    Confusion re DWC 'control heaters'
    Duet Web Control
    1.3k
      Is the Duet3 6HC in SBC mode?
      • jens55undefined
        jens55 @Phaedrux
        @Phaedrux, I do not have an SBC connected and I use the standalone files when I update. Is there a seperate flag that turns on the SBC mode ?
          No, and it's not that there is a known problem with SBC or anything, just wondering what your setup it.
          Maybe it's because they are toolboards? They are all on the same firmware version as the mainboard?
          jens55undefined 2 Replies Last reply Reply Quote 0
          • jens55undefined
            jens55 @Phaedrux
            @Phaedrux, yes, they are all on 3.4.4 which I just installed the other day via the zip file in the repository. As far as I know, if I upload the zip file then everything gets automatically updated.
            I will double check ....
            • jens55undefined
              jens55 @jens55
              Double checked - all boards report 3.4.4
              • jens55undefined
                jens55 @Phaedrux
                @Phaedrux, which Duet board do you run and do you run tool boards or is everything connected to the main board?
                  dc42 administrators @jens55
                  @jens55 I confirm there is an issue. I have a delta with one extruder and a bed heater, and Turn Everything Off works as expected. I also have a tool changer, on which 2 of the 4 tools use tool boards; but on that machine Turn Everything Off does nothing. All boards running RRF 3.4.4. I will investigate and report back.
                  jens55undefined 1 Reply Last reply Reply Quote 1
                  • jens55undefined
                    jens55 @dc42
                    @dc42,
                    THANK YOU THANK YOU THANK YOU !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
                    I am soooo glad I am not going insane !
                    chrishammundefined 1 Reply Last reply Reply Quote 1
                    • chrishammundefined
                      chrishamm administrators @jens55
                      @jens55 We have identified the problem and it will be fixed in the upcoming V3.4.5.
                      Duet software engineer
                      • jens55undefined
                        jens55 @chrishamm
                        @chrishamm, great news, thank you !
                          @jens55 FYI it's related to how many tool heaters the machine has. The length of the commands that DWC sent to turn the heaters off was too long to fit in the HTTP input buffer, and RRF was not returning an error code when this happened. We have fixed both.
                          • jens55undefined
                            jens55 @dc42
                            @dc42 , cool, thanks for that extra info!
                              Phaedrux Moderator @jens55
                              @jens55 said in Confusion re DWC 'control heaters':
                              Thanks for pushing the issue. 😉
