New experimental firmware 1.20beta2
That's normal behaviour if you have tool change files that wait for your tools to reach temperature.
Ah, I found it! I think these must have been created by the RRF configurator. I recently used it to redo all of my config files fresh in an attempt to solve my wifi issues. Thanks David.
I think I figured out an issue. It has something to do with how the Duet powers up and initializes. If it powers and hits some race condition or if I try to home it before it finishes some part of the startup routine – which is not clear when it does, it doesn't home correctly, if I wait a couple of minutes after power up. It appears to work properly.
Is there a way to add something to end config.g to print a message to the console -- Ready or something like that? -
Additional, i'm not able to print Files with Spaces or Brackets in the Filename anymore.
They upload just fine, but they are not able to print cause they will not be found. The Filename is not the same anymore.
Uploaded a File Test Cube (0.4).gcode
Trying to print:
[[language]] M32 Test Cube (0.4).gcode Error: M32: GCode file "Test Cube .gcode" not found As you can see, eveything after ( will be cutted. Even if the Space after Cube is visible, no Special-Character can be used.
The open-bracket character starts a comment in standard CNC gcode, so filenames with brackets in them should never have been allowed - just like filenames with semicolons in them. In the 1.20release I intend to allow filenames in commands such as M32 to have double quotation marks around them, which will provide a way round this.
I've just released 1.20beta3 which fixes a number of bugs in 1.20beta2. See the whats_new file for details.
Ah, was not aware of this. Sorry if i've overseen this.
Will test beta3 now
Cheers
MoS-tekknix -
Btw the standard I am referring to is http://ws680.nist.gov/publication/get_pdf.cfm?pub_id=823374 and section 3.3.4 describes comments. We have increasing interest in using Duets to control CNC machines, so I am striving for a greater compatibility with CNC gcode, without having to use a separate build of the firmware.
Confirmed the Error is gone for config-override.g
Thanks, waiting for Final of it
But, i hope that we see always an ongoing release of Firmware(s)
Mhh, tried to do a simulation via WebIf and it stucks at 0.5%, also it is not possible to cancel the print. Need to press Emergency-Stop
Nice a new Version.
Can i simply upload the latest Version from:
Firmware Version: 1.19.2 (2017-09-01)
WiFi Server Version: 1.19.2My CoreXY Printer
I confirm there is a bug in simulation mode, in 1.20b2 and b3.
@AS-3D:
Nice a new Version.
Latest stable firmware is always at https://github.com/dc42/RepRapFirmware/releases. Read the upgrade notes first, especially the ones for upgrading from 1.18 to 1.19.
Thanks David.
@AS-3D:
Nice a new Version.
My fault, i wanna know if i can use the latest Beta Version from my current Version or do i have to use Beta 1 and after that Beta 2?
Yes, you can upload directly to the latest beta from 1.19.2.
I've just published 1.20beta4 to fix a couple more bugs.
beta 4 working for me, just completed a print no issues.
Thanks for the feedback.
Am currently using
Firmware Electronics: Duet WiFi 1.0
Firmware Version: 1.20beta4 (2017-10-28)
WiFi Server Version: 1.20beta2
Web Interface Version: 1.19.3Issue is after I began a print I got a pause reporting "filament monitor reports too little filament fed extruder 0" and a pause, but not the usual pause, no head movement away from the print, it just hung with the nozzle on the print. The DWC unresponsive and the paneldue unresponsive. I had to power cycle it to get it running again.
Going back to beta 1 for now.
UPDATE just went back to beta 1, same print, got the extruder fed too little message but a normal pause, hit resume and back printing (changes the tolerance to 40% from 30%). So I'd postulate definitely a bug from beta 1 to beta 4.
M122 as below
19:25:33M122 === Diagnostics === Used output buffers: 3 of 32 (10 max) === Platform === RepRapFirmware for Duet WiFi version 1.20beta4 running on Duet WiFi 1.0 Board ID: 08DAM-999TL-MQ4S4-6J1FG-3S46M-TPHVY Static ram used: 15320 Dynamic ram used: 97368 Recycled dynamic ram: 2000 Stack ram used: 1368 current, 4800 maximum Never used ram: 11584 Last reset 00:29:15 ago, cause: power up Last software reset reason: User, spinning module GCodes, available RAM 7224 bytes (slot 0) Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 10.6ms MCU temperature: min 30.0, current 36.7, max 36.8 Supply voltage: min 24.1, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0 Driver 0: stalled standstill Driver 1: standstill Driver 2: stalled standstill Driver 3: standstill Driver 4: standstill Date/time: 2017-11-01 19:25:32 Slowest main loop (seconds): 0.016020; fastest: 0.000035 === Move === MaxReps: 3, StepErrors: 0, FreeDm: 240, MinFreeDm 234, MaxWait: 3692473758ms, Underruns: 0, 0 Scheduled moves: 6, completed moves: 6 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heater = 0, chamber heater = 2 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.20beta2 WiFi MAC address 18:fe:34:ca:f8:7e WiFi Vcc 3.11, reset reason Turned on by main processor WiFi flash size 4194304, free heap 39152 WiFi IP address 192.168.0.109 WiFi signal strength -33dBm, reconnections 0, sleep mode modem HTTP sessions: 1 of 8 Socket states: 2 0 0 0 0 0 0 0 Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) === Filament sensors === Extruder 0 sensor: angle 1.1, ok, no calibration data event log```
2017-09-24 11:41:20 Event logging started
2017-09-24 12:20:59 Printing paused
2017-09-24 12:21:22 Printing resumed
2017-09-24 13:39:23 Finished printing file 0:/gcodes/Large Kossel_Container.gcode, print time was 2h 16m
2017-09-24 14:14:11 Started printing file 0:/gcodes/Large Kossel_Container2.gcode
2017-09-24 14:18:54 Calibrated 8 factors using 16 points, deviation before 0.038 after 0.011
2017-09-24 17:02:27 Finished printing file 0:/gcodes/Large Kossel_Container2.gcode, print time was 2h 48m
2017-09-24 19:58:02 Started printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode
2017-09-24 19:58:57 Calibrated 8 factors using 16 points, deviation before 0.041 after 0.015
2017-09-24 20:29:34 Finished printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode, print time was 0h 32m
2017-09-24 21:01:20 Started printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode
2017-09-24 21:05:48 Calibrated 8 factors using 16 points, deviation before 0.048 after 0.021
2017-09-24 21:38:37 Finished printing file 0:/gcodes/Large Kossel_desk_roller_original.gcode, print time was 0h 37m
power up + 00:00:02 Event logging started
power up + 00:00:02 Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 448C.
