needed a few restarts. Lol Can you link a guide to update the panel due? It now will not connect, if that matters/
      Okay one more thing. How do I print a file from a sd card a usb stick? Can't figure it out. Or from a computer. Just not over wifi. I have to take the machine to work and connecting to wifi is really not a option.
        CorvoDewittV2
        @t3p3tony Like I can't figure out how to use the SD card slot on the PanelDue i7 I have so I can use the printer offline. It seems like a simple thing but it is kicking my butt.
          To use a Duet3 and PanelDue SD card slot you need to follow this wiring arrangement.
          https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue#duet-3-mb6hc-using-ribbon-cable
          Have you done that?
          To use a USB drive on the Pi and access it from the Duet you need to mount the USB key and give read write access to it.
          Take a look here: https://forum.duet3d.com/topic/29081/cant-read-usb-drive
          CorvoDewittV2undefined 2 Replies Last reply Reply Quote 0
            CorvoDewittV2 @Phaedrux
            @phaedrux I am trying to get the SD card to show up and I'm hitting a few issues. I am going to put a lot of info here so hopefully you can figure out what I am doing wrong!
            PanelDue 7i V2 Firmware 3.4.1-pre2
            Duet 3 MB6HC Firmware 3.4.2
            I want to use the ribbon cable in the temp daughterboard connector. Im not sure which way the ribbon connector should be plugged into the board. Should the red line be towards the power screw terminals or away?
            I cut conductors 1,9,10 on the ribbon cable per the picture.
            When I run M950 D1 C"spi.cs0" or M950 D1 C"spi.cs0+spi.cs2" I get the error "M950: exactly one of FHJPSR must be given" What am I doing wrong here?
            I jumped GND to NC on the 7i.
            Am I missing anything else?
            Thanks in advance!
            Phaedruxundefined 2 Replies Last reply Reply Quote 0
              Phaedrux Moderator @CorvoDewittV2
              This post is deleted!
                @phaedrux why did you delete your reply?
                  @corvodewittv2 said in Can't Connect to Duet 3 over wifi after firmware update:
                  Cause I need to think harder. 😜
                  I'll have to take a deeper look later.
                  CorvoDewittV2undefined 2 Replies Last reply Reply Quote 1
                    @phaedrux Hahaha okay thank you for looking into this!
                      @phaedrux Do you think this can be fixed by Wednesday? I was planning to bring my printer to work around then but if I have to do something different then I can plan for that!
                        Can you send M122 in the gcode console tab in DWC and copy and paste the results here?
                        Can you also send M98 P"config.g" and paste the results here as well?
                        Your full config.g would be helpful as well.
                        Finally, just to confirm, you've now run sudo apt update and sudo apt dist-upgrade -y on the pi itself sucessfully?
                        Can you show some photos of your paneldue wiring?
                        CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
                          @phaedrux yep!
                          I did sudo apt update and sudo apt dist-upgrade -y on the pi itself successfully! I did it again to be sure and it said no updates!
                          M122
                          RepRapFirmware for Duet 3 MB6HC version 3.4.2 (2022-09-13 15:17:43) running on Duet 3 MB6HC v1.01 (SBC mode)
                          Board ID: 08DJM-956L2-G43S8-6J9F4-3S86J-TA3QF
                          Used output buffers: 3 of 40 (17 max)
                          Static ram: 152664
                          Dynamic ram: 65624 of which 584 recycled
                          Never used RAM 131800, free system stack 216 words
                          Tasks: SBC(ready,0.5%,436) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,333) TMC(notifyWait,8.1%,91) MAIN(running,91.0%,923) IDLE(ready,0.4%,30), total 100.0%
                          Owned mutexes: HTTP(MAIN)
                          Last reset 00:02:13 ago, cause: power up
                          Last software reset details not available
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Step timer max interval 134
                          MCU temperature: min 25.6, current 38.3, max 38.3
                          Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                          Events: 0 queued, 0 completed
                          Driver 0: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                          Driver 1: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                          Driver 2: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                          Driver 3: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                          Driver 4: standstill, SG min 0, mspos 8, reads 19169, writes 15 timeouts 0
                          Driver 5: standstill, SG min 0, mspos 8, reads 19169, writes 15 timeouts 0
                          Date/time: 2022-09-20 22:18:03
                          Slowest loop: 1.27ms; fastest: 0.03ms
                          === Storage ===
                          Free file entries: 10
                          DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          === AuxDDARing ===
                          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                          Segments left: 0
                          Movement lock held by null
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty
                          === CAN ===
                          Messages queued 1100, received 0, lost 0, boc 0
                          Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 668/0/0
                          Tx timeouts 0,0,667,0,0,431 last cancelled message type 4514 dest 127
                          === SBC interface ===
                          Transfer state: 5, failed transfers: 0, checksum errors: 0
                          RX/TX seq numbers: 4952/4952
                          SPI underruns 0, overruns 0
                          State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b1c8
                          Buffer RX/TX: 0/0-0, open files: 0
                          === Duet Control Server ===
                          Duet Control Server v3.4.2
                          Code buffer space: 4096
                          Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                          Full transfers per second: 0.04, max time between full transfers: 169.5ms, max pin wait times: 32.5ms/9.5ms
