    Failed to enable endstops new build
    Using Duet Controllers
    890
    • chriswhitingundefined
      chriswhiting @chriswhiting
      @chriswhiting I think I might have fixed the home all issue
      homeall.g
        jay_s_uk @chriswhiting
        @chriswhiting thats better.
        It's also suggested to probe in the centre of the bed for homing.
        chriswhitingundefined 1 Reply Last reply Reply Quote 0
          chriswhiting @jay_s_uk
          @jay_s_uk Understood that's me being inpatient 🙂
            @chriswhiting Grrr calibrated my Z probe offset height to 1.28 and it's printing the first layer about 4mm above the bed?
            bed.g homez.g homeall.g config.g
              @chriswhiting you have no X and Y offsets for your probe
              G31 P500 X0 Y0 Z1.2                         ; set Z probe trigger value, offset and trigger height
              what type of probe is it and how did you calibrate it?
                @jay_s_uk its a bltouch and I used this
                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                  @chriswhiting Tried again and changed
                  M558 P9 C"121.io0.in" H1.945 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                  Same problem?
                  config.g
                    @chriswhiting thats not where you set the probe offset. its set using G31, the next line down from M558
                      @jay_s_uk Yes I just worked that out and corrected it however, it's still not working
                        @chriswhiting can you post a photo of your setup?
                          @jay_s_uk It's not pretty 🙂
                          IMG_0868.pdf
                          IMG_0869.pdf IMG_0870.pdf
                            @chriswhiting OMG I think I have it working, had to add some g code to the slicer,
                            ; XY-3 Start Code
                            G21 ; Set units to millimeters
                            G90 ; Set all axis to Absolute
                            M82 ; Set extrusion to Absolute
                            M107 ; Disable all fans
                            M190 S{material_bed_temperature_layer_0} ; Set bed temperature and wait
                            G28 ; Home all axis
                            ; Uncomment the line below to enable ABL Mesh probing
                            ;G29 ; Probe bed mesh for ABL
                            ; For best results do not run nozzle heater while performing ABL
                            G1 Z5.0 ; Raise nozzle to prevent scratching of heat bed
                            G1 X0 Y0 ; Move nozzle to Home before heating
                            M109 S{material_print_temperature_layer_0} T0 ; Set nozzle temp and wait
                            G92 E0 ; Set Extruder position to zero
                            ; Uncomment the following lines to enable nozzle purge line along left edge of bed
                            ;G1 Z2.0 F3000 ; Raise Z axis
                            ;G1 X1.1 Y20 Z0.2 F3600.0 ; Move to purge line start position
                            ;G1 Y220 F1500.0 E10 ; Draw first purge line
                            ;G1 X1.4 F3600.0 ; Move to side
                            ;G1 Y20 F1500.0 E20 ; Draw second purge line
                            ;G92 E0 ; Reset Extruder
                            ;G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
                            ;G1 X5 Y20 Z0.2 F3600.0 ; Move over to finish nozzle wipe
                            ;G92 E0
                            chriswhitingundefined 1 Reply Last reply Reply Quote 1
                            • Phaedruxundefined Phaedrux has marked this topic as solved
                              @chriswhiting Thanks so much for responding so quickly and providing A grade assistance
