    Voron 2.4 Homing for XYZ Help
    2.0k
      Did you also change the direction of movement in the homing files as I showed?
      Karimundefined 1 Reply Last reply Reply Quote 0
      • Karimundefined
        Karim @Phaedrux
        @Phaedrux ok so a X is home toward the switch now, but it is at max, look at the photo.
        M119
        Endstops - X: at max stop, Y: at min stop, Z: not stopped, Z probe: at min stop
        ; homex.g
        ; called to home the X axis
        ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 14 2022 18:23:21 GMT-0400 (Eastern Daylight Time)
        G91               ; relative positioning
        G1 H2 Z5 F6000    ; lift Z relative to current position
        G1 H1 X355 F1800 ; move quickly to X axis endstop and stop there (first pass)
        G1 X-5 F6000       ; go back a few mm
        G1 H1 X355 F360  ; move slowly to X axis endstop once more (second pass)
        G1 H2 Z-5 F6000   ; lower Z again
        G90               ; absolute positioning
        ; homeall.g
        ; called to home all axes
        G1 H1 X355 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
        G1 H1 X355             ; home X axis
        G1 H1 Y-355             ; home Y axis
        G1 X-5 Y5 F6000          ; go back a few mm
        G1 H1 Y-355             ; then move slowly to Y axis endstop
        G1 H1 Z-355 F360        ; move Z down stopping at the endstop
        G92 Z0                  ; set Z position to axis minimum (you may want to adjust this)
        ;G91                    ; relative positioning
        ;G1 Z5 F100             ; lift Z relative to current position
        ;G90                    ; absolute positioning
        • Karimundefined
          Karim @Karim
          OK so I think I have a problem, Both X & Y should be going in the + direction when Homing, X Home in the + direction but Y home in the - direction. So as you can see on the status display Y shows 0 and X shows 350.
          How can I fix Y to Home in the + direction. I try changing M569 S0 which flip the X & Y axis.
          ; Drive directions
          M569 P0 S0 ; A
          M569 P1 S0 ; B
          • Ghaziundefined
            Ghazi @Karim
            @Karim This seems similar to my printer voron 2.4 It would be easier for you to debug if you write pin number instead of xstop, ystop. The reason is to make sure x and y motors are not flipped, which happened to me
            • Karimundefined
              Karim @Ghazi
              @Ghazi This is a Voron 2.4, All the stepper are wire the same colors, are you going in the + for X & Y direction when homing. How do I know if X and Y is Flip.
              • Ghaziundefined
                Ghazi @Karim
                @Karim I checked my config file. B motor is X and A motor is Y. Check manual page 235
                • Karimundefined
                  Karim @Ghazi
                  @Ghazi ok A & B was mixed, now it home in the + direction, Now my End stops is at MAX.
                  M119
                  Endstops - X: at max stop, Y: at max stop, Z: not stopped, Z probe: at min stop
                  Ghaziundefined 1 Reply Last reply Reply Quote 0
                  • Ghaziundefined
                    Ghazi @Karim
                    @Karim Try the old homing file and see if it works. I changed nothing for homing x and y. But for Z I added few lines to move the toolhead above the z endstop
                    • Karimundefined
                      Karim @Ghazi
                      @Ghazi Do you mind sharing you Config, X & Y & Z homing files.
                      • Ghaziundefined
                        Ghazi @Karim
                        @Karim I donot have the printer nearby. I can help if you share the homing files you are testing right now
                        • Karimundefined
                          Karim @Ghazi
                          @Ghazi
                          ; Configuration file for Duet WiFi (firmware version 3.3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.13 on Fri Oct 14 2022 18:23:20 GMT-0400 (Eastern Daylight Time)
                          M575 P1 S1 B57600                                  ; enable support for PanelDue
                          G90                                                ; send absolute coordinates...
