Solved Can't upload .gcode to Duet 3 - Network Error
@p8blr said in Can't upload .gcode to Duet 3 - Network Error:
SD card longest read time 4.0ms, write time 212.9ms, max retries 0
wow, thats a slow write speed.
what sd card is it? is it almost full? -
@jay_s_uk I bought the Duet 3 from Matterhackers, so it's whatever was included. How can I check if it's full? I don't want to shut off the printer or remove the sd card because I have a print paused that I need to resume and I don't want to lose my home posistion.
@p8blr post the output of
M39
@jay_s_uk
M39SD card in slot 0: capacity 15.93GB, partition size 0.26GB, free space 0.04GB, speed 25.00MBytes/sec, cluster size 512 bytes
@jay_s_uk Do the included SD cards come partitioned like that normally? I literally have never removed the sd card. I have only updated to the latest firmware.
@p8blr and looks like its one of the older duet 3's that were shipped with an SD card that was setup for pi usage where the partition used in standalone mode was tiny.
best to get your print finished, remove the sd card, back everything up (config etc), format the sd card and pop everything back. then you can use the full 16gb -
@jay_s_uk It's a failed print that I'm trying to resume about halfway through so I need to upload a modified .gcode. Is it possible for me to remove the sd card, copy/paste the new .gcode over, reinsert it, and not mess anything up?
@p8blr you can release the SD card with M22, make the changes to the SD card and then plug it back in using M21.
But is the print actually paused or is it cancelled and you're just trying to recover it? -
@jay_s_uk It's canceled and I'm just trying to recover it. I'll give the M22 and M21 a shot.
@jay_s_uk That did the trick. Thank you!