power up + 00:00:02 Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 336C.
power up + 00:00:02 Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 734C.
power up + 00:00:02 WiFi module started
power up + 00:00:09 Wifi module is connected to access point 3DP, IP address 192.168.0.109
power up + 00:02:42 HTTP client 192.168.0.117 attempted login with incorrect password
2017-09-25 20:39:44 HTTP client 192.168.0.117 login succeeded
2017-09-25 20:49:38 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-09-25 20:50:40 Calibrated 8 factors using 16 points, deviation before 0.042 after 0.016
2017-09-25 20:56:17 Warning: Tool 98 was not driven because its heater temperatures were not high enough or it has a heater fault
2017-09-25 20:56:21 Warning: Tool 98 was not driven because its heater temperatures were not high enough or it has a heater fault
2017-09-25 20:56:21 Warning: Tool 99 was not driven because its heater temperatures were not high enough or it has a heater fault
2017-09-25 20:56:21 Error: Attempting to extrude with no tool selected.
2017-09-25 20:56:25 Error: Attempting to extrude with no tool selected.
2017-09-25 20:56:29 Error: Attempting to extrude with no tool selected.
2017-09-25 20:56:33 Error: Attempting to extrude with no tool selected.
2017-09-25 20:56:37 Error: Attempting to extrude with no tool selected.
2017-09-25 20:56:41 Error: Attempting to extrude with no tool selected.
2017-09-25 20:56:45 Error: Attempting to extrude with no tool selected.
2017-09-25 22:38:07 Event logging stopped
2017-09-25 22:38:18 HTTP client 192.168.0.117 login succeeded
2017-09-25 23:39:14 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-09-25 23:44:05 Calibrated 8 factors using 16 points, deviation before 0.025 after 0.013
2017-09-26 00:45:07 HTTP client 192.168.0.106 attempted login with incorrect password
2017-09-26 00:45:22 HTTP client 192.168.0.106 login succeeded
2017-09-26 01:45:27 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 6m
2017-09-26 07:00:56 HTTP client 192.168.0.106 login succeeded
2017-09-26 19:12:20 HTTP client 192.168.0.117 login succeeded
2017-09-26 19:13:52 Event logging stopped
power up + 00:00:09 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:01:25 HTTP client 192.168.0.117 attempted login with incorrect password
2017-09-26 19:15:34 HTTP client 192.168.0.117 login succeeded
2017-09-26 19:15:41 Event logging stopped
2017-09-26 19:16:01 HTTP client 192.168.0.117 login succeeded
2017-09-26 19:16:57 Started printing file 0:/gcodes/SMARTRAP_kostka20x20_with 8mm hole.gcode
2017-09-26 19:22:28 Calibrated 8 factors using 16 points, deviation before 0.025 after 0.015
2017-09-26 19:30:30 Finished printing file 0:/gcodes/SMARTRAP_kostka20x20_with 8mm hole.gcode, print time was 0h 14m
2017-09-26 19:38:33 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
2017-09-26 19:41:08 Calibrated 8 factors using 16 points, deviation before 0.042 after 0.012
2017-09-26 23:21:08 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 3h 43m
power up + 00:01:39 HTTP client 192.168.0.117 attempted login with incorrect password
2017-09-27 22:33:36 HTTP client 192.168.0.117 login succeeded
2017-09-27 22:39:15 Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 714C.
