Duet 2 U and W axis on IDEX printer
I'm building a printer with IDEX system. One extruder is using X and Z axis but another one should use U and W axis.
I can put the second extruder to use the U axis (I mean, I call "T1" and the second extruder moves on "G1 X" commands) but the W axis don't move, only the Z axis (from the 1st extruder). W axis can move manually on the dashboard, do homming, etc.
This is my config.g file:
; Drives M569 P0 S1 ; physical drive 0 goes forwards X connection - M569 P1 S1 ; physical drive 1 goes forwards Y connection - Y2 M569 P2 S1 ; physical drive 2 goes forwards Z connection - Y1 M569 P5 S0 ; physical drive 5 goes forwards X0 (duex expansion drive 5) - DRIVE EXTERNO M569 P6 S1 ; physical drive 6 goes forwards X1(U) (duex expansion drive 6) - DRIVE EXTERNO M569 P7 S1 ; physical drive 7 goes forwards Zextrusora0 (duex expansion drive 7) - DRIVE EXTERNO M569 P8 S1 ; physical drive 8 goes forwards Zextrusora1 (V)(duex expansion drive 8) - DRIVE EXTERNO M569 P9 S1 ;extrusora 2 M584 X5 Y1:2 Z7 U6 W8 E0:9 P6 ; set drive mapping ; Endstops M574 X2 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin ^xstop M574 Y2 S1 P"ystop+zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ^ystop M574 Z2 S1 P"!exp.e5stop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin ^zstop M574 U1 S1 P"!e0stop" ; configure active-low endstop for high end on U via pin e0stop M574 W2 S1 P"!e1stop" ; Tools M563 P0 D0 S"ExtDireita" ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 D1 X3 Z5 S"ExtEsquerda" ; define tool 0 G10 P1 X0 Y0 Z0 ; set tool 0 axis offsets ;G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C
I'm using a Duet 2 Wifi with firmware version: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0 (2022-03-15)
Duet WiFi Server Version: 1.26There are some missing commands on the code above but not related to drives or tools.
Can somebody help me?
Thanks in advance -
@amcubed
remapping drives is quite confusing. For me it's always trial&error.
I would try Z6, since W is the sixth letter in the kinematic matrix.
IIRC it starts with X=1 then YZUVW.
Anyone please correct me if I'm wrong -
@amcubed if you are trying to get the second tool to use a different Z axis, then I am sorry, RRF doesn't support that. RRF only supports mapping the X and Y parameters in move commands to different axes, not Z.
@dc42 will the RRF ever support it?
The wiki page says that "Note that axes are mapped in the order XYZUVWABC, where X=0, Y=1, Z=2, U=3 etc, not by driver number, so X0:3 means 'map axis 0 (X) and 3 (U) to X'." I mean, if Z axis don't work this information is misleading... I actually made a whole machine based on this