                          M83                                                ; ...but relative extruder moves
                          M550 P"Voron"                                      ; set printer name
                          M669 K1                                            ; select CoreXY mode
                          M552 S1                                            ; enable network
                          M586 P0 S1                                         ; enable HTTP
                          M586 P1 S0                                         ; disable FTP
                          M586 P2 S0                                         ; disable Telnet
                          ; --- Z Drive map ---
                          ;     _______
                          ;    | 6 | 7 |
                          ;    | 5 | 8 |
                          ;      front
                          ; (looking at the printer from the top)
                          ; Drive directions
                          M569 P0 S0 ; A
                          M569 P1 S0 ; B
                          M569 P3 S0 ; Extruder
                          M569 P5 S0 ; Z1
                          M569 P6 S1 ; Z2
                          M569 P7 S0 ; Z3
                          M569 P8 S1 ; Z4
                          ; Motor mapping and steps per mm
                          M584 X0 Y1 Z5:6:7:8 E3
                          M350 X16 Y16 Z16 E16 I1                           ; Use 1/16 microstepping with interpolation everywhere
                          M92 X80 Y80 Z400                                  ; Set XYZ steps per mm (1.8deg motors)
                          M92 E406                                          ; Set Extruder steps per mm
                          ; Drive currents
                          M906 X1200 Y1200 Z1200 E600                        ; XYZ and E current
                          M906 I30                                           ; Idle current percentage
                          M84 S120                                           ; Idle timeout
                          M208 X0 Y0 Z0 S1                                   ; set axis minima
                          M208 X350 Y350 Z350 S0                           ; set axis maxima
                          M574 X2 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                          M574 Y2 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                          M574 Z1 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
                          ;M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
                          ;M557 X15:215 Y15:195 S20                           ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                            ; map heated bed to heater 0
                          M143 H0 S120                                       ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
                          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 S280                                       ; set temperature limit for heater 1 to 280C
                          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 D0 H1 F0                                   ; define tool 0
                          G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                          G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                          ;M501                                               ; load saved parameters from non-volatile memory
                          ;M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                          ; homeall.g
                          G1 H1 X355 Y355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                          G1 H1 Y355             ; home Y axis
                          G1 X-5 Y-5 F6000          ; go back a few mm
                          G1 H1 Y355             ; then move slowly to Y axis endstop
                          ; homex.g
                          ; homey.g
                          ; called to home the Y axis
                          G1 H1 Y355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                          G1 Y-5 F6000       ; go back a few mm
                          G1 H1 Y355 F360  ; move slowly to Y axis endstop once more (second pass)
                          ; homez.g
                          ; called to home the Z axis
                          G1 H1 Z-355 F1800 ; move Z down until the endstop is triggered
                          • Ghaziundefined
                            Ghazi @Karim
                            @Karim X & Y end stops M574 define high-end M574 X2, M574 Y2 switch them to low-end M574 X1 S1 p"xstop" & M574 Y1S1 P"ystop". The homing files should move in the negative values -355. Also, did you fix the mixed in wiring A & B motors
                            • Karimundefined
                              Karim @Ghazi
                              @Ghazi Ok that make the + movement for X & Y crash into the endstop.
                              • Ghaziundefined
                                Ghazi @Karim
                                @Karim My configuration might look different. The first config file in this post looks fine, but after switching A and B motors in the motor mapping M584 X1 Y0 Z5:6:7:8 E3. I attached a simple image for the x and y axes and where the original is on the printing bed (0,0) in the configuration Untitled.png
                                The point in green would be (350,350 ,0) after homing if you keep your current homing files.
                                • Karimundefined
                                  Karim @Ghazi
                                  @Ghazi So you moving in the Negative to home X & Y.
                                  • Ghaziundefined
                                    Ghazi @Karim
                                    @Karim Yes
                                    • Karimundefined
                                      Karim @Ghazi
                                      @Ghazi ok X & Y is moving in the Negative when homing. I need to work on Z end stop, I am not using a probe.
                                      • Ghaziundefined
                                        Ghazi @Karim
                                        @Karim IF you are using a switch endstop for z, first align the extruder to be above the z endstop. I use a G1 command then the position in X and Y before switch to relative position. The position of my z endstop is (X=230,Y=0)
                                        ; homez.g
                                        G1 X230 Y0        ; align the extruder to be above the z endstop
                                        • Karimundefined
                                          Karim @Ghazi
                                          @Ghazi Here is my Z homing.
                                          ; homez.g
                                          G1 X115 Y0        ; align the extruder to be above the z endstop
                                          ; homeall.g
                                          G1 H1 X-355 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-355             ; home X axis
                                          G1 X5 Y5 F6000          ; go back a few mm
                                          G1 H1 X-355 F360        ; move slowly to X axis endstop once more (second pass)
                                          • Ghaziundefined
                                            Ghazi @Karim
                                            @Karim if you move x or y before homing z, it would not work correctly
                                            just switch line 5 and 6 to be like this,
                                            ; homez.g
