    Robotic kinematics
    MultiAxis Printing
    22
    389
    46.9k
    • JoergS5undefined
      JoergS5 @o_lampe
      @o_lampe that's a very nice looking one!
      Yes, another user recommended using cycloidal gears in this thread somewhere above. It is an alternative. I've decided to go with harmonic drive, but there is no reason to consider cycloidal also. I love the cycloidal drives from Nabtesco like the RV500-N, which are used in Fanuc and ABB robots, but they have similar price ranges like the harmonic drives.
      I standardize / modularize the components for myself, like the dimensions of the gears, so it will be possible to exchange harmonic drive, cycloidal or belt-based gears. I take dimensions of commercial ones as a guideline.
      jtimonundefined 1 Reply Last reply Reply Quote 0
      • jtimonundefined
        jtimon @JoergS5
        @joergs5 Is this work still active?
        I wanted to take a look at the code to see what you're doing with the extra degrees of freedom, because I'm myself working on a modified hangprinter-like kynematics with 6 degrees of freedom. I only needed 6 steppers instead of 4 for the extra degrees of freedom, but I'm using 8 because I wanted to keep things squared and hopefully be able to get more speed with 8 motors, certainly I will have more torque.
        Anyway, the links to the code at the beginning of the thread are broken and I can't find it in your github account. Sorry I haven't read the whole read, but it's kind of long. Can you point me to the code?
        Thanks in advance.
        https://github.com/jtimon/reprope
        JoergS5undefined 2 Replies Last reply Reply Quote 0
        • JoergS5undefined
          JoergS5 @jtimon
          @jtimon I'm currently integrating it into RRF 3.5 locally and test, then will make a fork on github later this week. I removed my old fork. Hangprinter is also interesting, I would like to use it for wall painting (no joke), based on wires.
          • JoergS5undefined
            JoergS5
            Before it's too late and the robot kinematics goes into the official RRF, I split the A parameter into A and D, because it was very difficult to keep overview of 10 parameters in one setting. Instead of one A parameter for DH and angle parameters, I define D for DH parameters and A for angles now.
            Old eg:
            A1:200.0:0.0:0.0:0.0:70.0:90.0:-180.0:0.0:180.0
            New eg:
            D1:200.0:0.0:70.0:90.0
            A1:-180.0:180.0:0.0
            I have to change firmware code, documentation and RobotViewer DWC plugin, which I do before making a RRF fork.
            • JoergS5undefined
              JoergS5 @jtimon
              @jtimon sorry, it will take a few days more to deploy a RRF 3.5 version of the robot kinematics. I found a way to manage the different flavours of CNC 5 axis to be programmed, so I want to integrate it first.
              Regarding hangprinter, do you know the site https://stadtfabrikanten.org/display/TH ?
              The page "RepRapFirmware and calculations" is e.g. interesting regarding kinematics.
              • jtimonundefined
                jtimon @JoergS5
                @joergs5 Wall painting seems like a cool use case.
                There are plenty of small projects doing that (or something similar):
                https://www.youtube.com/watch?v=_mTvSju3d6o
                https://www.youtube.com/watch?v=T0jwdrgVBBc
                here's a CNC
                https://www.youtube.com/watch?v=y60q6U7NjTQ
                I'm currently working on adapting the hangprinter to allow more anchors in this PR:
                https://github.com/Duet3D/RepRapFirmware/pull/585
                But perhaps it would make sense to go lower than 4 anchors for some use cases too?
                Thanks for the trikarus link, cool stuff.
                Regarding your code, I'm not in a hurry. I'm not ready for working on the extra 3 rotational ABC axes since I still didn't get the basic xyz axes to work, and that is the part I want to read more, to see what you have done. Whenever you can share it, it would be awesome to have a look.
                jtimon opened this pull request in Duet3D/RepRapFirmware
                open 3.4 WIP: Allow up to 9 anchors/motors to be configured in hangprinter kinematics. #585
                • JoergS5undefined
                  JoergS5 @jtimon
                  @jtimon if you need help to understand firmware or how to address additional axes, I can help you, I have some experience now. I've created some documents about robot, starting is at https://docs.duet3d.com/User_manual/Machine_configuration/Configuring_RepRapFirmware_for_a_Robot_printer and made a tag "robot". The documents firmware and CNC 5 axis may be interesting for you about orientation.
                  I am constantly updating the documentation pages, when I think I have new knowledge to add.
                  Hangprinter may be a closed chain system, then robot kinematics will not help you much. You can check FiveBarScara, which is in the official RRF and uses closed kinematics, for additional code. I've used circle intersection in this kinematics to calculate the position of two arms without knowing the angles, this may help with wire based kinematics. Because you know the arm length (wire length), but not the angles.
