Common Ground with Ribbon Cable?
Does the ribbon cable provide common ground between a Duet3 and a Raspberry Pi SBC? I'm building a Voron and the wiring guide specifies common ground between the MCU and the Pi somehow, and if this is satisfied by the ribbon cable it would make the wiring simpler.
@id_pqr it does. there are several ground connections in fact
