    fan connection on the duet 3 mini
    361
      jay_s_uk @Proschi3D
      @Proschi78 how are you configuring them? how are you wiring the fan in? what fan part number is it? is it 2 wire, 3 wire or 4 wire?
      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
      • Proschi3Dundefined
        Proschi3D @jay_s_uk
        @jay_s_uk
        there are 12 v fans connected to a raise 3d tollboard with 2 cables.
        via a ribbon cable on the motion board.
        the tollboard is supplied with 12v via the ribbon.
        the fans each have a cable in the ribbon.
        but they work perfectly on the out 6 buff.
        I just want to be able to control both separately
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
          jay_s_uk @Proschi3D
          @Proschi78 that doesn't really answer anything. without the commands you're using to configure them and explicit wiring details its very difficult to help you further.
          My first guess if you've wired them incorrectly but without knowing what you have connected where I have no idea.
            Proschi3D @jay_s_uk
            12V is on the 12V output.
            left fan on the out 6 buff
              jay_s_uk @Proschi3D
              @Proschi78 so you're bypassing the power outputs on the fan connector and purely using the out 6 buff connector.
              So the question is. how did you wire them in when you tried the other out connectors?
                Proschi3D @jay_s_uk
                On the right is the LED lighting, then the left fan and then the right and the 12v connection. The one on the left cannot be controlled. He's always on
                  jay_s_uk @Proschi3D
                  @Proschi78 all the out connectors on the duet switch on the ground side, not the positive side. so if you're wiring from 12v to a ground connection, the fans will always be on
                    Proschi3D @jay_s_uk
                    @jay_s_uk And then why does it work on the out6 buff?
                      jay_s_uk @Proschi3D
                      @Proschi78 i'm assuming you're wiring the ground side of the fan to out6buff
                        Proschi3D @jay_s_uk
                        The conversion to the duet 3 mini is complete. Just a few things to adjust. Thank you for your help, you are great
                        • Phaedruxundefined Phaedrux has marked this topic as solved
