    Ender 5 with duet duo 2 wifi firmware 3.1 config
    • Melfestoundefined
      Melfesto
      Hello all wanted to see if anyone has a good working config for this type of setup. I recently updated the firmware to the newest version and I am having a lot of issues I can't seem to track down. The biggest one is print speed is stuck at 11.4mm/s no matter what i change it to in cura nothing changes. I looked in the firmware but i don't seem to see anything that stands out. Any help would be greatly appreciated.
      • Melfestoundefined
        Melfesto
        well digging around some i found out if i force the M203 command M203 X6000 Y6000 Z300 E10000 everything starts working fine speed is back up to where it needs to be. I go into the config.g file and make the changes there save it restart the printer and check the settings are correct still but the next print the speed goes back down to 8.4-11.8mm/s. whats happening with this ?
          jay_s_uk @Melfesto
          @Melfesto check your start gcode in your slicer
