    New experimental firmware 1.20beta2
    Firmware installation
    12
    44
    5.7k
    • MoS-tekknixundefined
      MoS-tekknix
      Confirmed the Error is gone for config-override.g
      Thanks, waiting for Final of it 😉 But, i hope that we see always an ongoing release of Firmware(s) 😉
        MoS-tekknix
        Mhh, tried to do a simulation via WebIf and it stucks at 0.5%, also it is not possible to cancel the print. Need to press Emergency-Stop
        • AS-3D Druckundefined
          AS-3D Druck
          Nice a new Version. 🙂
          Can i simply upload the latest Version from:
          Firmware Version: 1.19.2 (2017-09-01)
          WiFi Server Version: 1.19.2
          My CoreXY Printer
          Best regards
          AS-3D Druck / Andre
            @MoS-tekknix:
            I confirm there is a bug in simulation mode, in 1.20b2 and b3.
              @AS-3D:
              My CoreXY Printer
              Latest stable firmware is always at https://github.com/dc42/RepRapFirmware/releases. Read the upgrade notes first, especially the ones for upgrading from 1.18 to 1.19.
                MoS-tekknix
                @dc42:
                @MoS-tekknix:
                Thanks David.
                  AS-3D Druck
                  @AS-3D:
                  My CoreXY Printer
                  My fault, i wanna know if i can use the latest Beta Version from my current Version or do i have to use Beta 1 and after that Beta 2?
                  Best regards
                  AS-3D Druck / Andre
                    Yes, you can upload directly to the latest beta from 1.19.2.
                      I've just published 1.20beta4 to fix a couple more bugs.
                      • DjDemonDundefined
                        DjDemonD
                        beta 4 working for me, just completed a print no issues.
                        www.precisionpiezo.co.uk
                          Thanks for the feedback.
                          • DjDemonDundefined
                            DjDemonD
                            Am currently using
                            Firmware Electronics: Duet WiFi 1.0
                            Firmware Version: 1.20beta4 (2017-10-28)
                            WiFi Server Version: 1.20beta2
                            Web Interface Version: 1.19.3
                            Issue is after I began a print I got a pause reporting "filament monitor reports too little filament fed extruder 0" and a pause, but not the usual pause, no head movement away from the print, it just hung with the nozzle on the print. The DWC unresponsive and the paneldue unresponsive. I had to power cycle it to get it running again.
                            Going back to beta 1 for now.
                            UPDATE just went back to beta 1, same print, got the extruder fed too little message but a normal pause, hit resume and back printing (changes the tolerance to 40% from 30%). So I'd postulate definitely a bug from beta 1 to beta 4.
                            M122 as below
                            19:25:33M122
                            Used output buffers: 3 of 32 (10 max)
                            RepRapFirmware for Duet WiFi version 1.20beta4 running on Duet WiFi 1.0
                            Board ID: 08DAM-999TL-MQ4S4-6J1FG-3S46M-TPHVY
                            Static ram used: 15320
                            Dynamic ram used: 97368
                            Recycled dynamic ram: 2000
                            Stack ram used: 1368 current, 4800 maximum
                            Never used ram: 11584
                            Last reset 00:29:15 ago, cause: power up
                            Last software reset reason: User, spinning module GCodes, available RAM 7224 bytes (slot 0)
                            Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff
                            Error status: 0
                            Free file entries: 9
                            SD card longest block write time: 10.6ms
                            MCU temperature: min 30.0, current 36.7, max 36.8
                            Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0
                            Driver 0: stalled standstill
                            Driver 1: standstill
                            Driver 2: stalled standstill
                            Driver 3: standstill
                            Driver 4: standstill
                            Date/time: 2017-11-01 19:25:32
                            Slowest main loop (seconds): 0.016020; fastest: 0.000035
                            MaxReps: 3, StepErrors: 0, FreeDm: 240, MinFreeDm 234, MaxWait: 3692473758ms, Underruns: 0, 0
                            Scheduled moves: 6, completed moves: 6
                            Bed compensation in use: none
                            Bed heater = 0, chamber heater = 2
                            Heater 0 is on, I-accum = 0.0
                            Heater 1 is on, I-accum = 0.0
                            Segments left: 0
                            Movement lock held by null
                            http is idle in state(s) 0
                            telnet is idle in state(s) 0
                            file is idle in state(s) 0
                            serial is idle in state(s) 0
                            aux is idle in state(s) 0
                            daemon is idle in state(s) 0
                            queue is idle in state(s) 0
                            Code queue is empty.
                            Network state is running
                            WiFi firmware version 1.20beta2
                            WiFi MAC address 18:fe:34:ca:f8:7e
                            WiFi Vcc 3.11, reset reason Turned on by main processor
                            WiFi flash size 4194304, free heap 39152
                            WiFi IP address 192.168.0.109
                            WiFi signal strength -33dBm, reconnections 0, sleep mode modem
                            HTTP sessions: 1 of 8
                            Socket states: 2 0 0 0 0 0 0 0
                            Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                            === Filament sensors ===
                            Extruder 0 sensor: angle 1.1, ok, no calibration data
                            event log```
                            2017-09-24 11:41:20 Event logging started
                            2017-09-24 12:20:59 Printing paused
                            2017-09-24 12:21:22 Printing resumed
                            2017-09-24 13:39:23 Finished printing file 0:/gcodes/Large Kossel_Container.gcode, print time was 2h 16m
                            2017-09-24 14:14:11 Started printing file 0:/gcodes/Large Kossel_Container2.gcode
                            2017-09-24 14:18:54 Calibrated 8 factors using 16 points, deviation before 0.038 after 0.011
                            2017-09-24 17:02:27 Finished printing file 0:/gcodes/Large Kossel_Container2.gcode, print time was 2h 48m
                            2017-09-24 19:58:02 Started printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode
                            2017-09-24 19:58:57 Calibrated 8 factors using 16 points, deviation before 0.041 after 0.015
                            2017-09-24 20:29:34 Finished printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode, print time was 0h 32m
                            2017-09-24 21:01:20 Started printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode
                            2017-09-24 21:05:48 Calibrated 8 factors using 16 points, deviation before 0.048 after 0.021
                            2017-09-24 21:38:37 Finished printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode, print time was 0h 37m
                            power up + 00:00:02 Event logging started
                            power up + 00:00:02 Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 448C.
