G32 Error: Probe was not triggered during probing move
STM
1.1k
    john345463563 @john345463563
    This is my homez and homeall, however
    when I click homez I get: Error: Insufficient axes homed for bed probing
    When I click homeall I get: G32 Error: Probe was not triggered during probing move
    This is what happens in both case: https://www.veed.io/view/2662d068-d4fd-4333-b377-a7714f70bd2a
    homez.g
    G91 ; relative positioning
    ;JP REMOVED; G1 H1 Z-255 F1800 ; move Z down until the endstop is triggered
    G31 X50 Y50 ;JP ADDED
    G30 X50 Y50 ;JP ADDED
    G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
    homeall.g
    G1 H1 X-240 Y-240 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
    G1 H2 X5 Y5 F6000 ; go back a few mm
    G1 H1 X-240 Y-240 F360 ; move slowly to X and Y axis endstops once more (second pass)
    ;JP COMMENTED G1 H1 Z-255 F360 ; move Z down stopping at the endstop
    G31 X50 Y50 ; JP ADDED
    G30 X50 Y50 ; JP ADDED
    G90 ; absolute positioning
    BlTouch
    M918 P1 E4 F1000000
    M558 P9 H5 F120 T6000 C"^probe"
    M950 S0 C"Servo0"
    G31 P550 X-40 Y-5 Z2.05
    M557 X10:180 Y10:210 S40
    undefined 1 Reply Last reply 6 Nov 2022, 21:04 Reply Quote 0
      Phaedrux Moderator @john345463563
      @john345463563 said in G32 Error: Probe was not triggered during probing move:
      M558 P9 H5 F120 T6000 C"^probe" M950 S0 C"Servo0"
      Where did you get those?
      Can you send M122 and M98 P"config.g" in the gcode console in DWC and copy and paste the results here?
      Homez gives you an error like that if the X and Y axis aren't homed yet.
      G31 X50 Y50 ;JP ADDEDG30 X50 Y50 ;JP ADDEDG92 Z0 ; set Z position to axis minimum (you may want to adjust this)
      this is all still incorrect.
      Here's an example of what it should be
      homeall.g
      G1 X150 Y150 F6000 ; move to bed center
      G30 ; probe z
      And here is an example of what the bltouch config should look like
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      undefined 1 Reply Last reply 6 Nov 2022, 21:28 Reply Quote 1
        john345463563 @Phaedrux
        @Phaedrux
        Thank you so much for your help!
        I'm doing some progress, now the extruder will move in the middle on the bed but then I get this error:
        Error: Invalid Z probe index
        Error: in file macro line 8: G30: Z probe 0 not found
        and
        Error: in file macro line 11: G30: Z probe 0 not found
          Did you also fix up the bltouch config in your config.g?
          undefined 1 Reply Last reply 7 Nov 2022, 23:33 Reply Quote 1
            @Phaedrux
            M122 returns but M98 P"config.g" erros and the connection is reseted, I am using a BLtouch clone.
            >>> m122
            SENDING:M122
            RepRapFirmware for STM32F4 based Boards (biquskr_rrf_e3_1.1) version 3.4.2_101 (2022-09-14 11:00:21) running on STM32F4
            Board ID: 21064-0N0JA-JJ5T4-7S18N-GBQS7-40000
            Used output buffers: 1 of 40 (23 max)
            Static ram: 19520
            Dynamic ram: 84372 of which 648 recycled
            Never used RAM 25504, free system stack 161 words
            CCMRam static ram: 16760 dynamic ram: 19708 free ram 29064
            Tasks: NETWORK(ready,11.9%,242) HEAT(notifyWait,0.0%,347) Move(notifyWait,0.0%,361) TMC22xx(delaying,1.7%,135) FSWRITE(notifyWait,0.0%,566) MAIN(running,86.4%,436) IDLE(ready,0.0%,29), total 100.0%
            Owned mutexes: WiFi(NETWORK) BITIO(TMC22xx) USB(MAIN)
            Last reset 00:14:34 ago, cause: power on/off
            Last software reset at 2022-11-06 13:21, reason: User, GCodes spinning, available RAM 27092, slot 1
            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00454000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
            Error status: 0x00
            [ERROR] Error status: 0x00
            Aux0 errors 0,0,0
            Step timer max interval 0
            MCU temperature: min 40.8, current 43.6, max 43.6
            Supply voltage: min 24.0, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
            Events: 0 queued, 0 completed
            Driver 0: standstill 2209, SG min 0, reads 49289, writes 8
            Driver 1: standstill 2209, SG min 0, reads 49289, writes 8
            Driver 2: standstill 2209, SG min 0, reads 49289, writes 8
            Driver 3: standstill 2209, SG min 0, reads 49290, writes 8
            Driver 4:
            Driver 5:
            Driver 6:
            Driver 7:
            Driver 8:
            Driver 9:
            Driver 10:
            Driver 11:
            Driver 12:
            Driver 13:
            Date/time: 2022-11-07 15:32:21
            Slowest loop: 162.98ms; fastest: 0.09ms