2017-09-27 22:39:15 Auto tune heater 1 completed in 294 sec
Use M307 H1 to see the result, or M500 to save the result in config-override.g
power up + 00:00:12 HTTP client 192.168.0.117 attempted login with incorrect password
2017-09-28 14:13:42 HTTP client 192.168.0.117 login succeeded
2017-09-28 14:27:21 Started printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode
2017-09-28 14:28:00 Resume-after-power-fail state saved
2017-09-28 14:28:02 Printing paused
2017-09-28 14:28:03 Finished printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode, print time was 0h 1m
2017-09-28 14:28:09 Started printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode
2017-09-28 14:30:25 Calibrated 8 factors using 16 points, deviation before 0.075 after 0.017
2017-09-28 14:37:50 Resume-after-power-fail state saved
2017-09-28 14:37:51 Printing paused
2017-09-28 14:38:14 Printing resumed
2017-09-28 14:38:27 Resume-after-power-fail state saved
2017-09-28 14:38:29 Printing paused
2017-09-28 14:38:50 Printing resumed
2017-09-28 14:54:01 Finished printing file 0:/gcodes/Large Kossel_Spinning_Heart_Keyring_outside.gcode, print time was 0h 25m
2017-09-28 22:37:28 HTTP client 192.168.0.106 attempted login with incorrect password
power up + 00:03:35 HTTP client 192.168.0.117 attempted login with incorrect password
2017-09-29 13:48:38 HTTP client 192.168.0.117 login succeeded
2017-09-29 14:00:16 Started printing file 0:/gcodes/Large Kossel_shower holder backing.gcode
2017-09-29 14:01:54 Calibrated 8 factors using 16 points, deviation before 0.028 after 0.020
2017-09-29 15:52:10 Finished printing file 0:/gcodes/Large Kossel_shower holder backing.gcode, print time was 1h 52m
power up + 00:00:55 HTTP client 192.168.0.117 attempted login with incorrect password
2017-09-30 09:50:54 HTTP client 192.168.0.117 login succeeded
2017-09-30 10:14:08 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-09-30 10:15:14 Calibrated 8 factors using 16 points, deviation before 0.034 after 0.015
2017-09-30 10:29:05 HTTP client 192.168.0.106 attempted login with incorrect password
2017-09-30 10:29:12 HTTP client 192.168.0.106 login succeeded
2017-09-30 11:06:07 HTTP client 192.168.0.117 login succeeded
2017-09-30 11:40:51 HTTP client 192.168.0.117 login succeeded
2017-09-30 11:41:37 Event logging stopped
2017-09-30 11:41:46 HTTP client 192.168.0.117 login succeeded
2017-09-30 11:43:25 HTTP client 192.168.0.117 login succeeded
power up + 00:00:07 Wifi module is connected to access point 3DP, IP address 192.168.0.109
2017-09-30 11:54:13 HTTP client 192.168.0.117 login succeeded
2017-09-30 11:54:22 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-09-30 11:55:35 Event logging stopped
2017-09-30 11:55:45 HTTP client 192.168.0.117 login succeeded
2017-09-30 11:55:51 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-09-30 12:00:01 Calibrated 8 factors using 16 points, deviation before 0.032 after 0.014
2017-09-30 13:47:34 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 1h 52m
2017-09-30 14:35:12 HTTP client 192.168.0.117 login succeeded
2017-09-30 14:50:34 Started printing file 0:/gcodes/Large Kossel_50mm exhaust fan shroud and diverter for enclosure.gcode
2017-09-30 14:51:49 Calibrated 8 factors using 16 points, deviation before 0.118 after 0.022
2017-09-30 16:49:15 Finished printing file 0:/gcodes/Large Kossel_50mm exhaust fan shroud and diverter for enclosure.gcode, print time was 1h 59m
power up + 00:00:10 Wifi module is connected to access point 3DP, IP address 192.168.0.109
2017-09-30 17:43:14 HTTP client 192.168.0.117 login succeeded
2017-09-30 22:46:05 Started printing file 0:/gcodes/Large Kossel_Container.gcode
2017-09-30 22:47:07 Calibrated 8 factors using 16 points, deviation before 0.104 after 0.018
2017-10-01 03:00:38 Finished printing file 0:/gcodes/Large Kossel_Container.gcode, print time was 4h 15m
2017-10-01 10:40:20 HTTP client 192.168.0.117 login succeeded
power up + 00:02:14 HTTP client 192.168.0.117 attempted login with incorrect password
2017-10-02 21:52:16 HTTP client 192.168.0.117 login succeeded
2017-10-02 21:54:07 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 1.8°C/sec
2017-10-02 22:01:19 Event logging stopped
2017-10-02 22:01:32 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:03:16 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:04:23 Event logging stopped
2017-10-02 22:04:33 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:04:36 HTTP client 192.168.0.117 disconnected
2017-10-02 22:04:36 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:09:13 Event logging stopped
2017-10-02 22:13:39 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:14:20 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 1.8°C/sec
2017-10-02 22:19:52 Event logging stopped
2017-10-02 22:20:03 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:22:01 Event logging stopped
2017-10-02 22:22:13 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:22:50 Event logging stopped
2017-10-02 22:23:04 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:24:55 Event logging stopped
2017-10-02 22:25:04 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:26:08 Event logging stopped
2017-10-02 22:26:40 HTTP client 192.168.0.117 login succeeded
2017-10-02 22:39:53 Started printing file 0:/gcodes/Large Kossel_SSR cover Revised no sides deeper lettering.gcode
2017-10-02 22:40:54 Calibrated 8 factors using 16 points, deviation before 0.846 after 0.021
2017-10-02 23:08:15 Resume-after-power-fail state saved
2017-10-02 23:08:17 Printing paused
2017-10-02 23:10:42 Printing resumed
2017-10-02 23:10:47 Resume-after-power-fail state saved
2017-10-02 23:10:49 Printing paused
2017-10-02 23:10:53 Printing resumed
2017-10-03 00:38:38 Finished printing file 0:/gcodes/Large Kossel_SSR cover Revised no sides deeper lettering.gcode, print time was 1h 56m
2017-10-03 00:51:24 Started printing file 0:/gcodes/Large Kossel_desk_roller_v2_original.gcode
2017-10-03 00:52:41 Calibrated 8 factors using 16 points, deviation before 0.062 after 0.017
