    Loss remote access to Duet2 Wifi after firmware 3.4.3 upgrade
    Firmware installation
    754
    • tximyundefined
      tximy @dc42
      @dc42 Sorry, over my lan and the ping is ok but did not work DWC Telnet or FTP, the machine and panelDue work nice.
        dc42 administrators @tximy
        @tximy thanks. Please send M586 from PanelDue or USB and report the response.
        tximyundefined 1 Reply Last reply Reply Quote 0
        • tximyundefined
          tximy @dc42
          dc42undefined 2 Replies Last reply Reply Quote 0
            @tximy thanks. CORS is disabled by default and doesn't normally need to be enabled.
            The following may provide information useful to me to diagnose the problem:
            1. Please share some more details about your system - the config.g file will probably tell me all I need to know. It may have some significant feature that the bench system I just tested doesn't.
            2. Can you get a Wireshark trace from your PC so that we can see what response (if any) the Duet sends to DWC? If you haven't used Wireshark before, it's straightforward to install, then you need to select the correct network interface. Finally set the display filter to "ip.addr==192.168.137.243" (without the quotes) so that it only displays the traffic to/from the Duet.
              @tximy I may not need you to do that. I have just discovered that if enable FTP and Telnet (which I normally leave disabled) then I am unable to connect DWC. I am investigating.
              tximyundefined 1 Reply Last reply Reply Quote 1
              • tximyundefined
                tximy @dc42
                @dc42 config.g duet.txt
                I try now disable telnet and ftp. DWC is working for me 😉
                Thx.
                  @tximy please try this firmware binary.
                  Duet2CombinedFirmware.bin
                  tximyundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                  • tximyundefined
                    tximy @dc42
                    @dc42 tested, it work nice.
                    Great job.
                      @tximy thanks. I'll update the 3.4.3 release with that firmware binary within the next few days.
                      • OwenDundefined
                        OwenD @dc42
                        @dc42 said in Loss remote access to Duet2 Wifi after firmware 3.4.3 upgrade:
                        I had to remove the SD and put this binary into the firmware directory then perform an update using M997 S0
                        DWC now works again as does FTP and Telnet.
                        • jay_s_ukundefined jay_s_uk referenced this topic