                  • JoergS5undefined
                    JoergS5 @jtimon
                    @jtimon said in Robotic kinematics:
                    Thank you for the links. I meant wall painting: a house wall, to save house scaffolding. But I will start in the house, a single wall. After all, most of the work is in the little nooks and crannies. These exceptions and path planning could be programmed and then executed with G-Code. A camera can control the result and repaint the locations where it is not good enough. Maybe spraying is better than painting then (a fixed orientation endpoint).
                    I first thought about using an industrial robot for wall painting, but long arms are a problem for high payload. But maybe one can combine hangprinter with robot: robot for orientation and placing to the correct location, hangprinter to support payload. It will be necessary to paint around corners.
                    • JoergS5undefined
                      JoergS5
                      I have a problem with understanding CNC 5 axis. If someone here has knowledge of CNC 5 axis, could you please tell me whether my understanding is correct? This is also valid for CoreXY 5 axis, Pentarod and Open5x.
                      I've described it in
                      https://docs.duet3d.com/en/User_manual/Machine_configuration/robot_5_axis_CNC
                      second section called "Calculation".
                      My main confusion was reading an article about G-Code based on IJK (using tool vectors in G-Code) versus AC. The article wrote, an advantage of IJK is the machine independence. But in my understanding, AC is also machine independent (with the exception of the axis direction of AC versus BC). If someone knows if this is correct, a confirmation would be very kind.
                      DerAndereundefined 1 Reply Last reply Reply Quote 0
                      • wieman01undefined
                        wieman01
                        Is there a list of compatible robots somewhere on docs.duet.com? I searched but could not find anything...
                        Just curious what Duet will be capable of with the upcoming release (3.5).
                        wieman01
                        • JoergS5undefined
                          JoergS5 @wieman01
                          @wieman01 tested will be:
                          6 axis industrial robot
                          CNC 5 axis including CoreXY 5 axis
                          4 axis palletized robot
                          Documentation starting point is https://docs.duet3d.com/User_manual/Machine_configuration/Configuring_RepRapFirmware_for_a_Robot_printer and by the robot tag there are specialized documents for the specific types.
                          Other serial chain types are possible by configuring Denavit-Hartenberg parameters. With this concept, prismatic/linear and rotary axes can be combined in any combination, as long as they are in series. The current limit is 7 axes, but this is just a fixed variable.
                          wieman01undefined 1 Reply Last reply Reply Quote 1
                          • wieman01undefined
                            wieman01 @JoergS5
                            @joergs5 said in Robotic kinematics:
                            Thank you, @JoergS5. So the supported hardware isn't restricted to certain manufacturers, but to the design of the robot. That makes sense. I'll look into it. And really big thanks for your contribution here!
                            • JoergS5undefined
                              JoergS5 @wieman01
                              @wieman01 your're welcome. Don't hesitate to post your hardware setup here to discuss how to configure it, if you need help. I'll try to offer as much example configs and explanations as possible, but some questions may remain unanswered.
                              • JoergS5undefined JoergS5 referenced this topic
                              • JoergS5undefined
                                JoergS5
                                I am starting a new topic now in the "My Duet controlled machine" to apply the robot kinematics to robot prototypes of different kinds. You're invited to join the process of building:
                                • CNC 5 axis for abrasive drilling (with iHSV servos and 6XD) and CoreXYAC 5 axis for additive 3D printing
                                • 4 axis palletized for 3D printing (only for proof of firmware working)
                                • 6 axis industrial robot (later)
                                The next steps are:
                                • prototypes and verify robot kinematics in real life
                                • improve RobotViewer DWC plugin
                                • find or develop a free software solution to create 5 axis G-Code
                                I will concentrate on CNC. Some users plan to create CoreXY 5 axis printing, so for 3D printing, the 3D printer prototypes are mainly meant to help solving problems.
                                • DerAndereundefined
                                  DerAndere @JoergS5
                                  @JoergS5 Re: "My main confusion was reading an article about G-Code based on IJK (using tool vectors in G-Code) versus AC. The article wrote, an advantage of IJK is the machine independence. But in my understanding, AC is also machine independent (with the exception of the axis direction of AC versus BC). If someone knows if this is correct, a confirmation would be very kind."
                                  Answer:
                                  AFAIK, there is no international standard beyond 3 axis CNC G-code (ANSI/EIA RS-274D, ISO 6983-1:2009)
                                  XYZIJK notation is usually not interpreted by the CNC controller. It is usually used in an intermediate format of the CAM software. A post processor is used to convert it to the correct NC language for the selected machine.
                                  There are two ways how G-code axis codes XYZABC can be interpreted.
                                  a) direct joint control: each G-code axis is directly mapped to one joint/motor and controls only its position.
                                  b) Tool center point control (TCPC): inverse kinematics are applied so that other joints compensate changes in the commanded position of the rotational axes.This way, G-code axes XYZ control the tool center point (TCP) position and axes ABC control the tool angle/orientation.