                          Codes per second: 0.00
                          Maximum length of RX/TX data transfers: 2944/624
                          M98 P"config.g"
                          9/20/2022, 5:20:53 PM Warning: M307: Heater 1 predicted maximum temperature at full power is 580°C
                          9/20/2022, 5:20:53 PM Warning: M307: Heater 0 predicted maximum temperature at full power is 403°C
                          ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 17:41:35 GMT-0400 (Eastern Daylight Time)
                          M550 P"duet3" ; set printer name
                          M669 K1 ; select CoreXY mode
                          M569 P0.0 S0 ; physical drive 0.0 goes forwards
                          M569 P0.2 S0 ; physical drive 0.2 goes forwards
                          M569 P0.4 S1 ; physical drive 0.4 goes forwards
                          M569 P0.5 S1 ; physical drive 0.5 goes forwards
                          M584 X0.5 Y0.4 Z0.0:0.2:0.1 E0.3 ; set drive mapping Z-Motors: Right, Left, Rear
                          M92 X160.00 Y160.00 Z400.00 E812 ; set steps per mm
                          M906 X1400 Y1400 Z1200 E600 I50 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M203 X90000.00 Y90000.00 Z10000.00 E90000.00 ; set maximum speeds (mm/min)
                          M201 X90000.00 Y90000.00 Z2000.00 E90000.00 ; set accelerations (mm/s^2)
                          M566 X9000.00 Y9000.00 Z1200.00 E10000.00 ; set maximum instantaneous speed changes (mm/min)
                          ; Z leadscrew positions
                          M671 X295:0:150 Y295:0:295 S10 ; right, left, back - S Parameter for maximum Correction on G32
                          M208 X295 Y295 Z290 S0 ; set axis maxima
                          M574 X1 S3 ; configure sensorless endstop for low end on X
                          M574 Y1 S3 ; configure sensorless endstop for low end on Y
                          M915 X Y S1 R0
                          M950 S0 C"io5.out" ; create servo pin 0 for BLTouch
                          M558 P9 C"io5.in" F200 H5 R0.2 T9000 A1 B1 ; set Z probe type to bltouch and the dive height + speeds
                          G31 P25 X-28 Y-13 Z2.90 ; set Z probe trigger value, offset and trigger height
                          M557 X15:260 Y15:270 S60 ; define mesh grid
                          M308 S0 P"temp0" Y"thermistor" T100000 B4407 C7.26e-8 ; configure sensor 0 as thermistor on pin temp1
                          M950 H0 C"out2" T0 ; create bed heater output on out1 and map it to sensor 0
                          M143 H0 S145 ; set temperature limit for heater 0 to 145C
                          M308 S1 P"temp1" Y"thermistor" T100000 B4725 C0.0000000706 ; configure sensor 1 as thermistor on pin temp2
                          M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1
                          ;M950 F0 C"out7" Q10 ; create fan 0 on pin out7 and set its frequency
                          ;M106 P0 C"Hotend" S0 H1 T20 ; set fan 0 name and value. Thermostatic control is turned on
                          M950 F0 C"out8" Q100 ; create fan 1 on pin out8 and set its frequency
                          M106 P0 C"Radial" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                          M563 P0 S"e3d V6" D0 H1 F0:1 ; define tool 0
                          ; PID Tunings
                          M307 H1 A555.0, C181.8, D6.3 S1 ; Hotend PID
                          M307 H0 A378.1, C427.3, D3.9 S1 ; Bed PID
                          ;Display stuff
                          M575 P1 S1 B57600
                            Can you update the firmware to 3.4.1 final?
                            https://github.com/Duet3D/PanelDueFirmware/releases/
                            I'm also trying to determine if your 7i V2 requires the card detect modification as well, or if it's perhaps a limitation of SBC mode.
                            Also I don't see M950 D1 C"spi.cs0+spi.cs2" in your config.g
                            CorvoDewittV2undefined 1 Reply Last reply Reply Quote 0
                              @phaedrux I'll update the firmware for the 7i.
                              I get this error from M950 D1 C"spi.cs0+spi.cs2":
                              Error: M950: exactly one of FHJPSR must be given
                              Oh I did modify the card detect thing:
                                Note: if you are using an older version of either PanelDue 7i or PanelDue 5i, or a non-integrated version of PanelDue, then those do not support the CD signal. In that case you should omit the second port, for example:
                                M950 D1 C"spi.cs0"
                                  @phaedrux said in Can't Connect to Duet 3 over wifi after firmware update:
                                  M950 D1 C"spi.cs0"
                                  Get the same error 😞
                                  M950 D1 C"spi.cs0"
                                  Also updated the firmware no change
                                    @phaedrux WAIT its says I have 2 sd cards (sd0 and sd1) sd0 is the boards internal memory and sd1 is the pi is that an issue????
                                    Also M950 D1 also returns the same error. It seems like its not recognizing D1 as a valid command.
                                    Is there a way to access the the files on the Pi from the PanelDue?
                                      That means that the version of RepRapFirmware on your Duet 3 is tool old to support it.
                                        CorvoDewittV2 @dc42
                                        @dc42 Am I missing something? Isn't this the most recent version?
                                        Board: Duet 3 MB6HC (MB6HC)
                                        DSF Version: 3.4.2
                                        Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.2 (2022-09-13)
                                          dc42 administrators @CorvoDewittV2
                                          @corvodewittv2 I just noticed that you are running in SBC mode. SD cards attached to the Duet are not supported in SBC mode. You could use a USB stick attached to the Pi instead.
                                          I will improve the error message in the next release.
                                            CorvoDewittV2 @dc42
                                            @dc42 okay, would files from that show up on the paneldue display? I just need to be able to load files and start prints without wifi
