    Can't Connect to Duet 3 over wifi after firmware update
    Firmware installation
    1.4k
      Duet3 mini5+ wifi?
      How exactly did you perform the firmware update? The guide you linked is pretty old.
      If it's a Duet 3 mini, use this:
      https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#duet-3-mini-5-wifiethernet
      CorvoDewittV2undefined 1 Reply Last reply Reply Quote 0
      • CorvoDewittV2undefined
        CorvoDewittV2 @Phaedrux
        @phaedrux No it is not a mini. I uploaded the zip file to the system page, said yes to update firmware and waited an hour but nothing when I try to connect. The due panel also won't connect. The raspberry pi is still connected to my wifi.
          T3P3Tony administrators @CorvoDewittV2
          @corvodewittv2 to recover from this you will need to connect using USB and a terminal program (like YAT). See:
          https://docs.duet3d.com/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-1
          you mention a Duet 3 and wifi, but say its not a duet 3 mini 5+ wifi - so I guess its a Duet 2 wifi?
          jay_s_ukundefined CorvoDewittV2undefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @T3P3Tony
            @t3p3tony i think its a duet 3 in SBC mode as he talks about a pi.
            I guess he tried to upgrade using the web interface rather than SSHing into the pi and using sudo apt update && sudo apt dist-upgrade -y
              T3P3Tony administrators @jay_s_uk
              @jay_s_uk ahh yes, probably
                CorvoDewittV2 @T3P3Tony
                @t3p3tony it is running in off the pi, and that guide says to take the SD card out but it doesn't have a SD card
                  @corvodewittv2 yeah that guide is for a stand alone Duet. For an SBC setup please do the following:
                  https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup#h-6-update-firmware
                    @t3p3tony okay I'll try that when I get home. It's really just 2 lines of code while SSH into the pi?
                      @corvodewittv2 yes that should work, although i forgot to mention that the upgrade is sting is different with the new version (as @jay_s_uk already mentioned):
                      sudo apt update
                        @t3p3tony I update through the Pi, got all the way to the end, the last line was "done.". I still can not connect to the duet web control. My panel due 7i will also not connect. What should I do now?
                        Nevermind it just needed a few restarts. Lol Can you link a guide to update the panel due? It now will not connect, if that matters/
                        Okay one more thing. How do I print a file from a sd card a usb stick? Can't figure it out. Or from a computer. Just not over wifi. I have to take the machine to work and connecting to wifi is really not a option.
                          CorvoDewittV2
                          @t3p3tony Like I can't figure out how to use the SD card slot on the PanelDue i7 I have so I can use the printer offline. It seems like a simple thing but it is kicking my butt.
                            To use a Duet3 and PanelDue SD card slot you need to follow this wiring arrangement.
                            https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_PanelDue#duet-3-mb6hc-using-ribbon-cable
                            Have you done that?
                            To use a USB drive on the Pi and access it from the Duet you need to mount the USB key and give read write access to it.
                            Take a look here: https://forum.duet3d.com/topic/29081/cant-read-usb-drive
                              @phaedrux I am trying to get the SD card to show up and I'm hitting a few issues. I am going to put a lot of info here so hopefully you can figure out what I am doing wrong!
                              PanelDue 7i V2 Firmware 3.4.1-pre2
                              Duet 3 MB6HC Firmware 3.4.2
                              I want to use the ribbon cable in the temp daughterboard connector. Im not sure which way the ribbon connector should be plugged into the board. Should the red line be towards the power screw terminals or away?
                              I cut conductors 1,9,10 on the ribbon cable per the picture.
                              When I run M950 D1 C"spi.cs0" or M950 D1 C"spi.cs0+spi.cs2" I get the error "M950: exactly one of FHJPSR must be given" What am I doing wrong here?
                              I jumped GND to NC on the 7i.
                              Am I missing anything else?
                              Thanks in advance!
                              Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @CorvoDewittV2
                                This post is deleted!
                                  @phaedrux why did you delete your reply?
