Z Axis home speed varies.
@Karim if you home Z after you have already run G32 then the Z homing speed will be 60mm/min because that was set in line 13 of bed.g.
To avoid this, use M558 in homez.g to reset the probing speed before the G30 command.
@dc42 ok like this
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 11:08:05 GMT-0400 (Eastern Daylight Time) G1 X140 Y150 F6000 ; go Center of bed G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X140 Y150 F6000 ; go to first probe point G30 ; home Z by probing the bed M558 P5 C"^zprobe.in" H5 F300 T6000 ; set Z probe type to switch and the dive height + speeds
Don't use the full line, just M558 F300. If you use the full line things can get reset in G31.
@Phaedrux said in Z Axis home speed varies.:
M558 F300
This does not work. The only way it goes to normal speed (F300) is by emergency stop or power off then power on.
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 11:08:05 GMT-0400 (Eastern Daylight Time) G1 X140 Y150 F6000 ; go Center of bed G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X140 Y150 F6000 ; go to first probe point G30 ; home Z by probing the bed M558 F300 ; Reset Probe Speed.
@Karim said in Z Axis home speed varies.:
This does not work.
I bet against: just home Z twice - the second time, it should run at normal speed.
I think you should move the line
from the very end of home.g to its beginning - else, the intended speed change can't affect the
G30
in the line above … -
@infiniteloop Still does not work.
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.14 on Sat Oct 29 2022 11:08:05 GMT-0400 (Eastern Daylight Time) M558 F300 ; Reset Probe Speed. G1 X140 Y150 F6000 ; go Center of bed G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G90 ; absolute positioning G1 X140 Y150 F6000 ; go to first probe point G30 ; home Z by probing the bed
@infiniteloop , ok I think I got it, It's working now, I add the M558 F300 after G32 in the homeall.g
Thanks guys.
undefined dc42 marked this topic as a question
undefined dc42 has marked this topic as solved