                            power up + 00:00:02 Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 336C.
                            power up + 00:00:02 Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 734C.
                            power up + 00:00:02 WiFi module started
                            power up + 00:00:09 Wifi module is connected to access point 3DP, IP address 192.168.0.109
                            power up + 00:02:42 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-09-25 20:39:44 HTTP client 192.168.0.117 login succeeded
                            2017-09-25 20:49:38 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-09-25 20:50:40 Calibrated 8 factors using 16 points, deviation before 0.042 after 0.016
                            2017-09-25 20:56:17 Warning: Tool 98 was not driven because its heater temperatures were not high enough or it has a heater fault
                            2017-09-25 20:56:21 Warning: Tool 98 was not driven because its heater temperatures were not high enough or it has a heater fault
                            2017-09-25 20:56:21 Warning: Tool 99 was not driven because its heater temperatures were not high enough or it has a heater fault
                            2017-09-25 20:56:21 Error: Attempting to extrude with no tool selected.
                            2017-09-25 20:56:25 Error: Attempting to extrude with no tool selected.
                            2017-09-25 20:56:29 Error: Attempting to extrude with no tool selected.
                            2017-09-25 20:56:33 Error: Attempting to extrude with no tool selected.
                            2017-09-25 20:56:37 Error: Attempting to extrude with no tool selected.
                            2017-09-25 20:56:41 Error: Attempting to extrude with no tool selected.
                            2017-09-25 20:56:45 Error: Attempting to extrude with no tool selected.
                            2017-09-25 22:38:07 Event logging stopped
                            2017-09-25 22:38:18 HTTP client 192.168.0.117 login succeeded
                            2017-09-25 23:39:14 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-09-25 23:44:05 Calibrated 8 factors using 16 points, deviation before 0.025 after 0.013
                            2017-09-26 00:45:07 HTTP client 192.168.0.106 attempted login with incorrect password
                            2017-09-26 00:45:22 HTTP client 192.168.0.106 login succeeded
                            2017-09-26 01:45:27 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 6m
                            2017-09-26 07:00:56 HTTP client 192.168.0.106 login succeeded
                            2017-09-26 19:12:20 HTTP client 192.168.0.117 login succeeded
                            2017-09-26 19:13:52 Event logging stopped
                            power up + 00:00:09 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:01:25 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-09-26 19:15:34 HTTP client 192.168.0.117 login succeeded
                            2017-09-26 19:15:41 Event logging stopped
                            2017-09-26 19:16:01 HTTP client 192.168.0.117 login succeeded
                            2017-09-26 19:16:57 Started printing file 0:/gcodes/SMARTRAP_kostka20x20_with 8mm hole.gcode
                            2017-09-26 19:22:28 Calibrated 8 factors using 16 points, deviation before 0.025 after 0.015
                            2017-09-26 19:30:30 Finished printing file 0:/gcodes/SMARTRAP_kostka20x20_with 8mm hole.gcode, print time was 0h 14m
                            2017-09-26 19:38:33 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
                            2017-09-26 19:41:08 Calibrated 8 factors using 16 points, deviation before 0.042 after 0.012
                            2017-09-26 23:21:08 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 3h 43m
                            power up + 00:01:39 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-09-27 22:33:36 HTTP client 192.168.0.117 login succeeded
                            2017-09-27 22:39:15 Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 714C.
                            2017-09-27 22:39:15 Auto tune heater 1 completed in 294 sec
                            Use M307 H1 to see the result, or M500 to save the result in config-override.g
                            power up + 00:00:12 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-09-28 14:13:42 HTTP client 192.168.0.117 login succeeded
                            2017-09-28 14:27:21 Started printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode
                            2017-09-28 14:28:00 Resume-after-power-fail state saved
                            2017-09-28 14:28:02 Printing paused
                            2017-09-28 14:28:03 Finished printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode, print time was 0h 1m
                            2017-09-28 14:28:09 Started printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode
                            2017-09-28 14:30:25 Calibrated 8 factors using 16 points, deviation before 0.075 after 0.017
                            2017-09-28 14:37:50 Resume-after-power-fail state saved
                            2017-09-28 14:37:51 Printing paused
                            2017-09-28 14:38:14 Printing resumed
                            2017-09-28 14:38:27 Resume-after-power-fail state saved
                            2017-09-28 14:38:29 Printing paused
                            2017-09-28 14:38:50 Printing resumed
                            2017-09-28 14:54:01 Finished printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode, print time was 0h 25m
                            2017-09-28 22:37:28 HTTP client 192.168.0.106 attempted login with incorrect password
                            power up + 00:03:35 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-09-29 13:48:38 HTTP client 192.168.0.117 login succeeded
                            2017-09-29 14:00:16 Started printing file 0:/gcodes/Large Kossel_shower holder backing.gcode
                            2017-09-29 14:01:54 Calibrated 8 factors using 16 points, deviation before 0.028 after 0.020
                            2017-09-29 15:52:10 Finished printing file 0:/gcodes/Large Kossel_shower holder backing.gcode, print time was 1h 52m
                            power up + 00:00:55 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-09-30 09:50:54 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 10:14:08 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-09-30 10:15:14 Calibrated 8 factors using 16 points, deviation before 0.034 after 0.015
                            2017-09-30 10:29:05 HTTP client 192.168.0.106 attempted login with incorrect password
                            2017-09-30 10:29:12 HTTP client 192.168.0.106 login succeeded
                            2017-09-30 11:06:07 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 11:40:51 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 11:41:37 Event logging stopped
                            2017-09-30 11:41:46 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 11:43:25 HTTP client 192.168.0.117 login succeeded
