    Failed to enable endstops new build
    Using Duet Controllers
    886
    • chriswhitingundefined
      chriswhiting @jay_s_uk
      @jay_s_uk OK did that and print seems to run. I have a z height issue, but it may not be related.
      One problem now is Z doesn't probe when I select home all and does when I select home z? homez.g homeall.g config.g
      chriswhitingundefined 1 Reply Last reply Reply Quote 0
        chriswhiting @chriswhiting
        @chriswhiting I think I might have fixed the home all issue
        homeall.g
          jay_s_uk @chriswhiting
          @chriswhiting thats better.
          It's also suggested to probe in the centre of the bed for homing.
            @jay_s_uk Understood that's me being inpatient 🙂
              @chriswhiting Grrr calibrated my Z probe offset height to 1.28 and it's printing the first layer about 4mm above the bed?
              bed.g homez.g homeall.g config.g
                @chriswhiting you have no X and Y offsets for your probe
                G31 P500 X0 Y0 Z1.2                         ; set Z probe trigger value, offset and trigger height
                what type of probe is it and how did you calibrate it?
                  @jay_s_uk its a bltouch and I used this
                  https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                    @chriswhiting Tried again and changed
                    M558 P9 C"121.io0.in" H1.945 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                    Same problem?
                    config.g
                      @chriswhiting thats not where you set the probe offset. its set using G31, the next line down from M558
                        @jay_s_uk Yes I just worked that out and corrected it however, it's still not working
                          @chriswhiting can you post a photo of your setup?
                            @jay_s_uk It's not pretty 🙂
                            IMG_0868.pdf
                            IMG_0869.pdf IMG_0870.pdf
                              @chriswhiting OMG I think I have it working, had to add some g code to the slicer,
                              ; XY-3 Start Code
                              G21 ; Set units to millimeters
                              G90 ; Set all axis to Absolute
                              M82 ; Set extrusion to Absolute
                              M107 ; Disable all fans
                              M190 S{material_bed_temperature_layer_0} ; Set bed temperature and wait
                              G28 ; Home all axis
                              ; Uncomment the line below to enable ABL Mesh probing
                              ;G29 ; Probe bed mesh for ABL
                              ; For best results do not run nozzle heater while performing ABL
                              G1 Z5.0 ; Raise nozzle to prevent scratching of heat bed
                              G1 X0 Y0 ; Move nozzle to Home before heating
                              M109 S{material_print_temperature_layer_0} T0 ; Set nozzle temp and wait
                              G92 E0 ; Set Extruder position to zero
                              ; Uncomment the following lines to enable nozzle purge line along left edge of bed
                              ;G1 Z2.0 F3000 ; Raise Z axis
                              ;G1 X1.1 Y20 Z0.2 F3600.0 ; Move to purge line start position
                              ;G1 Y220 F1500.0 E10 ; Draw first purge line
                              ;G1 X1.4 F3600.0 ; Move to side
                              ;G1 Y20 F1500.0 E20 ; Draw second purge line
                              ;G92 E0 ; Reset Extruder
                              ;G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
                              ;G1 X5 Y20 Z0.2 F3600.0 ; Move over to finish nozzle wipe
                              ;G92 E0
                              chriswhitingundefined 1 Reply Last reply Reply Quote 1
                              • Phaedruxundefined Phaedrux has marked this topic as solved
                                @chriswhiting Thanks so much for responding so quickly and providing A grade assistance