            === Storage ===
            Free file entries: 10
            SD card 0 detected
            SD card longest read time 1.2ms, write time 0.0ms, max retries 0
            DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            === AuxDDARing ===
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            File is idle in state(s) 0
            USB is ready with "M122" in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            Daemon is idle in state(s) 0
            Code queue is empty
            === Network ===
            Slowest loop: 20.75ms; fastest: 0.00ms
            Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0)
            HTTP sessions: 2 of 8
            Uploads/Errors: 0/0
            = WiFi =
            Network state is active
            Bad header: 0/0
            WiFi firmware version 1.25B0-01S-D
            WiFi MAC address 62:22:32:1d:82:4d
            WiFi Vcc 3.38, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 35192
            WiFi IP address 192.168.20.121
            WiFi signal strength -68dBm, mode 802.11n, reconnections 0, sleep mode modem
            Clock register 00004002
            >>> M98 P"config.g"
            SENDING:M98 P"CONFIG.G"
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            Error: bad model parameters
            [ERROR] Error: bad model parameters
            Led port is 0
            Pin is already allocated as pwm 48
            WiFi module is idle
            Error: Unknown pin name 'exp.heater3'
            [ERROR] Error: Unknown pin name 'exp.heater3'
            Error: Unknown pin name 'zprobe.in'
            [ERROR] Error: Unknown pin name 'zprobe.in'
            [ERROR] Error: Invalid Z probe index
            Error: in file macro line 105: M591: missing parameter 'C'
            [ERROR] Error: in file macro line 105: M591: missing parameter 'C'
            undefined 1 Reply Last reply 8 Nov 2022, 06:02 Reply Quote 0
            • undefined Phaedrux moved this topic from General Discussion 8 Nov 2022, 04:00
              You didn't mention it was an STM based board. I don't know what the correct pin names for that board would be. But once you find them, it should work once you put them into bltouch probe config. Don't forget to also setup the Deployprobe.g and Retractprobe.g macros in the sys folder.
                jay_s_uk @john345463563
                @john345463563 pin names are here
                https://teamgloomy.github.io/skr_rrf_e3_pins.html
                undefined 1 Reply Last reply 8 Nov 2022, 16:51 Reply Quote 1
                  john345463563 @jay_s_uk
                  @jay_s_uk
                  I think this is the Out of the Box pin configuration, however this was not working, I believe:
                  ; BlTouch
                  ; Setup Servo0 as servo port on SKR-RRF-E3
                  M950 S0 C"Servo0"
                  undefined 1 Reply Last reply 8 Nov 2022, 17:00 Reply Quote 0
                    @john345463563 yep, that looks right https://teamgloomy.github.io/skr_rrf_e3_bltouch.html
                    so i would suggest rechecking your wiring
                    undefined 1 Reply Last reply 8 Nov 2022, 17:39 Reply Quote 1
                      @jay_s_uk
                      with the OOB config the z will hit multiple time on the Z switch when home all:
                      https://www.veed.io/view/30b310ca-1c11-4b33-a064-c4d5c6d43daf?panel=share
                      ; BlTouch
                      M950 S0 C"Servo0"
                      homeall.g
                      G91
                      G1 H2 Z5 F6000
                      G1 H2 X5 Y5 F6000
                      G90
                      G1 X150 Y150 F6000
                      G30
                        You'll need to physically alter the placement of the BLtouch to lower it down a bit and probably move the z endstop out of the way. The bottom of the BLtouch body should be ~8mm above the nozzle tip to allow for proper trigger height.
                          If you raise the print head higher up and then do a homeall can you touch the pin with your finger to see if it stops z motion correctly?
                          undefined 1 Reply Last reply 9 Nov 2022, 01:00 Reply Quote 1
                            @Phaedrux
                            Yeah! thats one part of problem if I touch the pin while homing it will not stop the motor check the video:
                            https://www.veed.io/view/47fba682-59b9-4054-8d5c-fa732df8e43f?panel=share
                            the BLTouch wil changing color and at the end it will become red
                              Check the continuity of the signal wire. That's usually the white one that would be going to the "probe" input pin.
