    Printer architecture
    3.2k
      deckingman
      Something else has just occurred to me. Are you intending to use both heads at the same time or are you planning on having a carriage that will take either head and swap between them that way? If it's the former, then you'll have a large offset between the nozzles because the heat sinks on the Diamond are angled out at around 22 degrees forming a circle of about 75 mm in Diameter. So depending on what the second hot end is, you'll have to allow around 50mm for the lost axis travel. If you don't need to use them concurrently, then you physically swap between them and use one of the 5 Diamond extruders for the other hot end.
      • b7e7c2515deeundefined
        b7e7c2515dee
        I will use both heads at the same times, one for the main structure in PLA, and one for the support material in PVA.
          b7e7c2515dee
          @T3P3Tony:
          You can use an two more external drivers on the CONN_LCD header with recent firmware
          That would allow you to drive your 6th extruder.
          Is this compatible with the panel due? What's the standard use of this header?
            Yes it is compatible with Panel Due. The original plan was to support 20x4 text LCDs on that connector, but demand for that was very low and a requirement for more stepper drivers arose, so we repurposed it.
              b7e7c2515dee
              Thanks a lot, I now have my printer general architecture.
              • raykholoundefined
                raykholo
                I don't like having 2 nozzles side by side (idle nozzle leaking, all those concerns).
                I would make an IDEX like the SIGMA. Same construction - X Y on top, and bed moves down, but the XY is "regular" and not COREXY. Your diamond will dock to the left and your single support extruder will dock to the right. Requires 1 additional motor for the 2nd X axis. That should be exactly 10 motors.
                  b7e7c2515dee
                  I don't like to have a moving axis motor so IDEX with a carthesian moving system so it's not the best idea in my opinion.
                    b7e7c2515dee
                    I saw this thread http://forums.reprap.org/read.php?397,714601 about static motors for IDEX in a coreXY setup but I don't know if it's possible with a duet board.
                    • whosrdaddyundefined
                      whosrdaddy
                      yes, it is called CoreXYU: http://forums.reprap.org/read.php?397,775415
                        b7e7c2515dee
                        Do the duet board allow this kind of architecture (in the frimware I mean, without too much tweaking)?
                          Yes, it's supported in the standard firmware build. See https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer.
                            b7e7c2515dee
                            Thanks
