    Duet 2 Wifi CONN_LCD ENC_A AND ENC_B Pins Input Voltage Range
    • dieguitoundefined
      dieguito
      What is the voltage range that the Stop 11 (ENC_A) and the Stop 10 (ENC_B) pins in the CONN_LCD connector in the Duet 2 Wifi can take?
      Can the take a negative voltage?
      Thank you!
      D
        What do you intend to do?
        dieguitoundefined 1 Reply Last reply Reply Quote 0
        • dieguitoundefined
          dieguito @Phaedrux
          @Phaedrux I want to get a signal from a drive that tells me whenever the motor connected to the drive faults. The signal may be negative. I don't need to worry about polarity on the drive side. Wondering if the Duet Wifi cares.
            dc42 administrators @dieguito
            @dieguito those pins connect directly to the microcontroller, so negative voltages are unsafe and may damage it.
