    Tall 3D printers under 5000$/€
    3D Printing General Chat
    • sungod3kundefined
      sungod3k
      i work in orthopedics and we're using a Raise 3d pro 2+ which is fine, but now that we need an additional printer I dont want to buy a 5 year old machine for ~5000€.
      The new Pro 3+ however costs 7700€ which is a bit above my budget.
      I have looked far and wide for hobby level machines which are totally fine for what we print, but they usually go only up to 400-500mm in Z height, and we need a minimum of 600mm.
      So Id like to ask the crowd inteligence: Have you found a normal fdm 3d printer for under 5000€ with a minimum build hight of 600mm?
      Cheers
      F.
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
      • ComedianTF2undefined
        ComedianTF2
        I work for a company called Modix3D, and we create large printers at a pretty tight budget. The big60 model is 600x600x660 (XYZ) for $4950+shipping, so it's right around your budget
        sungod3kundefined 1 Reply Last reply Reply Quote 0
        • sungod3kundefined
          sungod3k @ComedianTF2
          @ComedianTF2 Yes thats was actually my first choice.
          I wanted the 120Z version, but it only comes as a kit and its company policy to only buy full service machines and i wasnt trusted with building the thing myself.
          also if you add the comfort features it ends up more on the 6000 side 🙂 but good thinking.
            dc42 administrators @sungod3k
            @sungod3k what bed size does the printer need to meet your requirements? The Tractus3D T1250 might meet your requirements if a 350mm diameter bed is large enough.
            sungod3kundefined 1 Reply Last reply Reply Quote 1
            • sungod3kundefined
              sungod3k @dc42
              @dc42 yes, i contacted them also, they were a bit slow with the communication and 350 is a bit on the smaller side, but yes tractus is still on my shortlist.