                                john345463563
                                Thank you so much! @Phaedrux
                                Great Call! i've inverted 3dTouch white and black wire and now the sensor works.
                                Now I am Following this:
                                https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                                I send these commands:
                                • M561
                                • M564 S0
                                • G92 Z0
                                • G30 S-1 Stopped at height 1.510 mm
                                • edited in congif.g
                                  ---> G31 P550 X-40 Y-5 Z1.51
                                • Reboted
                                Now I will like to level the bed and print, i am
                                • homing X (not configured for BLtouch)
                                • homing Y (not configured for BLtouch)
                                • HomeAll (not sure why the home is in the middle of the bed)
                                • True Bed leveling G32 (should I use this or the other?)
                                • Print
                                I am wondering:
                                1. Is that the correct way of leveling?
                                2. is there something wrong in my configuration?
                                3. I am also wondering why the homeAll is going in the middle?
                                4. should I edit also the homeX, homeY, HomeZ?
                                5. Is there any video/tutorial/info on how to level the bed?
                                homeall.g
                                G91
                                G1 H2 Z5 F6000
                                G1 H2 X5 Y5 F6000
                                G90 ; JP ADDED
                                G1 X150 Y150 ; JP ADDED
                                G30 ; JP ADDED
                                HomeX,Y,Z
                                ; homex.g HomeX
                                G1 H1 X-240 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                G1 H2 X5 F6000 ; go back a few mm
                                G1 H1 X-240 F360 ; move slowly to X axis endstop once more (second pass)
                                G1 H2 Z-5 F6000 ; lower Z again
                                G90 ; absolute positioning; homex.g
                                ; homey.g HomeY
                                G1 H1 Y-240 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                G1 H2 Y5 F6000 ; go back a few mm
                                G1 H1 Y-240 F360 ; move slowly to Y axis endstop once more (second pass)
                                ; homez.g HomeZ
                                config.g
                                M950 S0 C"Servo0"
                                M557 X50:180 Y50:210 S40
                                config-override.g
                                ; config-override.g file generated in response to M500 at 2021-01-20 10:10
                                ; Heater model parameters
                                M307 H0 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                M307 H1 R2.429 C140.000:140.000 D5.50 S1.00 V0.0 B0
                                ; Workplace coordinates
                                G10 L2 P1 X0.00 Y0.00 Z0.00
                                G10 L2 P2 X0.00 Y0.00 Z0.00
                                G10 L2 P3 X0.00 Y0.00 Z0.00
                                G10 L2 P4 X0.00 Y0.00 Z0.00
                                G10 L2 P5 X0.00 Y0.00 Z0.00
                                G10 L2 P6 X0.00 Y0.00 Z0.00
                                G10 L2 P7 X0.00 Y0.00 Z0.00
                                G10 L2 P8 X0.00 Y0.00 Z0.00
                                G10 L2 P9 X0.00 Y0.00 Z0.00
                                M486 T0M486 S-1
                                undefined 1 Reply Last reply 10 Nov 2022, 04:15 Reply Quote 0
                                  That's going to depend a lot on your printer. Do you have independent Z motors to do full automatic tilt correction, or do you just have leveling knobs on the print bed?
                                  It goes where you tell it to. G1 X150 Y150 Usually the center of the bed is the best place to go, since that's typically where you will be printing.
                                  What do you want to do with them?
                                  There are plenty of videos on youtube on that subject if you search.
                                  undefined 1 Reply Last reply 10 Nov 2022, 16:53 Reply Quote 1
                                    @Phaedrux said in G32 Error: Probe was not triggered during probing move:
                                    I have a stock Ender3, so Im guessing leveling knobs?
                                    Yeah! thats my curiosity why should I use them 🙂
                                    undefined 1 Reply Last reply 10 Nov 2022, 19:44 Reply Quote 0
                                      Well they are what dictates what the printer does when you tell it to home an axis. So it moves towards an endstop and sets the axis extents.
                                      Well the most basic leveling is to use a piece of paper to set the knobs so that the nozzle is just touching the paper.
                                      Take a look here https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40#s165
                                      undefined 1 Reply Last reply 11 Nov 2022, 00:50 Reply Quote 1
                                        Thats an amazing article too bad its does not have the instructions for the BLTouch
                                          What instructions are you looking for? How to use the bltouch to tell you how much to adjust the knobs? That's here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_manual_levelling
                                          15 out of 25
