    Flickering paneldue
    PanelDue
    547
      dc42 administrators @Exerqtor
      @exerqtor does it still flicker if you disconnect it from the Duet and power it from its USB port? If so then please submit a warranty claim to warranty@duet3d.com.
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @dc42
        @jay_s_uk said in Flickering paneldue:
        @exerqtor what type of heated bed do you have?
        230V, it don't mather if the bed is on or off though!
        @dc42 said in Flickering paneldue:
        Haven't tried that yet, i'll to it later today. Worked just fine before though, and the only thing i did was to shorten/recrimp the mobo side of the wires 🤔
          @exerqtor said in Flickering paneldue:
          A bad crimp connection in the 5V or ground wire could cause that flickering.
          • Exerqtorundefined
            Exerqtor @dc42
            @dc42 didn't help to recrimp, but with this behaviour the most likely problem is the PD? In that case it would be a good reason to swap for a 5i or 7i 😆
              @exerqtor did you try powering the PD from its USB port?
              Exerqtorundefined 2 Replies Last reply Reply Quote 0
              • Exerqtorundefined
                Exerqtor @dc42
                Haven't gotten around to do it yet, got quite a backlogg of stuff i have to get printed first now that the printer is actually up and working 😶
                • Exerqtorundefined Exerqtor referenced this topic
                • Exerqtorundefined
                  Exerqtor @dc42
                  @dc42 Looks like I found the problem, like mentioned in another thread I just re-soldered the WiFi module. And now the flickering seems to have stopped. COULD a weak/bad solderpoint to the WiFi module have caused this? Or am i grasping at straws?
                    @Exerqtor said in Flickering paneldue:
                    IMO it's unlikely that resoldering the wifi module would affect the PanelDue.
                    • Exerqtorundefined
                      Exerqtor @dc42
                      It's subsided atleast, so i'm a happy chap 😅
                        @Exerqtor I'll mark this as solved but feel free to revert it if the problem occurs again.
                        • dc42undefined dc42 marked this topic as a question
                        • dc42undefined dc42 has marked this topic as solved