                                  LinuxCNC is based on "NIST RS274NGC interpreter, Version 3". It cannot interpret the XYZIJK notation. LinuxCNC by default uses identity kinematics ("trivkins") which means direct joint control. it can (should) be configured to use kinetics that match the machine geometry, e.g. by adding this section in the config INI file:
                                  [KINS]
                                  KINEMATICS = xyzac-trt-kins
                                  Then, at startup, it applies the correct inverse kinematics to allow TCPC. You can change to direct joint control mode at runtime using a combination of M66 and M68 commands.
                                  For added confusion, LinuxCNC can be configured to start in direct joint control mode at startup:
                                  [KINS]
                                  KINEMATICS = xyzac-trt-kins sparm=identityfirst
                                  Source: https://linuxcnc.org/docs/devel/html/motion/switchkins.html
                                  Siemens Sinumeric controllers cannot interpret XYZIJK or XYZABC notation, only their own formats: https://www.manualslib.de/manual/134235/Siemens-Sinumerik-840Di.html?page=69#manual
                                  Haas
                                  direct joint control mode: G49 (default)
                                  TCPC mode: G234
                                  XYZIJK notation: no
                                  Fanuc:
                                  TCPC mode: G43.4
                                  XYZIJK notation: G43.5 (RTCP type II)
                                  • JoergS5undefined
                                    JoergS5 @DerAndere
                                    @DerAndere I wanted to use IJK, but then searched for alternatives, because IJ has a conflict with G2/G3 parameters. That's the reason why I changed to AC/BC and quaternions for full orientation. There is no G-Code standard for quaternions, so I use an artificial currently, until someone tells me which standard to use...
                                    I am using the b) method which supports the RTCP mode mentioned and explained e.g. in the links (the beckhoff one gives the fastest overview):
                                    https://www.cnclathing.com/guide/what-is-5-axis-cnc-machine-and-rtcp-function-advantages-of-5-axis-machining-cnclathing
                                    https://www.cnczone.com/forums/uncategorised-cam-discussion/413638-cnc-mastercam.html
                                    https://infosys.beckhoff.com/index.php?content=../content/1031/tccncprogramming/html/rotationtoolcenterpointrtcp.htm&id=
                                    This method has the advantage that you can configure the robot to calibrate any inexactness of axes, e.g. between X and Y. The kinematics will calculate the true rotations and positions. The idea is to measure the endpoints and calculate back to the config parameters.
                                    LinuxCNC is a great software and I'm taking it as reference sometimes how to propose parameters. It has however only experimental nurbs and bspline support, that's the next topic I want to address.
                                    The Fanuc has IJK support, but they need to change modes before using it (probably because of the G2/G3 problem), so it's a proprietary solution. Fanuc has good manuals. I find only few information about 5 axis CNC, so it's a valuable additional information source.
                                    • JoergS5undefined
                                      JoergS5
                                      The current status is that I changed internal calculations to skew symmetric matrices, but there were differences to the quaternion based calculations. The formulae in the internet are inexact (the rotation angle is set to 1), I've found the solution yesterday to get correct results now. Unfortunately from skew to rotation, there are also two solutions(!). As I said, orientations are a beast. I always use forward-inverse algorithms to calculate roundtrip calculation with random parameters. stackexchange and stackoverflow are very valuable information sources!
                                      • JoergS5undefined
                                        JoergS5 @DerAndere
                                        @DerAndere the different configurations of Haas and Fanuc shows imho that every manufacturer made his proprietary solution in the past. Worse, to get some advanced capabilities, one had to pay for those "options" additionally.
                                        Some combinations were not possible, e.g. changing the tool length for Fanuc prohibited using some special modes afterwards. robot kinematics uses the G10 offset settting of the current tool, so tool change should be no problem.
                                        The second problem is that there is no free software to support 5 axis. There are plugins in Blender and FreeCad, but to my knowledge not advanced ones. Currently I think, best would be to develop an own solution based on OpenNurbs, which is an open library developed by Rhino. Rhino itself is a bit expensive if one wants to use it noncommercial as hobby. (Hobby, non-commercial, being not a student => 1000$).
                                          DerAndere @JoergS5
                                          @JoergS5 List of open source CAM software for multi axis FDM (tool path- and G-code generators). I did not test them yet:
                                          • https://github.com/GuoxinFang/ReinforcedFDM (uses Rhino IIRC)
                                          • https://github.com/zhangty019/MultiAxis_3DP_MotionPlanning
                                          • https://github.com/Spiritdude/Slicer4RTN
                                          • https://xyzdims.com/vgcodectl/ : source code release planned
                                          T3P3Tonyundefined JoergS5undefined 2 Replies Last reply Reply Quote 2
                                            T3P3Tony administrators @DerAndere
                                            @DerAndere thanks for posting these here. two of them are @xyzdims work!
                                            Also not sure if you saw but the zhangty019 work is been built on further:
                                            https://dl.acm.org/doi/10.1145/3550454.3555516
                                            DerAndereundefined JoergS5undefined 2 Replies Last reply Reply Quote 0