2017-10-03 03:23:24 Finished printing file 0:/gcodes/Large Kossel_desk_roller_v2_original.gcode, print time was 2h 32m
2017-10-03 21:31:48 HTTP client 192.168.0.117 login succeeded
power up + 00:01:55 HTTP client 192.168.0.117 attempted login with incorrect password
2017-10-03 22:28:15 HTTP client 192.168.0.117 login succeeded
2017-10-03 22:34:02 Auto tune heater 2 completed in 276 sec
Use M307 H2 to see the result, or M500 to save the result in config-override.g
2017-10-03 22:40:15 Event logging stopped
2017-10-03 22:40:26 HTTP client 192.168.0.117 login succeeded
2017-10-03 23:24:29 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 0.3°C/sec
2017-10-03 23:24:42 Event logging stopped
2017-10-03 23:24:53 HTTP client 192.168.0.117 login succeeded
2017-10-03 23:25:22 Error: Heating fault on heater 2, temperature rising much more slowly than the expected 0.4°C/sec
2017-10-03 23:32:59 Event logging stopped
2017-10-03 23:33:10 HTTP client 192.168.0.117 login succeeded
2017-10-03 23:37:49 Event logging stopped
2017-10-03 23:38:00 HTTP client 192.168.0.117 login succeeded
power up + 00:03:51 HTTP client 192.168.0.117 attempted login with incorrect password
2017-10-04 10:10:42 HTTP client 192.168.0.117 login succeeded
2017-10-04 10:11:34 Event logging stopped
2017-10-04 10:11:46 HTTP client 192.168.0.117 login succeeded
2017-10-04 10:26:43 Started printing file 0:/gcodes/Large Kossel_warpinator5000.gcode
2017-10-04 10:31:43 Calibrated 8 factors using 16 points, deviation before 0.186 after 0.010
2017-10-04 10:31:49 Resume-after-power-fail state saved
2017-10-04 10:31:51 Printing paused
2017-10-04 10:32:06 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
2017-10-04 10:32:07 Printing resumed
2017-10-04 11:26:38 Resume-after-power-fail state saved
2017-10-04 11:26:43 Printing paused
2017-10-04 11:26:51 Printing resumed
2017-10-04 11:29:32 Finished printing file 0:/gcodes/Large Kossel_warpinator5000.gcode, print time was 1h 2m
2017-10-04 11:49:11 Event logging stopped
2017-10-04 11:49:26 HTTP client 192.168.0.117 login succeeded
power up + 00:02:58 HTTP client 192.168.0.117 attempted login with incorrect password
2017-10-04 22:11:04 HTTP client 192.168.0.117 login succeeded
2017-10-04 22:12:54 Event logging stopped
power up + 00:00:11 Time and date set
2017-10-04 22:13:13 HTTP client 192.168.0.117 login succeeded
2017-10-04 22:39:01 Started printing file 0:/gcodes/Large Kossel_Titan_Mount_Bracket_4_Spacer.gcode
2017-10-04 22:40:02 Calibrated 8 factors using 16 points, deviation before 0.192 after 0.014
2017-10-04 22:48:26 HTTP client 192.168.0.117 login succeeded
2017-10-04 22:50:28 Error: Heating fault on heater 2, temperature excursion exceeded 15.0°C
2017-10-04 22:50:45 Event logging stopped
power up + 00:00:10 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:00:16 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:00:18 Time and date set
2017-10-04 22:51:05 HTTP client 192.168.0.117 login succeeded
2017-10-04 22:52:26 Started printing file Large Kossel_Titan_Mount_Bracket_4_Spacer.gcode
2017-10-04 22:53:19 Calibrated 8 factors using 16 points, deviation before 0.183 after 0.016
2017-10-05 00:48:28 Finished printing file Large Kossel_Titan_Mount_Bracket_4_Spacer.gcode, print time was 1h 56m
power up + 00:02:45 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:02:48 Time and date set
2017-10-05 14:24:58 HTTP client 192.168.0.117 login succeeded
2017-10-05 14:35:10 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-05 14:36:03 Calibrated 8 factors using 16 points, deviation before 0.209 after 0.016
2017-10-05 16:20:28 Resume-after-power-fail state saved
2017-10-05 16:20:30 Printing paused
2017-10-05 16:20:31 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 1h 45m
2017-10-05 16:30:37 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-05 16:33:42 Calibrated 8 factors using 16 points, deviation before 0.064 after 0.012
2017-10-05 18:35:01 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
2017-10-05 21:49:50 Started printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode
2017-10-05 21:50:09 Resume-after-power-fail state saved
2017-10-05 21:50:09 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
2017-10-05 21:50:10 Printing paused
2017-10-05 21:50:10 Finished printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode, print time was 0h 0m
2017-10-05 21:51:17 Started printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode
2017-10-05 21:56:17 Calibrated 8 factors using 13 points, deviation before 0.041 after 0.006
2017-10-05 22:54:24 Finished printing file 0:/gcodes/Large Kossel_Terra_Scorcher_A5_original.gcode, print time was 1h 3m
power up + 00:19:55 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:20:19 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:20:22 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:20:32 Time and date set
2017-10-06 14:31:04 HTTP client 192.168.0.117 login succeeded
2017-10-06 14:37:11 Event logging stopped
power up + 00:00:09 Time and date set
2017-10-06 14:37:22 HTTP client 192.168.0.117 login succeeded
2017-10-06 14:38:56 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
2017-10-06 14:40:02 Resume-after-power-fail state saved
2017-10-06 14:40:04 Printing paused
2017-10-06 14:40:32 Warning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
2017-10-06 14:40:33 Printing resumed
2017-10-06 14:44:05 Calibrated 8 factors using 13 points, deviation before 0.209 after 0.004
2017-10-06 14:49:00 Resume-after-power-fail state saved
2017-10-06 14:49:02 Printing paused
2017-10-06 14:49:03 Finished printing file 0:/gcodes/Large Kossel_kostka20x20.gcode, print time was 0h 10m
2017-10-06 14:49:25 Event logging stopped
power up + 00:00:14 Time and date set
2017-10-06 14:49:40 HTTP client 192.168.0.117 login succeeded
2017-10-06 14:49:43 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
2017-10-06 14:51:05 Calibrated 8 factors using 13 points, deviation before 0.019 after 0.007
power up + 00:00:22 Time and date set