                            power up + 00:00:07 Wifi module is connected to access point 3DP, IP address 192.168.0.109
                            2017-09-30 11:54:13 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 11:54:22 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-09-30 11:55:35 Event logging stopped
                            2017-09-30 11:55:45 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 11:55:51 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-09-30 12:00:01 Calibrated 8 factors using 16 points, deviation before 0.032 after 0.014
                            2017-09-30 13:47:34 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 1h 52m
                            2017-09-30 14:35:12 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 14:50:34 Started printing file 0:/gcodes/Large Kossel_50mm exhaust fan shroud and diverter for enclosure.gcode
                            2017-09-30 14:51:49 Calibrated 8 factors using 16 points, deviation before 0.118 after 0.022
                            2017-09-30 16:49:15 Finished printing file 0:/gcodes/Large Kossel_50mm exhaust fan shroud and diverter for enclosure.gcode, print time was 1h 59m
                            power up + 00:00:10 Wifi module is connected to access point 3DP, IP address 192.168.0.109
                            2017-09-30 17:43:14 HTTP client 192.168.0.117 login succeeded
                            2017-09-30 22:46:05 Started printing file 0:/gcodes/Large Kossel_Container.gcode
                            2017-09-30 22:47:07 Calibrated 8 factors using 16 points, deviation before 0.104 after 0.018
                            2017-10-01 03:00:38 Finished printing file 0:/gcodes/Large Kossel_Container.gcode, print time was 4h 15m
                            2017-10-01 10:40:20 HTTP client 192.168.0.117 login succeeded
                            power up + 00:02:14 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-10-02 21:52:16 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 21:54:07 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 1.8°C/sec
                            2017-10-02 22:01:19 Event logging stopped
                            2017-10-02 22:01:32 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:03:16 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:04:23 Event logging stopped
                            2017-10-02 22:04:33 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:04:36 HTTP client 192.168.0.117 disconnected
                            2017-10-02 22:04:36 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:09:13 Event logging stopped
                            2017-10-02 22:13:39 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:14:20 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 1.8°C/sec
                            2017-10-02 22:19:52 Event logging stopped
                            2017-10-02 22:20:03 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:22:01 Event logging stopped
                            2017-10-02 22:22:13 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:22:50 Event logging stopped
                            2017-10-02 22:23:04 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:24:55 Event logging stopped
                            2017-10-02 22:25:04 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:26:08 Event logging stopped
                            2017-10-02 22:26:40 HTTP client 192.168.0.117 login succeeded
                            2017-10-02 22:39:53 Started printing file 0:/gcodes/Large Kossel_SSR cover Revised no sides deeper lettering.gcode
                            2017-10-02 22:40:54 Calibrated 8 factors using 16 points, deviation before 0.846 after 0.021
                            2017-10-02 23:08:15 Resume-after-power-fail state saved
                            2017-10-02 23:08:17 Printing paused
                            2017-10-02 23:10:42 Printing resumed
                            2017-10-02 23:10:47 Resume-after-power-fail state saved
                            2017-10-02 23:10:49 Printing paused
                            2017-10-02 23:10:53 Printing resumed
                            2017-10-03 00:38:38 Finished printing file 0:/gcodes/Large Kossel_SSR cover Revised no sides deeper lettering.gcode, print time was 1h 56m
                            2017-10-03 00:51:24 Started printing file 0:/gcodes/Large Kossel_desk_roller_v2_original.gcode
                            2017-10-03 00:52:41 Calibrated 8 factors using 16 points, deviation before 0.062 after 0.017
                            2017-10-03 03:23:24 Finished printing file 0:/gcodes/Large Kossel_desk_roller_v2_original.gcode, print time was 2h 32m
                            2017-10-03 21:31:48 HTTP client 192.168.0.117 login succeeded
                            power up + 00:01:55 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-10-03 22:28:15 HTTP client 192.168.0.117 login succeeded
                            2017-10-03 22:34:02 Auto tune heater 2 completed in 276 sec
                            Use M307 H2 to see the result, or M500 to save the result in config-override.g
                            2017-10-03 22:40:15 Event logging stopped
                            2017-10-03 22:40:26 HTTP client 192.168.0.117 login succeeded
                            2017-10-03 23:24:29 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 0.3°C/sec
                            2017-10-03 23:24:42 Event logging stopped
                            2017-10-03 23:24:53 HTTP client 192.168.0.117 login succeeded
                            2017-10-03 23:25:22 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 0.4°C/sec
                            2017-10-03 23:32:59 Event logging stopped
                            2017-10-03 23:33:10 HTTP client 192.168.0.117 login succeeded
                            2017-10-03 23:37:49 Event logging stopped
                            2017-10-03 23:38:00 HTTP client 192.168.0.117 login succeeded
                            power up + 00:03:51 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-10-04 10:10:42 HTTP client 192.168.0.117 login succeeded
                            2017-10-04 10:11:34 Event logging stopped
                            2017-10-04 10:11:46 HTTP client 192.168.0.117 login succeeded
                            2017-10-04 10:26:43 Started printing file 0:/gcodes/Large Kossel_warpinator5000.gcode
                            2017-10-04 10:31:43 Calibrated 8 factors using 16 points, deviation before 0.186 after 0.010
                            2017-10-04 10:31:49 Resume-after-power-fail state saved
                            2017-10-04 10:31:51 Printing paused
                            2017-10-04 10:32:06 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                            2017-10-04 10:32:07 Printing resumed
                            2017-10-04 11:26:38 Resume-after-power-fail state saved
                            2017-10-04 11:26:43 Printing paused
                            2017-10-04 11:26:51 Printing resumed
                            2017-10-04 11:29:32 Finished printing file 0:/gcodes/Large Kossel_warpinator5000.gcode, print time was 1h 2m
                            2017-10-04 11:49:11 Event logging stopped
