End stops
Working on acquiring electronics for use with 6HC board. Looking at end stops, can I use the mechanicals from donor N2 Plus, or best to change to electronic?
Thanks in advance, everyone has been extremely helpful.
Photo of the endstops? Whatever they are, they can likely be reused no problem.
You may find some helpful info here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_endstops
Thanks, documentation sez can use about anything. Image of a Raise microswitch end stop.
That looks like a pretty plain microswitch. I can't tell from the photo if it's wired normally open or normally closed, but if you follow that linked document you should have no trouble using those.