2017-10-06 14:56:08 HTTP client 192.168.0.117 login succeeded
2017-10-06 14:57:15 Started printing file 0:/gcodes/resurrect.g
2017-10-06 14:59:30 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
2017-10-06 14:59:51 Resume-after-power-fail state saved
2017-10-06 14:59:53 Printing paused
2017-10-06 14:59:54 Finished printing file 0:/gcodes/Large Kossel_kostka20x20.gcode, print time was 0h 0m
power up + 00:04:34 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:04:39 Time and date set
2017-10-08 10:23:01 HTTP client 192.168.0.117 login succeeded
2017-10-08 10:23:54 Started printing file 0:/gcodes/Large Kossel_x183 leg model.gcode
2017-10-08 10:24:37 Calibrated 8 factors using 13 points, deviation before 0.043 after 0.004
2017-10-08 10:54:50 Finished printing file 0:/gcodes/Large Kossel_x183 leg model.gcode, print time was 0h 31m
2017-10-08 10:58:00 Started printing file 0:/gcodes/Large Kossel_x183 leg model.gcode
2017-10-08 10:59:12 Resume-after-power-fail state saved
2017-10-08 10:59:13 Printing paused
2017-10-08 11:01:52 Finished printing file 0:/gcodes/Large Kossel_x183 leg model.gcode, print time was 0h 1m
2017-10-08 11:01:58 Started printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode
2017-10-08 11:02:52 Calibrated 8 factors using 13 points, deviation before 0.049 after 0.006
2017-10-08 11:13:16 Resume-after-power-fail state saved
2017-10-08 11:13:18 Printing paused
2017-10-08 11:13:19 Finished printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode, print time was 0h 11m
2017-10-08 11:14:35 Started printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode
2017-10-08 11:15:22 Calibrated 8 factors using 13 points, deviation before 0.020 after 0.008
2017-10-08 11:42:52 Finished printing file 0:/gcodes/Large Kossel_x183 leg model2.gcode, print time was 0h 28m
2017-10-08 11:49:35 Started printing file 0:/gcodes/Large Kossel_x183 leg support for 6mm carbon tube 1.0.gcode
2017-10-08 11:51:57 Calibrated 8 factors using 13 points, deviation before 0.045 after 0.007
2017-10-08 13:39:01 Finished printing file 0:/gcodes/Large Kossel_x183 leg support for 6mm carbon tube 1.0.gcode, print time was 1h 49m
2017-10-08 16:18:35 Event logging stopped
2017-10-08 16:18:47 HTTP client 192.168.0.117 login succeeded
2017-10-08 16:37:30 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-08 16:38:12 Calibrated 8 factors using 13 points, deviation before 0.083 after 0.008
2017-10-08 18:39:36 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 2m
power up + 00:00:13 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:00:16 Time and date set
2017-10-10 18:49:12 HTTP client 192.168.0.117 login succeeded
2017-10-10 18:55:23 Calibrated 8 factors using 13 points, deviation before 0.034 after 0.012
2017-10-10 19:02:26 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-10 19:03:17 Calibrated 8 factors using 13 points, deviation before 0.037 after 0.016
2017-10-10 21:06:31 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
2017-10-10 21:40:26 HTTP client 192.168.0.117 login succeeded
2017-10-10 21:54:38 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
2017-10-10 21:56:29 Calibrated 8 factors using 13 points, deviation before 0.058 after 0.008
2017-10-10 23:48:21 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 1h 54m
power up + 00:04:15 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:04:25 Time and date set
2017-10-12 00:07:03 HTTP client 192.168.0.117 login succeeded
2017-10-12 00:07:58 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-12 00:12:58 Calibrated 8 factors using 13 points, deviation before 0.025 after 0.003
2017-10-12 02:16:09 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 8m
power up + 00:06:48 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:06:54 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:06:57 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:07:00 Time and date set
2017-10-12 18:59:21 HTTP client 192.168.0.117 login succeeded
2017-10-12 19:09:00 HTTP client 192.168.0.117 login succeeded
2017-10-12 19:09:04 HTTP client 192.168.0.117 login succeeded
2017-10-12 19:09:15 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-12 19:10:05 Calibrated 8 factors using 13 points, deviation before 0.159 after 0.016
2017-10-12 21:13:46 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 5m
2017-10-12 21:40:05 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-12 21:40:48 Calibrated 8 factors using 13 points, deviation before 0.157 after 0.009
2017-10-12 23:43:46 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
power up + 00:22:22 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:22:26 Time and date set
2017-10-15 10:40:19 HTTP client 192.168.0.117 login succeeded
2017-10-15 10:42:20 Started printing file 0:/gcodes/Large Kossel_extruder-body.gcode
2017-10-15 10:43:58 Calibrated 8 factors using 16 points, deviation before 0.242 after 0.015
2017-10-15 16:17:16 Finished printing file 0:/gcodes/Large Kossel_extruder-body.gcode, print time was 5h 35m
power up + 00:01:59 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:02:02 Time and date set
2017-10-15 20:02:19 HTTP client 192.168.0.117 login succeeded
2017-10-15 20:02:28 Started printing file 0:/gcodes/Large Kossel_Bearing_block1.gcode
2017-10-15 20:05:03 Calibrated 8 factors using 16 points, deviation before 0.028 after 0.012
2017-10-15 21:17:56 Finished printing file 0:/gcodes/Large Kossel_Bearing_block1.gcode, print time was 1h 15m
2017-10-15 21:23:25 Started printing file 0:/gcodes/Large Kossel_Bearing_block1_SKMOD.gcode
2017-10-15 21:24:59 Calibrated 8 factors using 16 points, deviation before 0.042 after 0.014
2017-10-15 22:10:20 Finished printing file 0:/gcodes/Large Kossel_Bearing_block1_SKMOD.gcode, print time was 0h 47m
2017-10-15 22:19:25 Error: Temperature reading fault on heater 1: sensor open circuit
2017-10-15 22:54:27 Event logging stopped
2017-10-15 22:54:39 HTTP client 192.168.0.117 login succeeded
2017-10-15 22:57:08 Event logging stopped
