SuperSlicer question
In SuperSlicer, in the 'g code preview' tab, how can I get the actual g code displayed. On occasion the g code shows up but I have not been able to make it show up when I want it to show up ....
I assume latest versions?
Screen shot of what you mean? -
@Phaedrux, yes, latest version
On occasion, this screen has, on the left side, a listing of g codes. Presumably the gcodes corresponding to the layer or layers that you are examining. I am assuming that since the window is called 'g codes preview', that somehow or other I should be able to see gcodes here.
The gcode listing has shown up on several occasions but I do not know what I did to make the listing appear or disappear. -
Ok, never mind, figured it out .... I have to use the slider on the bottom. If it is all the way to the right then no listing, anything else and it shows the listing of the gcodes that are being run.
Thanks for replying - it actually got me to realize that it makes no sense to display all the gcodes from an entire layer and I decided to try the slider to get to a more focused look and there it was .... so indirectly you gave me the answer. Thanks ! -
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
