    Voron 2.4 Homing for XYZ Help
    2.0k
    • Karimundefined
      Karim @Ghazi
      @Ghazi This is a Voron 2.4, All the stepper are wire the same colors, are you going in the + for X & Y direction when homing. How do I know if X and Y is Flip.
      • Ghaziundefined
        Ghazi @Karim
        @Karim I checked my config file. B motor is X and A motor is Y. Check manual page 235
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @Ghazi
          @Ghazi ok A & B was mixed, now it home in the + direction, Now my End stops is at MAX.
          M119
          Endstops - X: at max stop, Y: at max stop, Z: not stopped, Z probe: at min stop
          Ghaziundefined 1 Reply Last reply Reply Quote 0
          • Ghaziundefined
            Ghazi @Karim
            @Karim Try the old homing file and see if it works. I changed nothing for homing x and y. But for Z I added few lines to move the toolhead above the z endstop
            • Karimundefined
              Karim @Ghazi
              @Ghazi Do you mind sharing you Config, X & Y & Z homing files.
              • Ghaziundefined
                Ghazi @Karim
                @Karim I donot have the printer nearby. I can help if you share the homing files you are testing right now
                • Karimundefined
                  Karim @Ghazi
                  @Ghazi
                  ; Configuration file for Duet WiFi (firmware version 3.3)
                  ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 14 2022 18:23:20 GMT-0400 (Eastern Daylight Time)
                  M575 P1 S1 B57600                                  ; enable support for PanelDue
                  G90                                                ; send absolute coordinates...
                  M83                                                ; ...but relative extruder moves
                  M550 P"Voron"                                      ; set printer name
                  M669 K1                                            ; select CoreXY mode
                  M552 S1                                            ; enable network
                  M586 P0 S1                                         ; enable HTTP
                  M586 P1 S0                                         ; disable FTP
                  M586 P2 S0                                         ; disable Telnet
                  ; --- Z Drive map ---
                  ;     _______
                  ;    | 6 | 7 |
                  ;    | 5 | 8 |
                  ;      front
                  ; (looking at the printer from the top)
                  ; Drive directions
                  M569 P0 S0 ; A
                  M569 P1 S0 ; B
                  M569 P3 S0 ; Extruder
                  M569 P5 S0 ; Z1
                  M569 P6 S1 ; Z2
                  M569 P7 S0 ; Z3
                  M569 P8 S1 ; Z4
                  ; Motor mapping and steps per mm
                  M584 X0 Y1 Z5:6:7:8 E3
                  M350 X16 Y16 Z16 E16 I1                           ; Use 1/16 microstepping with interpolation everywhere
                  M92 X80 Y80 Z400                                  ; Set XYZ steps per mm (1.8deg motors)
                  M92 E406                                          ; Set Extruder steps per mm
                  ; Drive currents
                  M906 X1200 Y1200 Z1200 E600                        ; XYZ and E current
                  M906 I30                                           ; Idle current percentage
                  M84 S120                                           ; Idle timeout
                  M208 X0 Y0 Z0 S1                                   ; set axis minima
                  M208 X350 Y350 Z350 S0                           ; set axis maxima
                  M574 X2 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                  M574 Y2 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                  M574 Z1 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                  ;M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
                  ;M557 X15:215 Y15:195 S20                           ; define mesh grid
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                  M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                  M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                  M140 H0                                            ; map heated bed to heater 0
                  M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                  M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                  M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                  M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                  M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                  M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                  M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                  M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                  M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                  M563 P0 D0 H1 F0                                   ; define tool 0
                  G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                  G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                  ;M501                                               ; load saved parameters from non-volatile memory
                  ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                  ; homeall.g
                  ; called to home all axes
                  ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 14 2022 18:23:21 GMT-0400 (Eastern Daylight Time)
                  G1 H2 Z5 F6000          ; lift Z relative to current position
                  G1 H1 X355 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                  G1 H1 X355             ; home X axis
