    Urgent Problem with Config.g
    My Duet controlled machine
    • TRATOONundefined
      TRATOON
      Hello, I was editing my config file and when I saved, it said no storage left and restarted. My config file was empty after then so I pasted over config.g.bak and changed saved. Now heater 1 has dissapeared and i get the following errors:
      Config:
      M92 X80.00 Y80.00 Z800.00 E409.00                ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00              ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00          ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00              ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                          ; Set idle timeout
      M671 X15:275 Y150:150 S5
      M208 X10 Y0 Z0 S1                                ; set axis minima
      M208 X295 Y320 Z250 S0                           ; set axis maxima
      M574 X2 S1 P"io0.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
      M574 Y2 S1 P"io1.in"                             ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
      M574 Z1 S2                                       ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"121.io0.in" H5 F600 T12000 A3 S0.03 R0.4  ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X50 Y-15 Z2.5                           ; set Z probe trigger value, offset and trigger height
      M557 X25:270 Y25:280 S30                         ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B3950     ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                               ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                 ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                          ; map heated bed to heater 0
      M143 H0 S100                                     ; set temperature limit for heater 0 to 120C
      M308 S1 P"121.temp0" Y"pt1000"                   ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1                           ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                 ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S450                                     ; set temperature limit for heater 1 to 450C
      M950 F0 C"121.out1" Q500                         ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H-1                                   ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"121.out2" Q500                         ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
      M563 P0 S"E3D Hemera" D0 H1 F0                   ; define tool 0
      G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      ;Filament Monitor
      M591 D0 P3 C"121.io1.in" S1  ; filament monitor connected to Toolboard io1.in
      M591 D0 ; display filament sensor parameters for extruder drive 0
      T0                                               ; select first tool
      M501
      TRATOONundefined 1 Reply Last reply Reply Quote 0
      • TRATOONundefined
        TRATOON @TRATOON
        @tratoon Ok I fixed it by adding some lines that were missing. I am running Duet 3 With SBC. Are the config files stored in the microSD card in the SBC?
          Phaedrux Moderator @TRATOON
          @tratoon said in Urgent Problem with Config.g:
          Yes they are. Is your SD card full?
          You can check your available free space: https://raspberrytips.com/raspbian-free-disk-space/#:~:text=How to I check free,at the “Avail” column.
          • TRATOONundefined
            TRATOON @Phaedrux
            @phaedrux I used balena etcher to copy files from 16gb sd to 128 gb still have no space
              I think you may have copied the partitions over directly, so they would still be the same size regardless of your SD card size.
              You would need to use Etcher to burn a fresh DuetPi image onto the new card. You would need to backup your config files from your old card in DWC and then copy them over to the new installation.
              • TRATOONundefined
                TRATOON @Phaedrux
                @phaedrux I used raspi-config to expand partition
                • TRATOONundefined TRATOON marked this topic as a question
                • TRATOONundefined TRATOON has marked this topic as solved