                            2017-10-04 11:49:26 HTTP client 192.168.0.117 login succeeded
                            power up + 00:02:58 HTTP client 192.168.0.117 attempted login with incorrect password
                            2017-10-04 22:11:04 HTTP client 192.168.0.117 login succeeded
                            2017-10-04 22:12:54 Event logging stopped
                            power up + 00:00:11 Time and date set
                            2017-10-04 22:13:13 HTTP client 192.168.0.117 login succeeded
                            2017-10-04 22:39:01 Started printing file 0:/gcodes/Large Kossel_Titan_Mount_Bracket_4_Spacer.gcode
                            2017-10-04 22:40:02 Calibrated 8 factors using 16 points, deviation before 0.192 after 0.014
                            2017-10-04 22:48:26 HTTP client 192.168.0.117 login succeeded
                            2017-10-04 22:50:28 Error: Heating fault on heater 2, temperature excursion exceeded 15.0°C
                            2017-10-04 22:50:45 Event logging stopped
                            power up + 00:00:10 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:00:16 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:00:18 Time and date set
                            2017-10-04 22:51:05 HTTP client 192.168.0.117 login succeeded
                            2017-10-04 22:52:26 Started printing file Large Kossel_Titan_Mount_Bracket_4_Spacer.gcode
                            2017-10-04 22:53:19 Calibrated 8 factors using 16 points, deviation before 0.183 after 0.016
                            2017-10-05 00:48:28 Finished printing file Large Kossel_Titan_Mount_Bracket_4_Spacer.gcode, print time was 1h 56m
                            power up + 00:02:45 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:02:48 Time and date set
                            2017-10-05 14:24:58 HTTP client 192.168.0.117 login succeeded
                            2017-10-05 14:35:10 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-05 14:36:03 Calibrated 8 factors using 16 points, deviation before 0.209 after 0.016
                            2017-10-05 16:20:28 Resume-after-power-fail state saved
                            2017-10-05 16:20:30 Printing paused
                            2017-10-05 16:20:31 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 1h 45m
                            2017-10-05 16:30:37 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-05 16:33:42 Calibrated 8 factors using 16 points, deviation before 0.064 after 0.012
                            2017-10-05 18:35:01 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
                            2017-10-05 21:49:50 Started printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode
                            2017-10-05 21:50:09 Resume-after-power-fail state saved
                            2017-10-05 21:50:09 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                            2017-10-05 21:50:10 Printing paused
                            2017-10-05 21:50:10 Finished printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode, print time was 0h 0m
                            2017-10-05 21:51:17 Started printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode
                            2017-10-05 21:56:17 Calibrated 8 factors using 13 points, deviation before 0.041 after 0.006
                            2017-10-05 22:54:24 Finished printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode, print time was 1h 3m
                            power up + 00:19:55 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:20:19 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:20:22 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:20:32 Time and date set
                            2017-10-06 14:31:04 HTTP client 192.168.0.117 login succeeded
                            2017-10-06 14:37:11 Event logging stopped
                            power up + 00:00:09 Time and date set
                            2017-10-06 14:37:22 HTTP client 192.168.0.117 login succeeded
                            2017-10-06 14:38:56 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
                            2017-10-06 14:40:02 Resume-after-power-fail state saved
                            2017-10-06 14:40:04 Printing paused
                            2017-10-06 14:40:32 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                            2017-10-06 14:40:33 Printing resumed
                            2017-10-06 14:44:05 Calibrated 8 factors using 13 points, deviation before 0.209 after 0.004
                            2017-10-06 14:49:00 Resume-after-power-fail state saved
                            2017-10-06 14:49:02 Printing paused
                            2017-10-06 14:49:03 Finished printing file 0:/gcodes/Large Kossel_kostka20x20.gcode, print time was 0h 10m
                            2017-10-06 14:49:25 Event logging stopped
                            power up + 00:00:14 Time and date set
                            2017-10-06 14:49:40 HTTP client 192.168.0.117 login succeeded
                            2017-10-06 14:49:43 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
                            2017-10-06 14:51:05 Calibrated 8 factors using 13 points, deviation before 0.019 after 0.007
                            power up + 00:00:22 Time and date set
                            2017-10-06 14:56:08 HTTP client 192.168.0.117 login succeeded
                            2017-10-06 14:57:15 Started printing file 0:/gcodes/resurrect.g
                            2017-10-06 14:59:30 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
                            2017-10-06 14:59:51 Resume-after-power-fail state saved
                            2017-10-06 14:59:53 Printing paused
                            2017-10-06 14:59:54 Finished printing file 0:/gcodes/Large Kossel_kostka20x20.gcode, print time was 0h 0m
                            power up + 00:04:34 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:04:39 Time and date set
                            2017-10-08 10:23:01 HTTP client 192.168.0.117 login succeeded
                            2017-10-08 10:23:54 Started printing file 0:/gcodes/Large Kossel_x183 leg model.gcode
                            2017-10-08 10:24:37 Calibrated 8 factors using 13 points, deviation before 0.043 after 0.004
                            2017-10-08 10:54:50 Finished printing file 0:/gcodes/Large Kossel_x183 leg model.gcode, print time was 0h 31m
                            2017-10-08 10:58:00 Started printing file 0:/gcodes/Large Kossel_x183 leg model.gcode
                            2017-10-08 10:59:12 Resume-after-power-fail state saved
                            2017-10-08 10:59:13 Printing paused
                            2017-10-08 11:01:52 Finished printing file 0:/gcodes/Large Kossel_x183 leg model.gcode, print time was 0h 1m
                            2017-10-08 11:01:58 Started printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode
                            2017-10-08 11:02:52 Calibrated 8 factors using 13 points, deviation before 0.049 after 0.006
                            2017-10-08 11:13:16 Resume-after-power-fail state saved