                  G1 H1 Y355             ; home Y axis
                  G1 X-5 Y-5 F6000          ; go back a few mm
                  G1 H1 X355 F360        ; move slowly to X axis endstop once more (second pass)
                  G1 H1 Y355             ; then move slowly to Y axis endstop
                  G1 H1 Z-355 F360        ; move Z down stopping at the endstop
                  G90                     ; absolute positioning
                  G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
                  ;G91                    ; relative positioning
                  ;G1 Z5 F100             ; lift Z relative to current position
                  ;G90                    ; absolute positioning
                  ; homex.g
                  ; called to home the X axis
                  G1 H1 X355 F1800 ; move quickly to X axis endstop and stop there (first pass)
                  G1 X-5 F6000       ; go back a few mm
                  G1 H2 Z-5 F6000   ; lower Z again
                  ; homey.g
                  ; called to home the Y axis
                  G1 H1 Y355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                  G1 Y-5 F6000       ; go back a few mm
                  G1 H1 Y355 F360  ; move slowly to Y axis endstop once more (second pass)
                  ; homez.g
                  ; called to home the Z axis
                  G1 H1 Z-355 F1800 ; move Z down until the endstop is triggered
                  • Ghaziundefined
                    Ghazi @Karim
                    @Karim X & Y end stops M574 define high-end M574 X2, M574 Y2 switch them to low-end M574 X1 S1 p"xstop" & M574 Y1S1 P"ystop". The homing files should move in the negative values -355. Also, did you fix the mixed in wiring A & B motors
                    • Karimundefined
                      Karim @Ghazi
                      @Ghazi Ok that make the + movement for X & Y crash into the endstop.
                      • Ghaziundefined
                        Ghazi @Karim
                        @Karim My configuration might look different. The first config file in this post looks fine, but after switching A and B motors in the motor mapping M584 X1 Y0 Z5:6:7:8 E3. I attached a simple image for the x and y axes and where the original is on the printing bed (0,0) in the configuration Untitled.png
                        The point in green would be (350,350 ,0) after homing if you keep your current homing files.
                        • Karimundefined
                          Karim @Ghazi
                          @Ghazi So you moving in the Negative to home X & Y.
                          • Ghaziundefined
                            Ghazi @Karim
                            @Karim Yes
                            • Karimundefined
                              Karim @Ghazi
                              @Ghazi ok X & Y is moving in the Negative when homing. I need to work on Z end stop, I am not using a probe.
                              • Ghaziundefined
                                Ghazi @Karim
                                @Karim IF you are using a switch endstop for z, first align the extruder to be above the z endstop. I use a G1 command then the position in X and Y before switch to relative position. The position of my z endstop is (X=230,Y=0)
                                ; homez.g
                                G1 X230 Y0        ; align the extruder to be above the z endstop
                                • Karimundefined
                                  Karim @Ghazi
                                  @Ghazi Here is my Z homing.
                                  ; homez.g
                                  G1 X115 Y0        ; align the extruder to be above the z endstop
                                  ; homeall.g
                                  G1 H1 X-355 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                  G1 H1 X-355             ; home X axis
                                  G1 H1 Y-355             ; home Y axis
                                  G1 X5 Y5 F6000          ; go back a few mm
                                  G1 H1 X-355 F360        ; move slowly to X axis endstop once more (second pass)
                                  G1 H1 Y-355             ; then move slowly to Y axis endstop
                                  • Ghaziundefined
                                    Ghazi @Karim
                                    @Karim if you move x or y before homing z, it would not work correctly
                                    just switch line 5 and 6 to be like this,
                                    ; homez.g
                                    • Karimundefined
                                      Karim @Ghazi
                                      @Ghazi ok , after z endstop does x and y home. Also does the nozzle go back to the xy stop.
                                      ; homez.g
                                      • Karimundefined
                                        Karim @Karim
                                        Can you help with this:
                                        ;Bed (Keenovo 750w 120v)
                                        ;E3d Revo Voron)
                                        Karimundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                        • Karimundefined
                                          Karim @Karim
                                          Thanks Guys.
                                            Phaedrux Moderator @Karim
                                            @Karim said in Voron 2.4 Homing for XYZ Help:
                                            I'm not sure what you're asking for help with. Those are heater configuration commands, but what seems to be the issue?
