Endstop not working on delta with duet 2
Hello everyone.
I've been having some issues with the endstops on an FLSUN Q5 delta printer.
I've replaced the old board with the Duet 2 wifi. Firmware version 3.4.4M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.4 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-10-20 16:17:41
I have everything wired in correctly and it's mostly working.
I am however having an issue with the endstops. When I home the printer, the movement crashes against the endstops and wants to keep going. Then DWC shows an M121 error with insufficient axes homed.
I can see all the motors and axes working correctly.
Testing the switches with the M119 command shows the switches working correctly.M119: Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: not stopped ; nothing triggered M119: Endstops - X: not stopped, Y: not stopped, Z: not stopped, Z probe: at min stop ; Z probe active M119: Endstops - X: at max stop, Y: not stopped, Z: not stopped, Z probe: not stopped ; X stop active M119: Endstops - X: not stopped, Y: at max stop, Z: not stopped, Z probe: not stopped ; Y stop active M119: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped ; Z stop active
This is my config.g.
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Wed Nov 09 2022 00:32:21 GMT-0700 (Mountain Standard Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"FLSUN Q5" ; set printer name M665 R104 L215 B104 H160 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80 Z80.00 E13.00 ; set steps per mm M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X12000.00 Y12000.00 Z12000.00 E12000.00 ; set maximum speeds (mm/min) M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z0 S1 ; set minimum Z ; Endstops M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop ; Z-Probe M558 P5 C"!^zprobe.in" H5 F120 T6000 ; set Z probe type to switch and the dive height + speeds G31 P500 X0 Y0 Z20.34 ; set Z probe trigger value, offset and trigger height M557 R85 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp -Slice Engineering 300Deg Thermistor M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4680 C6.455513e-8 ; configure sensor 1 as thermistor on pin e0temp -Slice Engineering values M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S290 ; set temperature limit for heater 1 to 290C -Slice Engineering Mosquito ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 C"Part Cooling" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 C"Mosquito" S0 H-1 ; set fan 1 name and value. Thermostatic control is turned off ; Tools M563 P0 S"HotEnd" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M501 ; load saved parameters from non-volatile memory T0 ; select first tool
I'm starting to think the switches are going bad but, they get used so little compared to the other equipment, it doesn't make much sense.
These are the switches - https://www.ebay.com/itm/334506838039
I can't even find this kind anymore! Perhaps I need updated ones.Any help is appreciated.
Thanks. -
@sgtconker1r Can you post your homedelta.g from the sys folder, please?
@cosmowave said in Endstop not working on delta with duet 2:
Sure.
; homedelta.g ; called to home all towers on a delta printer ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Tue Nov 08 2022 22:54:47 GMT-0700 (Mountain Standard Time) G91 ; relative positioning G1 H1 X205 Y205 Z160 F1800 ; move all towers to the high end stopping at the endstops (first pass) G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass) G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred G90 ; absolute positioning G1 X0 Y0 F6000 ; move X+Y to the centre
A day later to think about it. I now notice some issues with my homedelta.g
All the axes need to be the same value, not just the Z.
I'll try this update later when I'm off work.. . . Seems so obvious after the fact. Perhaps it just helped to write it down.
@sgtconker1r Yes. The X,Y,Z values should be the same on a delta.
But i think, with G1 H1 it should stopping anyway at the endstops...!? -
@sgtconker1r your config looks OK to me.
The usual reason for not stopping at endstops on a delta is that the endstops are on the wrong towers, e.g. the X endstop is at the top of the tower with the Y motor. So I suggest you test the motors and endstops individually as described at https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_linear_delta#testing-the-motors-and-endstops-individually and make sure the endstops are consistent with the motors. Looking at the machine from the front, the X tower should be on the left, the Y tower on the right and the Z tower at the back.
Quote: "...make sure the endstops are consistent with the motors. Looking at the machine from the front, the X tower should be on the left, the Y tower on the right and the Z tower at the back."
This is what was wrong with my setup.
It seems the wiring was mislabeled from the very beginning.
Now the homing works correctly.
Solved.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