                                    @corvodewittv2 said in Can't Connect to Duet 3 over wifi after firmware update:
                                    Cause I need to think harder. 😜
                                    I'll have to take a deeper look later.
                                    CorvoDewittV2undefined 2 Replies Last reply Reply Quote 1
                                      @phaedrux Hahaha okay thank you for looking into this!
                                        @phaedrux Do you think this can be fixed by Wednesday? I was planning to bring my printer to work around then but if I have to do something different then I can plan for that!
                                          Can you send M122 in the gcode console tab in DWC and copy and paste the results here?
                                          Can you also send M98 P"config.g" and paste the results here as well?
                                          Your full config.g would be helpful as well.
                                          Finally, just to confirm, you've now run sudo apt update and sudo apt dist-upgrade -y on the pi itself sucessfully?
                                          Can you show some photos of your paneldue wiring?
                                          CorvoDewittV2undefined 1 Reply Last reply Reply Quote 1
                                            @phaedrux yep!
                                            I did sudo apt update and sudo apt dist-upgrade -y on the pi itself successfully! I did it again to be sure and it said no updates!
                                            M122
                                            RepRapFirmware for Duet 3 MB6HC version 3.4.2 (2022-09-13 15:17:43) running on Duet 3 MB6HC v1.01 (SBC mode)
                                            Board ID: 08DJM-956L2-G43S8-6J9F4-3S86J-TA3QF
                                            Used output buffers: 3 of 40 (17 max)
                                            Static ram: 152664
                                            Dynamic ram: 65624 of which 584 recycled
                                            Never used RAM 131800, free system stack 216 words
                                            Tasks: SBC(ready,0.5%,436) HEAT(notifyWait,0.0%,322) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.0%,944) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,333) TMC(notifyWait,8.1%,91) MAIN(running,91.0%,923) IDLE(ready,0.4%,30), total 100.0%
                                            Owned mutexes: HTTP(MAIN)
                                            Last reset 00:02:13 ago, cause: power up
                                            Last software reset details not available
                                            Error status: 0x00
                                            Aux0 errors 0,0,0
                                            Step timer max interval 134
                                            MCU temperature: min 25.6, current 38.3, max 38.3
                                            Supply voltage: min 24.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                                            12V rail voltage: min 12.2, current 12.2, max 12.3, under voltage events: 0
                                            Events: 0 queued, 0 completed
                                            Driver 0: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                                            Driver 1: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                                            Driver 2: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                                            Driver 3: standstill, SG min 0, mspos 8, reads 19170, writes 14 timeouts 0
                                            Driver 4: standstill, SG min 0, mspos 8, reads 19169, writes 15 timeouts 0
                                            Driver 5: standstill, SG min 0, mspos 8, reads 19169, writes 15 timeouts 0
                                            Date/time: 2022-09-20 22:18:03
                                            Slowest loop: 1.27ms; fastest: 0.03ms
                                            === Storage ===
                                            Free file entries: 10
                                            DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                            === MainDDARing ===
                                            === AuxDDARing ===
                                            Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                                            Segments left: 0
                                            Movement lock held by null
                                            Telnet is idle in state(s) 0
                                            File is idle in state(s) 0
                                            USB is idle in state(s) 0
                                            Aux is idle in state(s) 0
                                            Queue is idle in state(s) 0
                                            LCD is idle in state(s) 0
                                            SBC is idle in state(s) 0
                                            Daemon is idle in state(s) 0
                                            Aux2 is idle in state(s) 0
                                            Code queue is empty
                                            === CAN ===
                                            Messages queued 1100, received 0, lost 0, boc 0
                                            Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 668/0/0
