    5v to power my Neopixel from Duet 2 wifi
    1.3k
    • Karimundefined
      Karim
      Hey guys how do I get 5v from my duet 2 wifi or duex5 to power my 5v led light for my stealthburner . Below is the led it has three wire.
        T3P3Tony administrators @Karim
        @Karim what are specs of the LEDs - do you have any more information about the setup?
        Karimundefined 1 Reply Last reply Reply Quote 0
        • Karimundefined
          Karim @T3P3Tony
          @T3P3Tony Here is a photo of wiring.
          cosmowaveundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
          • cosmowaveundefined
            cosmowave @Karim
            @Karim Do you know how much current the LED's needs?
            According to the docu, the limit is:
            5V current limit 2.0A total on 5V and 3.3v, including the internal current consumption (around 200-300mA), any PanelDue or other display, and any endstops/Z probes that draw significant power.
            Mankati FSXT+, DeltaTowerV2, E3D MS/TC
              @Karim look like neopixels. The Duet3 mainboards have built in support for Neopixels. The Duet 2 boards need a level shifter for the data line:
              https://docs.duet3d.com/en/User_manual/Connecting_hardware/IO_Neopixel_DotStar
              • Karimundefined
                Karim @T3P3Tony
                @T3P3Tony Support for NeoPixel strips on Duet 2 WiFi/Ethernet was added in RRF 3.3.
                A signal for controlling Neopixel strips can be output on pin 5 of the CONN_LCD connector provided that you do not have external stepper drivers connected to CONN_LCD. The signal level is 3.3V so you need to level shift it to 5V. A non-inverting 74HCT series gate or buffer such as 74HCT08 can be used to do this.
                RGB NeoPixels draw up to 60mA per LED. RGBW ones draw up to 80mA per LED. Therefore the Duet cannot provide enough power for an LED strip unless the number of LEDs in the strip is small (for example 16 RGB or 12 RGBW LEDs). For longer strips you must provide external 5V power to the strip.
                In firmware 3.3 the maximum supported number of Neopixel LEDs in a strip is 60 RGB LEDs. Firmware 3.4 and later support up to 60 RGBW LEDs or 80 RGB LEDs.
                What does this means.
                cosmowaveundefined 1 Reply Last reply Reply Quote 0
                  cosmowave @Karim
                  @Karim said in 5v to power my led from Duet.:
                  This means that the Duet has an output voltage of 3.3V, but neopixels needs 5V.
                  You need a level shifter to "adapt" the voltage between the two systems.
                  • Karimundefined
                    Karim @cosmowave
                    @cosmowave is this what I need to get it working.
                    https://www.amazon.com/Fairchild-MM74HCT08N-74HCT08N-74HCT08-2-Input/dp/B07GQ5CJ2M/ref=sr_1_1_sspa?crid=2NZD4HLSWP0L9&keywords=74HCT08+quad+gate&qid=1666533478&sprefix=74hct08+quad+gate%2Caps%2C91&sr=8-1-spons&psc=1
                      cosmowave @Karim
                      @Karim Yes. I think this should work.
                      • Karimundefined
                        Karim @cosmowave
                        @cosmowave ok how did I connect this, is there a diagrams for this .
                          cosmowave @Karim
                          @Karim Not a diagram, but some infos. Eventually it makes sense to read the infos about the duet3 connection and then the special infos about the Duet2...
                          • Karimundefined
                            Karim @cosmowave
                            @cosmowave
                            Connecting NeoPixel strips to Duet 2 Wifi or Ethernet
                            So Can I use the pin 5 of the CONN_LCD connector and the have a 5v external power supply.
                              cosmowave @Karim
                              @Karim Yes, that should work.
                              Pin5 of CONN_LCD is only the signal. For the signal you should insert your level shifter.
                              Don't forget to connect the GND's of your Duet and external power supply, else they are not on the same "level".
                              • Karimundefined
                                Karim @cosmowave
                                @cosmowave Look at this photo .
                                  cosmowave @Karim
                                  @Karim If your LED's don't need to much current it is ok to wire them directly on the CONN_LCD.
                                  Else you should use your external power supply.
                                  • Karimundefined
                                    Karim @cosmowave
                                    @cosmowave it's just 3 neopixel for my tool head light.
                                      cosmowave @Karim
                                      Should be no problem...
                                      Don't forget the level shifter!
                                      • Karimundefined
                                        Karim @cosmowave
                                        @cosmowave this is where I am confuse, do I still need the level shifter. I am getting 5v +- and signal from the duet 2 Wi-Fi.
                                          cosmowave @Karim
                                          @Karim The signal port has only 3.3V!
                                          • Karimundefined
                                            Karim @cosmowave
                                            @cosmowave Thank you . I am waiting for the part.