                            2017-10-08 11:13:18 Printing paused
                            2017-10-08 11:13:19 Finished printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode, print time was 0h 11m
                            2017-10-08 11:14:35 Started printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode
                            2017-10-08 11:15:22 Calibrated 8 factors using 13 points, deviation before 0.020 after 0.008
                            2017-10-08 11:42:52 Finished printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode, print time was 0h 28m
                            2017-10-08 11:49:35 Started printing file 0:/gcodes/Large Kossel_x183 leg support for 6mm carbon tube 1.0.gcode
                            2017-10-08 11:51:57 Calibrated 8 factors using 13 points, deviation before 0.045 after 0.007
                            2017-10-08 13:39:01 Finished printing file 0:/gcodes/Large Kossel_x183 leg support for 6mm carbon tube 1.0.gcode, print time was 1h 49m
                            2017-10-08 16:18:35 Event logging stopped
                            2017-10-08 16:18:47 HTTP client 192.168.0.117 login succeeded
                            2017-10-08 16:37:30 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-08 16:38:12 Calibrated 8 factors using 13 points, deviation before 0.083 after 0.008
                            2017-10-08 18:39:36 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 2m
                            power up + 00:00:13 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:00:16 Time and date set
                            2017-10-10 18:49:12 HTTP client 192.168.0.117 login succeeded
                            2017-10-10 18:55:23 Calibrated 8 factors using 13 points, deviation before 0.034 after 0.012
                            2017-10-10 19:02:26 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-10 19:03:17 Calibrated 8 factors using 13 points, deviation before 0.037 after 0.016
                            2017-10-10 21:06:31 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
                            2017-10-10 21:40:26 HTTP client 192.168.0.117 login succeeded
                            2017-10-10 21:54:38 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
                            2017-10-10 21:56:29 Calibrated 8 factors using 13 points, deviation before 0.058 after 0.008
                            2017-10-10 23:48:21 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 1h 54m
                            power up + 00:04:15 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:04:25 Time and date set
                            2017-10-12 00:07:03 HTTP client 192.168.0.117 login succeeded
                            2017-10-12 00:07:58 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-12 00:12:58 Calibrated 8 factors using 13 points, deviation before 0.025 after 0.003
                            2017-10-12 02:16:09 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 8m
                            power up + 00:06:48 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:06:54 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:06:57 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:07:00 Time and date set
                            2017-10-12 18:59:21 HTTP client 192.168.0.117 login succeeded
                            2017-10-12 19:09:00 HTTP client 192.168.0.117 login succeeded
                            2017-10-12 19:09:04 HTTP client 192.168.0.117 login succeeded
                            2017-10-12 19:09:15 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-12 19:10:05 Calibrated 8 factors using 13 points, deviation before 0.159 after 0.016
                            2017-10-12 21:13:46 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 5m
                            2017-10-12 21:40:05 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-12 21:40:48 Calibrated 8 factors using 13 points, deviation before 0.157 after 0.009
                            2017-10-12 23:43:46 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
                            power up + 00:22:22 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:22:26 Time and date set
                            2017-10-15 10:40:19 HTTP client 192.168.0.117 login succeeded
                            2017-10-15 10:42:20 Started printing file 0:/gcodes/Large Kossel_extruder-body.gcode
                            2017-10-15 10:43:58 Calibrated 8 factors using 16 points, deviation before 0.242 after 0.015
                            2017-10-15 16:17:16 Finished printing file 0:/gcodes/Large Kossel_extruder-body.gcode, print time was 5h 35m
                            power up + 00:01:59 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:02:02 Time and date set
                            2017-10-15 20:02:19 HTTP client 192.168.0.117 login succeeded
                            2017-10-15 20:02:28 Started printing file 0:/gcodes/Large Kossel_Bearing_block1.gcode
                            2017-10-15 20:05:03 Calibrated 8 factors using 16 points, deviation before 0.028 after 0.012
                            2017-10-15 21:17:56 Finished printing file 0:/gcodes/Large Kossel_Bearing_block1.gcode, print time was 1h 15m
                            2017-10-15 21:23:25 Started printing file 0:/gcodes/Large Kossel_Bearing_block1_SKMOD.gcode
                            2017-10-15 21:24:59 Calibrated 8 factors using 16 points, deviation before 0.042 after 0.014
                            2017-10-15 22:10:20 Finished printing file 0:/gcodes/Large Kossel_Bearing_block1_SKMOD.gcode, print time was 0h 47m
                            2017-10-15 22:19:25 Error: Temperature reading fault on heater 1: sensor open circuit
                            2017-10-15 22:54:27 Event logging stopped
                            2017-10-15 22:54:39 HTTP client 192.168.0.117 login succeeded
                            2017-10-15 22:57:08 Event logging stopped
                            power up + 00:00:10 Time and date set
                            2017-10-15 22:57:21 HTTP client 192.168.0.117 login succeeded
                            2017-10-15 23:02:06 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
                            2017-10-15 23:03:24 Calibrated 8 factors using 16 points, deviation before 0.028 after 0.020
                            2017-10-15 23:19:51 Finished printing file 0:/gcodes/Large Kossel_kostka20x20.gcode, print time was 0h 18m
                            2017-10-15 23:20:31 Event logging stopped
                            2017-10-15 23:20:43 HTTP client 192.168.0.117 login succeeded
                            power up + 00:15:08 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:22:17 Time and date set
                            2017-10-16 22:43:30 HTTP client 192.168.0.117 login succeeded
                            2017-10-16 22:52:06 Calibrated 8 factors using 13 points, deviation before 0.047 after 0.005
                            2017-10-16 22:52:25 Started printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode
                            2017-10-16 22:53:16 Calibrated 8 factors using 13 points, deviation before 0.030 after 0.008
                            2017-10-16 22:53:22 Resume-after-power-fail state saved
