Error code when using M471
Gcode meta commands
macros m471
438
    ApTix
    So I'm in the trying to make a backup of my old bed mesh to reference. The issue I'm having isnt with the function but it spits out error code when doing it.
    Like it does rename the file heightmap_00 to .bak, but it spits out the error code underneath. Am I doing something wrong?
    Tried using the command in the console and in a macro but same result. It renames the file but spits out the same error code
    Using this command:
    M471 S"/sys/heightmap_00.csv" T"/sys/heightmap_00.csv.bak" D1
    Error code:
    Error: M471: Failed to rename file or directory /sys/heightmap_00.csv to /sys/heightmap_00.csv.bak: Unable to find the specified file.
    Using duetweb on a raspberry 4 8gb
    Board: Duet 3 6HC
    DSF 3.4.3
    undefined undefined 2 Replies Last reply 21 Nov 2022, 13:26 Reply Quote 1
      jay_s_uk @ApTix
      @ApTix one for @chrishamm
      what you're trying to do looks ok to me
        Do your DSF and Duet firmware versions match?
        undefined 1 Reply Last reply 21 Nov 2022, 17:43 Reply Quote 0
          ApTix @Phaedrux
          @Phaedrux
          Board: Duet 3 MB6HC (MB6HC)
          DSF Version: 3.4.3
          Firmware: RepRapFirmware for Duet 3 MB6HC 3.4.3 (2022-10-05)
            Can you try renaming, but keep the csv extension?
            undefined 1 Reply Last reply 21 Nov 2022, 18:02 Reply Quote 0
              ApTix @Phaedrux
              @Phaedrux I tried to rename the file to heightmap_00.bak.csv and heightmap_00_bak.csv with or without D1 in M471 but still the same result…it renames the file but gets the same error code.
              undefined 1 Reply Last reply 21 Nov 2022, 19:43 Reply Quote 0
                Sounds like maybe a permissions issue, but @chrishamm would know more.
                Is this with a stock Duet Pi image? Might not be a bad time to try a fresh image download and update to 3.4.4.
                  ApTix @ApTix
                  @Phaedrux its running mjpg-streamer beside the duet application for a camera stream. maybe updating would help...but it seems more like a bug than permission issues since it does change the name of the file? like it does work but error codes pops out?
                    chrishamm administrators @ApTix
                    @ApTix Thanks for reporting this, it will be fixed in the next version.
                    Duet software engineer
                    2 out of 9
