    Thermistor Temperatur od T2 and T3 are not correct
    823
    • Mike 0undefined
      Mike 0 @jay_s_uk
      @jay_s_uk Thanks a lot. I will give it a try tonight.
      • Mike 0undefined
        Mike 0 @jay_s_uk
        @jay_s_uk I just updated the firmware. It was very easy. But the stuttering and the Thermistor problem is still there.
          jay_s_uk @Mike 0
          @mike-0 can you post your whole config?
          Mike 0undefined 1 Reply Last reply Reply Quote 0
          • Mike 0undefined
            Mike 0 @jay_s_uk
            @jay_s_uk Here is the File. I think the stuttering got even worse. I uploaded the files and installed the update. Is there anything else i need to adjust ?
            Thanks for your help.
            config.g
              jay_s_uk @Mike 0
              @mike-0 M667 S1 has been replaced by M669 K1.
              Your M566 speed for Z is really low. Increase it to 60 or 120. That may fix your issue
                dc42 administrators @Mike 0
                @mike-0 what is the PCB revision of the DueX board? It's written on the top, next to the ribbon cable connector. If it's revision 0.11 then you need to add parameter R2200 to the two M308 commands that refer to thermistors connected to the DueX.
                Mike 0undefined SignPostManundefined 2 Replies Last reply Reply Quote 0
                • Mike 0undefined
                  Mike 0 @dc42
                  @dc42 That did the trick. Yes the version was 0.11.
                  Thanks a lot. I'm super happy for the quick support. Thanks again
                  • Mike 0undefined
                    Mike 0 @jay_s_uk
                    @jay_s_uk I think that solved the problem. It is much smoother now. But i will monitor it.
                    Thanks again for your help.
                    • Mike 0undefined Mike 0 has marked this topic as solved
                    • SignPostManundefined
                      SignPostMan @dc42
                      @dc42 said in Thermistor Temperatur od T2 and T3 are not correct:
                      R2200
                      Same problem, Same Fix
                        dc42 administrators @SignPostMan
                        @SignPostMan said in Thermistor Temperatur od T2 and T3 are not correct:
                        R2200
                        Firmware 3.4 and later detect the DueX version automatically and adjust the default R parameter for M308 accordingly.