                            2017-10-16 22:53:24 Printing paused
                            2017-10-16 22:55:21 Finished printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode, print time was 0h 1m
                            2017-10-16 22:55:40 Started printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode
                            2017-10-16 22:56:09 Event logging stopped
                            2017-10-16 22:56:20 HTTP client 192.168.0.117 login succeeded
                            2017-10-16 22:56:31 Started printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode
                            2017-10-16 22:58:43 Calibrated 8 factors using 13 points, deviation before 0.044 after 0.016
                            2017-10-17 00:21:05 Resume-after-power-fail state saved
                            2017-10-17 00:21:07 Printing paused
                            2017-10-17 00:21:08 Finished printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode, print time was 1h 25m
                            power up + 00:10:17 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:10:21 Time and date set
                            2017-10-17 19:11:12 HTTP client 192.168.0.117 login succeeded
                            2017-10-17 19:25:43 Calibrated 8 factors using 13 points, deviation before 1.731 after 0.005
                            2017-10-17 19:26:30 Calibrated 8 factors using 13 points, deviation before 0.042 after 0.006
                            2017-10-17 19:27:03 Event logging stopped
                            power up + 00:00:17 Time and date set
                            2017-10-17 19:27:21 HTTP client 192.168.0.117 login succeeded
                            2017-10-17 19:28:38 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
                            2017-10-17 19:32:34 Calibrated 8 factors using 13 points, deviation before 0.033 after 0.007
                            2017-10-17 19:56:00 Finished printing file 0:/gcodes/Large Kossel_50x50x50.gcode, print time was 0h 27m
                            2017-10-17 20:41:07 Event logging stopped
                            2017-10-17 20:41:17 HTTP client 192.168.0.117 login succeeded
                            2017-10-17 20:41:24 Started printing file Large Kossel_50x50x50.gcode
                            2017-10-17 20:45:57 Calibrated 8 factors using 13 points, deviation before 0.029 after 0.007
                            2017-10-17 21:05:24 Resume-after-power-fail state saved
                            2017-10-17 21:05:26 Printing paused
                            2017-10-17 21:05:27 Finished printing file Large Kossel_50x50x50.gcode, print time was 0h 24m
                            2017-10-17 23:29:23 Calibrated 8 factors using 13 points, deviation before 1.738 after 0.010
                            2017-10-17 23:32:01 Calibrated 8 factors using 16 points, deviation before 0.323 after 0.018
                            2017-10-17 23:33:23 Calibrated 9 factors using 16 points, deviation before 0.029 after 0.012
                            2017-10-17 23:33:39 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
                            2017-10-17 23:33:50 Event logging stopped
                            2017-10-17 23:34:02 HTTP client 192.168.0.117 login succeeded
                            2017-10-17 23:34:06 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
                            2017-10-17 23:35:17 Calibrated 9 factors using 16 points, deviation before 0.034 after 0.019
                            2017-10-17 23:57:41 Finished printing file 0:/gcodes/Large Kossel_50x50x50.gcode, print time was 0h 24m
                            2017-10-18 00:05:57 Error: Attempt to move the head of a Delta or SCARA printer before homing it
                            2017-10-18 00:06:01 Error: Attempt to move the head of a Delta or SCARA printer before homing it
                            2017-10-18 00:07:12 Calibrated 8 factors using 16 points, deviation before 0.037 after 0.013
                            2017-10-18 00:07:31 Started printing file Large Kossel_Uppercase_original.gcode
                            2017-10-18 00:08:35 Calibrated 8 factors using 16 points, deviation before 0.029 after 0.012
                            2017-10-18 00:10:17 Resume-after-power-fail state saved
                            2017-10-18 00:10:19 Printing paused
                            2017-10-18 00:10:24 Printing resumed
                            2017-10-18 01:34:41 Finished printing file Large Kossel_Uppercase_original.gcode, print time was 1h 27m
                            2017-10-18 07:07:01 Started printing file 0:/gcodes/Large Kossel_Bottom_case_original.gcode
                            2017-10-18 07:12:23 Calibrated 8 factors using 16 points, deviation before 0.032 after 0.011
                            2017-10-18 10:06:20 Finished printing file 0:/gcodes/Large Kossel_Bottom_case_original.gcode, print time was 2h 59m
                            2017-10-18 10:51:32 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
                            2017-10-18 10:52:27 Calibrated 8 factors using 16 points, deviation before 0.022 after 0.011
                            2017-10-18 12:44:25 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 1h 53m
                            power up + 00:03:16 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:03:20 Time and date set
                            2017-10-20 14:53:37 HTTP client 192.168.0.117 login succeeded
                            power up + 00:01:08 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:01:13 Time and date set
                            2017-10-22 09:48:52 HTTP client 192.168.0.117 login succeeded
                            2017-10-22 09:48:59 Started printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode
                            2017-10-22 09:50:54 Resume-after-power-fail state saved
                            2017-10-22 09:50:56 Printing paused
                            2017-10-22 09:50:56 Finished printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode, print time was 0h 2m
                            2017-10-22 09:51:02 Started printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode
                            2017-10-22 09:54:48 Calibrated 8 factors using 16 points, deviation before 0.036 after 0.009
                            2017-10-22 10:30:26 Finished printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode, print time was 0h 39m
                            2017-10-22 10:43:04 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-22 10:44:18 Calibrated 8 factors using 16 points, deviation before 0.046 after 0.010
                            2017-10-22 12:47:28 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
                            2017-10-22 16:35:51 Started printing file 0:/gcodes/large kossel groovemountx1 screwmountx1.gcode
                            2017-10-22 16:36:46 Calibrated 8 factors using 16 points, deviation before 0.085 after 0.007
                            2017-10-22 20:30:02 Finished printing file 0:/gcodes/large kossel groovemountx1 screwmountx1.gcode, print time was 3h 54m
                            power up + 00:02:07 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:07:45 Time and date set