                                            Tx timeouts 0,0,667,0,0,431 last cancelled message type 4514 dest 127
                                            === SBC interface ===
                                            Transfer state: 5, failed transfers: 0, checksum errors: 0
                                            RX/TX seq numbers: 4952/4952
                                            SPI underruns 0, overruns 0
                                            State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x2b1c8
                                            Buffer RX/TX: 0/0-0, open files: 0
                                            === Duet Control Server ===
                                            Duet Control Server v3.4.2
                                            Code buffer space: 4096
                                            Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                            Full transfers per second: 0.04, max time between full transfers: 169.5ms, max pin wait times: 32.5ms/9.5ms
                                            Codes per second: 0.00
                                            Maximum length of RX/TX data transfers: 2944/624
                                            M98 P"config.g"
                                            9/20/2022, 5:20:53 PM Warning: M307: Heater 1 predicted maximum temperature at full power is 580°C
                                            9/20/2022, 5:20:53 PM Warning: M307: Heater 0 predicted maximum temperature at full power is 403°C
                                            ; generated by RepRapFirmware Configuration Tool v3.1.3 on Fri Jul 03 2020 17:41:35 GMT-0400 (Eastern Daylight Time)
                                            M550 P"duet3" ; set printer name
                                            M669 K1 ; select CoreXY mode
                                            M569 P0.0 S0 ; physical drive 0.0 goes forwards
                                            M569 P0.2 S0 ; physical drive 0.2 goes forwards
                                            M569 P0.4 S1 ; physical drive 0.4 goes forwards
                                            M569 P0.5 S1 ; physical drive 0.5 goes forwards
                                            M584 X0.5 Y0.4 Z0.0:0.2:0.1 E0.3 ; set drive mapping Z-Motors: Right, Left, Rear
                                            M92 X160.00 Y160.00 Z400.00 E812 ; set steps per mm
                                            M906 X1400 Y1400 Z1200 E600 I50 ; set motor currents (mA) and motor idle factor in per cent
                                            M84 S30 ; Set idle timeout
                                            M203 X90000.00 Y90000.00 Z10000.00 E90000.00 ; set maximum speeds (mm/min)
                                            M201 X90000.00 Y90000.00 Z2000.00 E90000.00 ; set accelerations (mm/s^2)
                                            M566 X9000.00 Y9000.00 Z1200.00 E10000.00 ; set maximum instantaneous speed changes (mm/min)
                                            ; Z leadscrew positions
                                            M671 X295:0:150 Y295:0:295 S10 ; right, left, back - S Parameter for maximum Correction on G32
                                            M208 X295 Y295 Z290 S0 ; set axis maxima
                                            M574 X1 S3 ; configure sensorless endstop for low end on X
                                            M574 Y1 S3 ; configure sensorless endstop for low end on Y
                                            M915 X Y S1 R0
                                            M950 S0 C"io5.out" ; create servo pin 0 for BLTouch
                                            M558 P9 C"io5.in" F200 H5 R0.2 T9000 A1 B1 ; set Z probe type to bltouch and the dive height + speeds
                                            G31 P25 X-28 Y-13 Z2.90 ; set Z probe trigger value, offset and trigger height
                                            M557 X15:260 Y15:270 S60 ; define mesh grid
                                            M308 S0 P"temp0" Y"thermistor" T100000 B4407 C7.26e-8 ; configure sensor 0 as thermistor on pin temp1
                                            M950 H0 C"out2" T0 ; create bed heater output on out1 and map it to sensor 0
                                            M143 H0 S145 ; set temperature limit for heater 0 to 145C
                                            M308 S1 P"temp1" Y"thermistor" T100000 B4725 C0.0000000706 ; configure sensor 1 as thermistor on pin temp2
                                            M950 H1 C"out1" T1 ; create nozzle heater output on out2 and map it to sensor 1
                                            ;M950 F0 C"out7" Q10 ; create fan 0 on pin out7 and set its frequency
                                            ;M106 P0 C"Hotend" S0 H1 T20 ; set fan 0 name and value. Thermostatic control is turned on
                                            M950 F0 C"out8" Q100 ; create fan 1 on pin out8 and set its frequency
                                            M106 P0 C"Radial" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off
                                            M563 P0 S"e3d V6" D0 H1 F0:1 ; define tool 0
                                            ; PID Tunings
                                            M307 H1 A555.0, C181.8, D6.3 S1 ; Hotend PID
                                            M307 H0 A378.1, C427.3, D3.9 S1 ; Bed PID
                                            ;Display stuff
                                            M575 P1 S1 B57600