power up + 00:00:10 Time and date set
2017-10-15 22:57:21 HTTP client 192.168.0.117 login succeeded
2017-10-15 23:02:06 Started printing file 0:/gcodes/Large Kossel_kostka20x20.gcode
2017-10-15 23:03:24 Calibrated 8 factors using 16 points, deviation before 0.028 after 0.020
2017-10-15 23:19:51 Finished printing file 0:/gcodes/Large Kossel_kostka20x20.gcode, print time was 0h 18m
2017-10-15 23:20:31 Event logging stopped
2017-10-15 23:20:43 HTTP client 192.168.0.117 login succeeded
power up + 00:15:08 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:22:17 Time and date set
2017-10-16 22:43:30 HTTP client 192.168.0.117 login succeeded
2017-10-16 22:52:06 Calibrated 8 factors using 13 points, deviation before 0.047 after 0.005
2017-10-16 22:52:25 Started printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode
2017-10-16 22:53:16 Calibrated 8 factors using 13 points, deviation before 0.030 after 0.008
2017-10-16 22:53:22 Resume-after-power-fail state saved
2017-10-16 22:53:24 Printing paused
2017-10-16 22:55:21 Finished printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode, print time was 0h 1m
2017-10-16 22:55:40 Started printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode
2017-10-16 22:56:09 Event logging stopped
2017-10-16 22:56:20 HTTP client 192.168.0.117 login succeeded
2017-10-16 22:56:31 Started printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode
2017-10-16 22:58:43 Calibrated 8 factors using 13 points, deviation before 0.044 after 0.016
2017-10-17 00:21:05 Resume-after-power-fail state saved
2017-10-17 00:21:07 Printing paused
2017-10-17 00:21:08 Finished printing file 0:/gcodes/Large Kossel_Uppercase_original.gcode, print time was 1h 25m
power up + 00:10:17 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:10:21 Time and date set
2017-10-17 19:11:12 HTTP client 192.168.0.117 login succeeded
2017-10-17 19:25:43 Calibrated 8 factors using 13 points, deviation before 1.731 after 0.005
2017-10-17 19:26:30 Calibrated 8 factors using 13 points, deviation before 0.042 after 0.006
2017-10-17 19:27:03 Event logging stopped
power up + 00:00:17 Time and date set
2017-10-17 19:27:21 HTTP client 192.168.0.117 login succeeded
2017-10-17 19:28:38 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
2017-10-17 19:32:34 Calibrated 8 factors using 13 points, deviation before 0.033 after 0.007
2017-10-17 19:56:00 Finished printing file 0:/gcodes/Large Kossel_50x50x50.gcode, print time was 0h 27m
2017-10-17 20:41:07 Event logging stopped
2017-10-17 20:41:17 HTTP client 192.168.0.117 login succeeded
2017-10-17 20:41:24 Started printing file Large Kossel_50x50x50.gcode
2017-10-17 20:45:57 Calibrated 8 factors using 13 points, deviation before 0.029 after 0.007
2017-10-17 21:05:24 Resume-after-power-fail state saved
2017-10-17 21:05:26 Printing paused
2017-10-17 21:05:27 Finished printing file Large Kossel_50x50x50.gcode, print time was 0h 24m
2017-10-17 23:29:23 Calibrated 8 factors using 13 points, deviation before 1.738 after 0.010
2017-10-17 23:32:01 Calibrated 8 factors using 16 points, deviation before 0.323 after 0.018
2017-10-17 23:33:23 Calibrated 9 factors using 16 points, deviation before 0.029 after 0.012
2017-10-17 23:33:39 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
2017-10-17 23:33:50 Event logging stopped
2017-10-17 23:34:02 HTTP client 192.168.0.117 login succeeded
2017-10-17 23:34:06 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
2017-10-17 23:35:17 Calibrated 9 factors using 16 points, deviation before 0.034 after 0.019
2017-10-17 23:57:41 Finished printing file 0:/gcodes/Large Kossel_50x50x50.gcode, print time was 0h 24m
2017-10-18 00:05:57 Error: Attempt to move the head of a Delta or SCARA printer before homing it
2017-10-18 00:06:01 Error: Attempt to move the head of a Delta or SCARA printer before homing it
2017-10-18 00:07:12 Calibrated 8 factors using 16 points, deviation before 0.037 after 0.013
2017-10-18 00:07:31 Started printing file Large Kossel_Uppercase_original.gcode
2017-10-18 00:08:35 Calibrated 8 factors using 16 points, deviation before 0.029 after 0.012
2017-10-18 00:10:17 Resume-after-power-fail state saved
2017-10-18 00:10:19 Printing paused
2017-10-18 00:10:24 Printing resumed
2017-10-18 01:34:41 Finished printing file Large Kossel_Uppercase_original.gcode, print time was 1h 27m
2017-10-18 07:07:01 Started printing file 0:/gcodes/Large Kossel_Bottom_case_original.gcode
2017-10-18 07:12:23 Calibrated 8 factors using 16 points, deviation before 0.032 after 0.011
2017-10-18 10:06:20 Finished printing file 0:/gcodes/Large Kossel_Bottom_case_original.gcode, print time was 2h 59m
2017-10-18 10:51:32 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
2017-10-18 10:52:27 Calibrated 8 factors using 16 points, deviation before 0.022 after 0.011
2017-10-18 12:44:25 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 1h 53m
power up + 00:03:16 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:03:20 Time and date set
2017-10-20 14:53:37 HTTP client 192.168.0.117 login succeeded
power up + 00:01:08 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:01:13 Time and date set
2017-10-22 09:48:52 HTTP client 192.168.0.117 login succeeded
2017-10-22 09:48:59 Started printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode
2017-10-22 09:50:54 Resume-after-power-fail state saved
2017-10-22 09:50:56 Printing paused
2017-10-22 09:50:56 Finished printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode, print time was 0h 2m
2017-10-22 09:51:02 Started printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode
2017-10-22 09:54:48 Calibrated 8 factors using 16 points, deviation before 0.036 after 0.009
2017-10-22 10:30:26 Finished printing file 0:/gcodes/Large Kossel_SQ-11 Camera mount.gcode, print time was 0h 39m
2017-10-22 10:43:04 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-22 10:44:18 Calibrated 8 factors using 16 points, deviation before 0.046 after 0.010
2017-10-22 12:47:28 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 4m