                            2017-10-24 00:14:28 HTTP client 192.168.0.117 login succeeded
                            2017-10-24 00:15:11 Started printing file 0:/gcodes/Large Kossel_Rachael Nicky Sammy and Travelling ted.gcode
                            2017-10-24 00:17:59 Calibrated 8 factors using 16 points, deviation before 0.161 after 0.019
                            2017-10-24 08:43:44 Finished printing file 0:/gcodes/Large Kossel_Rachael Nicky Sammy and Travelling ted.gcode, print time was 8h 29m
                            2017-10-24 19:58:02 HTTP client 192.168.0.117 login succeeded
                            power up + 00:15:12 Time and date set
                            2017-10-25 08:55:03 HTTP client 192.168.0.117 login succeeded
                            2017-10-25 08:55:14 Started printing file 0:/gcodes/Large Kossel_sammy feeding.gcode
                            2017-10-25 08:58:03 Calibrated 8 factors using 16 points, deviation before 0.134 after 0.025
                            2017-10-25 08:59:38 Resume-after-power-fail state saved
                            2017-10-25 08:59:40 Printing paused
                            2017-10-25 08:59:44 Printing resumed
                            2017-10-25 09:50:14 Finished printing file 0:/gcodes/Large Kossel_sammy feeding.gcode, print time was 0h 55m
                            2017-10-25 11:04:09 Started printing file 0:/gcodes/Large Kossel_sammy feeding3mm border.gcode
                            2017-10-25 11:06:45 Calibrated 8 factors using 16 points, deviation before 0.132 after 0.013
                            2017-10-25 12:11:48 Finished printing file 0:/gcodes/Large Kossel_sammy feeding3mm border.gcode, print time was 1h 8m
                            2017-10-25 16:32:58 Started printing file 0:/gcodes/Large Kossel_che hi res 100mm with border.gcode
                            2017-10-25 16:35:39 Calibrated 8 factors using 16 points, deviation before 0.041 after 0.020
                            2017-10-25 16:37:13 HTTP client 192.168.0.117 login succeeded
                            2017-10-25 20:19:13 Finished printing file 0:/gcodes/Large Kossel_che hi res 100mm with border.gcode, print time was 3h 46m
                            2017-10-25 21:28:46 HTTP client 192.168.0.106 attempted login with incorrect password
                            2017-10-25 21:28:58 HTTP client 192.168.0.106 attempted login with incorrect password
                            2017-10-25 21:29:24 HTTP client 192.168.0.106 attempted login with incorrect password
                            2017-10-25 21:29:37 HTTP client 192.168.0.106 login succeeded
                            2017-10-25 22:01:34 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-25 22:04:30 Calibrated 8 factors using 16 points, deviation before 0.077 after 0.007
                            2017-10-25 22:08:04 Resume-after-power-fail state saved
                            2017-10-25 22:08:06 Printing paused
                            2017-10-25 22:08:18 Printing resumed
                            2017-10-25 22:26:19 HTTP client 192.168.0.106 login succeeded
                            2017-10-26 00:07:57 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 6m
                            2017-10-26 19:34:04 HTTP client 192.168.0.117 login succeeded
                            2017-10-26 22:54:08 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-26 22:59:24 Calibrated 8 factors using 16 points, deviation before 0.043 after 0.025
                            2017-10-27 01:02:40 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 9m
                            power up + 00:01:46 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:01:50 Time and date set
                            2017-10-27 16:57:35 HTTP client 192.168.0.117 login succeeded
                            2017-10-27 17:00:18 Started printing file Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
                            2017-10-27 17:03:11 Calibrated 8 factors using 16 points, deviation before 0.038 after 0.026
                            2017-10-27 18:55:10 Finished printing file Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 1h 55m
                            power up + 00:07:44 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:07:48 Time and date set
                            2017-10-28 12:20:11 HTTP client 192.168.0.117 login succeeded
                            2017-10-28 12:20:25 Started printing file 0:/gcodes/Large Kossel_filament sensor body and bracket.gcode
                            2017-10-28 12:21:20 Calibrated 8 factors using 16 points, deviation before 0.064 after 0.012
                            2017-10-28 15:15:07 Finished printing file 0:/gcodes/Large Kossel_filament sensor body and bracket.gcode, print time was 2h 55m
                            2017-10-28 21:02:55 Error: Attempt to move the head of a Delta or SCARA printer before homing it
                            2017-10-28 21:02:59 Error: Attempt to move the head of a Delta or SCARA printer before homing it
                            2017-10-28 21:06:22 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
                            2017-10-28 21:07:05 Calibrated 8 factors using 13 points, deviation before 0.027 after 0.005
                            2017-10-28 23:11:27 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 2h 5m
                            power up + 00:00:48 Time and date set
                            2017-10-29 07:58:53 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 07:59:08 Started printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode
                            2017-10-29 08:04:20 Calibrated 8 factors using 13 points, deviation before 0.022 after 0.005
                            2017-10-29 08:17:15 Finished printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode, print time was 0h 18m
                            2017-10-29 08:22:18 Started printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode
                            2017-10-29 08:24:29 Calibrated 8 factors using 13 points, deviation before 0.021 after 0.006
                            2017-10-29 08:41:48 Finished printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode, print time was 0h 19m
                            2017-10-29 13:28:43 HTTP client 192.168.0.117 login succeeded
                            power up + 00:02:32 Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C
                            power up + 00:02:43 Event logging stopped
                            power up + 00:04:01 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:04:12 Time and date set
                            2017-10-29 15:50:50 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 15:51:47 Event logging stopped
                            power up + 00:00:31 Time and date set
                            2017-10-29 15:52:19 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 15:52:41 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
                            2017-10-29 15:57:59 Calibrated 8 factors using 13 points, deviation before 0.039 after 0.007
                            2017-10-29 16:00:11 Error: Pop(): stack underflow!
