Map Z axis to V axis
Hello all -
Issue:
I am trying to map the Z axis of one of two tools to the V axis (an independent axis operating in the z-direction), however this action appears unsupported. Has anyone found a way around this / or could indicate where I am making an error?Background:
I have built a custom 3D printer which has two independent X-axes for 2 toolheads (each on its own rail). Each x-rail is controlled by independent Z-stepper motors. The setup has 5 axes:
x-0
Y-1
Z-2
U-3 (powered by stepper driver 6) - parallel to X-axis
V-4 (powered by stepper driver 7) - parallel to Z-axisThe Y-axis is shared between both toolheads (the bed moves).
To move the toolheads independently in the X and Z directions, I've mapped Tool 0 to X0 Y1 Z2 and Tool 2 to X3 Y1 Z4, where axis 3 is the U axis, and axis 4 is the V axis per the duet documentation.
The issue: In the interface, after selecting Tool 2 and moving the 'x' axis, it moves the U axis as expected. However, when moving the 'z' axis, it moves the Z instead of V axis.
I've tried changing the mapping of Z with no effect. The documentation states that mapping of the X and Y axes is possible, but does not indicate whether the Z axis can also be remapped.
Here are the relevant pieces of setup code:
M569 P0 s1 ; physical drive 0 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P2 S1 ; physical drive 2 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M569 P4 S0 ; physical drive 4 goes forwards
M569 P5 S1 ; physical drive 5 goes backwards
M569 P6 S1 ; physical drive 5 goes backwards
M569 P7 S1 ; physical drive 6 goes backwards
M584 X0 Y1 Z2 E3:4:5 U6 V7 ; set drive mappingM563 P0 D0 H1 F0 X0 Y1 Z2 ; define tool 0
M563 P2 D2 H2 F2 X3 Y1 Z4 ; define tool 2Thank you for your help!
@SebastianM said in Map Z axis to V axis:
This should be Z7, not Z4 from my understanding. But then again, it should also be X6....I'm confused
@o_lampe Thanks for the response.
I initially thought that as well, however, after that didn't work, this is what I found in the documentation which clarified that U is the 3rd and V4th axis.
M563:
X, Y The X and Y mapping option is used to create tools on machines with multiple independent X and/or Y carriages. The additional carriages are set up as axes U, V etc. (see M584) and the X mapping option in M563 defines which carriage or carriages are used. Axes are mapped in the order XYZUVWABC, where X=0, Y=1, Z=2, U=3 etc, not by driver number. -
@SebastianM
I remember, I fell in the same trap before. But with RRF3.2, I could only make it work when the driver number matched the letter-numbering you quoted.M584 X0 Y1 Z2 U3 V4 E5 ; set drive mapping ... ; Drives hashPrinter ; ; X | V ;---|--- ; Y | U ; M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; U axis als 2te x M569 P4 S1 ; V axis als 2te Y ... ; Tools ; ; 1 | 2 ;---|--- ; 0 | 3 ; M563 P0 D0 H1 S"XY" X0 Y1 F0 ; define tool 0 in bottom left corner G10 P0 X-0 Y-0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D0 H1 S"XV" X0 Y4 F0 ; define tool 1 in top left corner G10 P1 X-0 V0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C M563 P2 D0 H1 S"UV" X3 Y4 F0 ; define tool 2 in top right corner G10 P2 U0 V0 Z0 ; set tool 2 axis offsets G10 P2 R0 S0 ; set initial tool 2 active and standby temperatures to 0C M563 P3 D0 H1 S"UY" X3 Y1 F0 ; define tool 3 in bottom right corner G10 P3 U0 Y-0 Z0 ; set tool 3 axis offsets G10 P3 R0 S0 ; set initial tool 3 active and standby temperatures to 0C
So I've put the extrudermotor(s) behind the motion drivers
undefined oribotic referenced this topic