2017-10-22 16:35:51 Started printing file 0:/gcodes/large kossel groovemountx1 screwmountx1.gcode
2017-10-22 16:36:46 Calibrated 8 factors using 16 points, deviation before 0.085 after 0.007
2017-10-22 20:30:02 Finished printing file 0:/gcodes/large kossel groovemountx1 screwmountx1.gcode, print time was 3h 54m
power up + 00:02:07 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:07:45 Time and date set
2017-10-24 00:14:28 HTTP client 192.168.0.117 login succeeded
2017-10-24 00:15:11 Started printing file 0:/gcodes/Large Kossel_Rachael Nicky Sammy and Travelling ted.gcode
2017-10-24 00:17:59 Calibrated 8 factors using 16 points, deviation before 0.161 after 0.019
2017-10-24 08:43:44 Finished printing file 0:/gcodes/Large Kossel_Rachael Nicky Sammy and Travelling ted.gcode, print time was 8h 29m
2017-10-24 19:58:02 HTTP client 192.168.0.117 login succeeded
power up + 00:15:12 Time and date set
2017-10-25 08:55:03 HTTP client 192.168.0.117 login succeeded
2017-10-25 08:55:14 Started printing file 0:/gcodes/Large Kossel_sammy feeding.gcode
2017-10-25 08:58:03 Calibrated 8 factors using 16 points, deviation before 0.134 after 0.025
2017-10-25 08:59:38 Resume-after-power-fail state saved
2017-10-25 08:59:40 Printing paused
2017-10-25 08:59:44 Printing resumed
2017-10-25 09:50:14 Finished printing file 0:/gcodes/Large Kossel_sammy feeding.gcode, print time was 0h 55m
2017-10-25 11:04:09 Started printing file 0:/gcodes/Large Kossel_sammy feeding3mm border.gcode
2017-10-25 11:06:45 Calibrated 8 factors using 16 points, deviation before 0.132 after 0.013
2017-10-25 12:11:48 Finished printing file 0:/gcodes/Large Kossel_sammy feeding3mm border.gcode, print time was 1h 8m
2017-10-25 16:32:58 Started printing file 0:/gcodes/Large Kossel_che hi res 100mm with border.gcode
2017-10-25 16:35:39 Calibrated 8 factors using 16 points, deviation before 0.041 after 0.020
2017-10-25 16:37:13 HTTP client 192.168.0.117 login succeeded
2017-10-25 20:19:13 Finished printing file 0:/gcodes/Large Kossel_che hi res 100mm with border.gcode, print time was 3h 46m
2017-10-25 21:28:46 HTTP client 192.168.0.106 attempted login with incorrect password
2017-10-25 21:28:58 HTTP client 192.168.0.106 attempted login with incorrect password
2017-10-25 21:29:24 HTTP client 192.168.0.106 attempted login with incorrect password
2017-10-25 21:29:37 HTTP client 192.168.0.106 login succeeded
2017-10-25 22:01:34 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-25 22:04:30 Calibrated 8 factors using 16 points, deviation before 0.077 after 0.007
2017-10-25 22:08:04 Resume-after-power-fail state saved
2017-10-25 22:08:06 Printing paused
2017-10-25 22:08:18 Printing resumed
2017-10-25 22:26:19 HTTP client 192.168.0.106 login succeeded
2017-10-26 00:07:57 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 6m
2017-10-26 19:34:04 HTTP client 192.168.0.117 login succeeded
2017-10-26 22:54:08 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-26 22:59:24 Calibrated 8 factors using 16 points, deviation before 0.043 after 0.025
2017-10-27 01:02:40 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 9m
power up + 00:01:46 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:01:50 Time and date set
2017-10-27 16:57:35 HTTP client 192.168.0.117 login succeeded
2017-10-27 17:00:18 Started printing file Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
2017-10-27 17:03:11 Calibrated 8 factors using 16 points, deviation before 0.038 after 0.026
2017-10-27 18:55:10 Finished printing file Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 1h 55m
power up + 00:07:44 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:07:48 Time and date set
2017-10-28 12:20:11 HTTP client 192.168.0.117 login succeeded
2017-10-28 12:20:25 Started printing file 0:/gcodes/Large Kossel_filament sensor body and bracket.gcode
2017-10-28 12:21:20 Calibrated 8 factors using 16 points, deviation before 0.064 after 0.012
2017-10-28 15:15:07 Finished printing file 0:/gcodes/Large Kossel_filament sensor body and bracket.gcode, print time was 2h 55m
2017-10-28 21:02:55 Error: Attempt to move the head of a Delta or SCARA printer before homing it
2017-10-28 21:02:59 Error: Attempt to move the head of a Delta or SCARA printer before homing it
2017-10-28 21:06:22 Started printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode
2017-10-28 21:07:05 Calibrated 8 factors using 13 points, deviation before 0.027 after 0.005
2017-10-28 23:11:27 Finished printing file 0:/gcodes/Large Kossel_Piezo 20 V1.12 Screwmount 25mm.gcode, print time was 2h 5m
power up + 00:00:48 Time and date set
2017-10-29 07:58:53 HTTP client 192.168.0.117 login succeeded
2017-10-29 07:59:08 Started printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode
2017-10-29 08:04:20 Calibrated 8 factors using 13 points, deviation before 0.022 after 0.005
2017-10-29 08:17:15 Finished printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode, print time was 0h 18m
2017-10-29 08:22:18 Started printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode
2017-10-29 08:24:29 Calibrated 8 factors using 13 points, deviation before 0.021 after 0.006
2017-10-29 08:41:48 Finished printing file 0:/gcodes/Large Kossel_hanging bracket for titan.gcode, print time was 0h 19m
2017-10-29 13:28:43 HTTP client 192.168.0.117 login succeeded
power up + 00:02:32 Error: Heating fault on heater 1, temperature excursion exceeded 15.0°C
power up + 00:02:43 Event logging stopped
power up + 00:04:01 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:04:12 Time and date set
2017-10-29 15:50:50 HTTP client 192.168.0.117 login succeeded
2017-10-29 15:51:47 Event logging stopped
power up + 00:00:31 Time and date set
2017-10-29 15:52:19 HTTP client 192.168.0.117 login succeeded
2017-10-29 15:52:41 Started printing file 0:/gcodes/Large Kossel_50x50x50.gcode
2017-10-29 15:57:59 Calibrated 8 factors using 13 points, deviation before 0.039 after 0.007
2017-10-29 16:00:11 Error: Pop(): stack underflow!