                            2017-10-29 16:12:23 Resume-after-power-fail state saved
                            2017-10-29 16:12:26 Printing paused
                            2017-10-29 16:12:26 Finished printing file 0:/gcodes/Large Kossel_50x50x50.gcode, print time was 0h 20m
                            2017-10-29 16:13:58 Event logging stopped
                            2017-10-29 16:14:09 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 16:14:21 Started printing file Large Kossel_50x50x50.gcode
                            2017-10-29 16:16:00 Calibrated 8 factors using 13 points, deviation before 0.022 after 0.009
                            2017-10-29 16:22:35 Resume-after-power-fail state saved
                            2017-10-29 16:22:37 Printing paused
                            2017-10-29 16:22:58 Printing resumed
                            2017-10-29 16:34:07 Finished printing file Large Kossel_50x50x50.gcode, print time was 0h 19m
                            2017-10-29 22:09:41 Error: Failed to rename file or directory 0:/sys/DuetWiFiServer-1.20beta2.bin to /sys/DuetWiFiServer.bin
                            2017-10-29 22:09:58 WiFi module started
                            2017-10-29 22:10:03 Wifi module is connected to access point 3DP, IP address 192.168.0.109
                            2017-10-29 22:10:26 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 22:10:32 HTTP client 192.168.0.117 disconnected
                            2017-10-29 22:10:33 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 22:10:46 Event logging stopped
                            power up + 00:00:11 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 22:11:06 Date and time set at power up + 00:00:11
                            power up + 00:00:38 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 22:19:17 Date and time set at power up + 00:00:38
                            power up + 00:00:57 HTTP client 192.168.0.117 login succeeded
                            2017-10-29 22:26:40 Date and time set at power up + 00:00:57
                            power up + 00:00:20 HTTP client 192.168.0.117 login succeeded
                            2017-10-30 21:16:46 Date and time set at power up + 00:00:20
                            2017-10-30 21:17:11 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-30 21:22:28 Calibrated 8 factors using 13 points, deviation before 0.037 after 0.009
                            2017-10-30 23:30:20 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 13m
                            2017-10-30 23:41:54 Error: Attempt to move the head of a Delta or SCARA printer before homing it
                            2017-10-30 23:41:58 Error: Attempt to move the head of a Delta or SCARA printer before homing it
                            2017-10-30 23:50:19 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-10-30 23:51:26 Calibrated 8 factors using 13 points, deviation before 0.035 after 0.005
                            2017-10-31 01:59:13 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 9m
                            power up + 00:01:15 HTTP client 192.168.0.117 attempted login with incorrect password
                            power up + 00:01:19 HTTP client 192.168.0.117 login succeeded
                            2017-11-01 12:04:04 Date and time set at power up + 00:01:19
                            2017-11-01 12:04:10 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-11-01 12:09:40 Calibrated 8 factors using 13 points, deviation before 0.032 after 0.007
                            2017-11-01 14:17:31 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 13m
                            2017-11-01 15:01:18 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-11-01 15:04:59 Calibrated 8 factors using 13 points, deviation before 0.122 after 0.147
                            2017-11-01 15:06:45 Resume-after-power-fail state saved
                            2017-11-01 15:06:51 Printing paused
                            2017-11-01 15:07:03 Cancelled printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 0h 5m
                            2017-11-01 15:07:22 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-11-01 15:08:28 Calibrated 8 factors using 13 points, deviation before 0.262 after 0.006
                            2017-11-01 15:18:57 Resume-after-power-fail state saved
                            power up + 00:01:28 HTTP client 192.168.0.117 login succeeded
                            2017-11-01 18:38:52 Date and time set at power up + 00:01:28
                            2017-11-01 18:39:45 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
                            2017-11-01 18:45:17 Calibrated 8 factors using 13 points, deviation before 0.027 after 0.005
                            2017-11-01 18:54:28 Resume-after-power-fail state saved
                            power up + 00:00:08 Wifi module is connected to access point 3DP, IP address 192.168.0.109
                            power up + 00:29:12 HTTP client 192.168.0.117 login succeeded
                            2017-11-01 19:25:29 Date and time set at power up + 00:29:12
                              Can you confirm that you have the beta filament monitor installed and configured?
                              • DjDemonDundefined
                                DjDemonD
                                Yes I have the Duet beta filament monitor installed and calibrated. I;m using these parameters:
                                M591 D0 P3 S28.15 C3 R50 E3.0
                                  Ok, I'll test that. The pause code was modified in beta 2 so it's highly plausible that a bug has crept in.
                                  • Mikeundefined
                                    Mike
                                    Greetings! Was there by chance any mix-up between M916 and M915 codes in the latest beta (1.20b4)? My Duet doesn't really engage Stallguard stall detection upon receiving M915, but logs in failed attempts to resume print after power failure.
                                      I'll check that too.
                                      • DjDemonDundefined
                                        DjDemonD
                                        I was also getting stops on power fail pause, which I wasn't getting before. I was using quite tight parameters for Vin voltage, which I have backed off by 0.5v but it was more apparent with B4 than B1.
