    How to add firmware to my Formbot Troodon 3D printer
    Firmware installation
    981
    • RJ 0undefined
      RJ 0
      I accidentally hit the factory reset function on my new 3D troodon printer and now I have macros or functions to access. Can someone help me please on how to upload that back into the printer.
        In DWC in the macros tab there is an upload button.
        RJ 0undefined 1 Reply Last reply Reply Quote 0
        • RJ 0undefined
          RJ 0 @Phaedrux
          @Phaedrux Sorry I am kinda stupid when it comes to this kind of stuff. How to I access the DWC in the macros tab. THis is the type of printer i have.
          • RJ 0undefined
            RJ 0 @RJ 0
            @RJ-0 400 series. I lost all functions. Nothing works since I hit that factory setting button by mistake.
              I'm not really familiar with what Formbot does with their Duet clone. I'm not sure what the factory reset does. I assumed you still had access to the web interface, but perhaps not? Have you reached out to Formbot? Do they have documentation?
              • RJ 0undefined
                RJ 0 @Phaedrux
                @Phaedrux No documentation. Very little came with it. Just a SD card with setup stuff that's all. I don't have access to the web interface on it. Nothing works now. That should be my next step I guess is to reach out to Formbot and see if they can tell me anything. The factory reset cleared all my macros, wifi connectivity access and pretty much all commands. None of the buttons I press does anything.
                  Wish I could help more, but I have no familiarity with the printer or what parts of the Duet they keep or replace.
                  • oliofundefined
                    oliof @Phaedrux
                    @Phaedrux the Troodon board is fully compatible with the Duet2 firmware, it's basically a custom board combining a Duet2 and Duex5 board. So the normal Duet2 flashing instructions apply. Their config is somewhere on GitHub,
                    RJ 0undefined 1 Reply Last reply Reply Quote 1
                    • RJ 0undefined
                      RJ 0 @oliof
                      @oliof Thank you very much. I will see if I can find that.
                      • RJ 0undefined
                        RJ 0 @RJ 0
                        @RJ-0 Do I need to sign up to GitHub to access that info?
                        • oliofundefined
                          oliof @RJ 0
                          @RJ-0 no. Here is the link I had in mind https://github.com/InsanityAutomation/FormbotTroodon -- please be advised that this is for a relatively old version of RepRapFirmware and you will need to do some adjustments to make it work with RepRapFirmware 3.4. Some Troodon users are here on the forum and may have an adjusted version.
                          • RJ 0undefined
                            RJ 0 @oliof
                            @oliof Thank you very much for the info. What is the only way to download this stuff back into the printer? Can it be done thru transfer from a SD card?
                            • RJ 0undefined
                              RJ 0 @RJ 0
                              @RJ-0 I have no Wifi capability since i did the factory reset.
                                If it's just like the Duet 2, then you would have to use a USB connection to your computer and use software called BOSSA to flash the firmware back onto the board.
                                https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#fallback-procedure-2
                                • RJ 0undefined
                                  RJ 0 @Phaedrux
                                  @Phaedrux So the board will have to be removed?
                                    I'm not sure about that, but you'd at least need to be able to get a USB cable to the board.
                                    • RJ 0undefined
                                      RJ 0 @Phaedrux
                                      @Phaedrux I had to remove the board in order to access the micro usb connection on it. Last question lol. Does the board have to be powered up (printer on) to do this or can i just do this with the board laying on my table plugged up to computer?
                                        Plugging it in via USB should work I think. It does for a Duet board anyway.
                                        • RJ 0undefined
                                          RJ 0 @Phaedrux
                                          @Phaedrux Thanks so much for the help. Will try and let you know.