2017-10-29 16:12:23 Resume-after-power-fail state saved
2017-10-29 16:12:26 Printing paused
2017-10-29 16:12:26 Finished printing file 0:/gcodes/Large Kossel_50x50x50.gcode, print time was 0h 20m
2017-10-29 16:13:58 Event logging stopped
2017-10-29 16:14:09 HTTP client 192.168.0.117 login succeeded
2017-10-29 16:14:21 Started printing file Large Kossel_50x50x50.gcode
2017-10-29 16:16:00 Calibrated 8 factors using 13 points, deviation before 0.022 after 0.009
2017-10-29 16:22:35 Resume-after-power-fail state saved
2017-10-29 16:22:37 Printing paused
2017-10-29 16:22:58 Printing resumed
2017-10-29 16:34:07 Finished printing file Large Kossel_50x50x50.gcode, print time was 0h 19m
2017-10-29 22:09:41 Error: Failed to rename file or directory 0:/sys/DuetWiFiServer-1.20beta2.bin to /sys/DuetWiFiServer.bin
2017-10-29 22:09:58 WiFi module started
2017-10-29 22:10:03 Wifi module is connected to access point 3DP, IP address 192.168.0.109
2017-10-29 22:10:26 HTTP client 192.168.0.117 login succeeded
2017-10-29 22:10:32 HTTP client 192.168.0.117 disconnected
2017-10-29 22:10:33 HTTP client 192.168.0.117 login succeeded
2017-10-29 22:10:46 Event logging stopped
power up + 00:00:11 HTTP client 192.168.0.117 login succeeded
2017-10-29 22:11:06 Date and time set at power up + 00:00:11
power up + 00:00:38 HTTP client 192.168.0.117 login succeeded
2017-10-29 22:19:17 Date and time set at power up + 00:00:38
power up + 00:00:57 HTTP client 192.168.0.117 login succeeded
2017-10-29 22:26:40 Date and time set at power up + 00:00:57
power up + 00:00:20 HTTP client 192.168.0.117 login succeeded
2017-10-30 21:16:46 Date and time set at power up + 00:00:20
2017-10-30 21:17:11 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-30 21:22:28 Calibrated 8 factors using 13 points, deviation before 0.037 after 0.009
2017-10-30 23:30:20 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 13m
2017-10-30 23:41:54 Error: Attempt to move the head of a Delta or SCARA printer before homing it
2017-10-30 23:41:58 Error: Attempt to move the head of a Delta or SCARA printer before homing it
2017-10-30 23:50:19 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-10-30 23:51:26 Calibrated 8 factors using 13 points, deviation before 0.035 after 0.005
2017-10-31 01:59:13 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 9m
power up + 00:01:15 HTTP client 192.168.0.117 attempted login with incorrect password
power up + 00:01:19 HTTP client 192.168.0.117 login succeeded
2017-11-01 12:04:04 Date and time set at power up + 00:01:19
2017-11-01 12:04:10 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-11-01 12:09:40 Calibrated 8 factors using 13 points, deviation before 0.032 after 0.007
2017-11-01 14:17:31 Finished printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 2h 13m
2017-11-01 15:01:18 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-11-01 15:04:59 Calibrated 8 factors using 13 points, deviation before 0.122 after 0.147
2017-11-01 15:06:45 Resume-after-power-fail state saved
2017-11-01 15:06:51 Printing paused
2017-11-01 15:07:03 Cancelled printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode, print time was 0h 5m
2017-11-01 15:07:22 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-11-01 15:08:28 Calibrated 8 factors using 13 points, deviation before 0.262 after 0.006
2017-11-01 15:18:57 Resume-after-power-fail state saved
power up + 00:01:28 HTTP client 192.168.0.117 login succeeded
2017-11-01 18:38:52 Date and time set at power up + 00:01:28
2017-11-01 18:39:45 Started printing file Large Kossel_Piezo 20 V1.12 Groovemount .gcode
2017-11-01 18:45:17 Calibrated 8 factors using 13 points, deviation before 0.027 after 0.005
2017-11-01 18:54:28 Resume-after-power-fail state saved
power up + 00:00:08 Wifi module is connected to access point 3DP, IP address 192.168.0.109
power up + 00:29:12 HTTP client 192.168.0.117 login succeeded
2017-11-01 19:25:29 Date and time set at power up + 00:29:12
