    Should've stuck with the knockoff GT2560?
    28
    3.9k
    • DjDemonDundefined
      DjDemonD
      @hayseed_byte:
      That actually makes me feel a lot better. Guess I just needed a little encouragement. Thanks, man.
      You're welcome, you'll find this is one of the most helpful, knowledgeable and polite forums in 3d printing.
      Send us some more details of what you're struggling with and we'll soon get you printing awesome stuff.
      www.precisionpiezo.co.uk
      • JRDMundefined
        JRDM
        The connectors will take 0.1" / 2.54mm "dupont" connectors, you mainly miss out on the latching mechanism. I didn't spot any kits where you got wires with Molex KK connectors on them. I can crimp these connectors but I just haven't yet, my old connectors will just connect.
        I'm impressed with how powerful the platform is but the g code configuration is wearing thin.
        • elmoretundefined
          elmoret
          So the current issue is the Y-axis is going the wrong way? That's an easy fix, change the relevant M569 command in config.g.
          I'm a huge fan of g-code based config actually, it means that 1.) configuration of the printer can be changed mid-print and 2.) configuration can be simply and easily overridden using the g-code console which helps for initial testing and setup.
          • Billhc83undefined
            Billhc83
            Stick with it, the Duet is IMO the best board for 3d printing. The community is very active and helpful, the web browser interface is great. David puts a lot of work into making the firmware better and better, which I don't think you get elsewhere. The initial setup and configuration can be a bit confusing at first but it really is great once you get onto it.
            • hayseed_byteundefined
              hayseed_byte
              @elmoret:
              I'll look into the M569 command. I'm a flunkie maintenance man so I just swapped the motor leads around. πŸ˜„
              https://wildbot.me/wildbot
              Gcode Definitions for VSCode extension: https://github.com/hayseedbyte/rrf-gcode-definitions
              • DjDemonDundefined
                DjDemonD
                Turning the motor plug around is my preferred solution since I'd rather everything turn the "right way" mechanically than in software. And I prefer DuPont plugs to molex so its not a problem t do so (and I'm careful which way around I insert them by default).
                All I'd say is that if you were familiar with downloading Marlin, and going through configuration.h and setting all the parameters for your printer manually, then tweaking it by adjusting them and uploading, Duet/RRF is the same but its much easier as you just change the config.g file and hit reboot, or test your change by just sending the gcode at any time, even whilst printing.
                If you just downloaded pre-configured firmware for your machine and flashed it and booted it up, then RRF will seem like a lot more ball-ache, but it actually makes you delve much deeper into how the machine works, broadens your understanding of it, and makes changing/upgraded/fault finding in the future far less daunting.
                • Forgvn77undefined
                  Forgvn77
                  I can only speak from my own learning experience. Duet has a steep and sometimes costly (regarding time) learning curve, especially if what you're doing is currently in development πŸ™‚ But I will say that David and the forum here are a very dedicated and helpful group of people! Stick with it and once you get your rig up and running, you'll definitely be better for it.
                  Velleman K8200, Geeetech G2S Pro (x2), Geeetech Rostock 301 retrofitted with Duet
                  Make A Difference!
                  • stavrosgmtlundefined
                    stavrosgmtl
                    @Forgvn77:
                    Words from my mouth. I love this thing once i understood it. Lot's of little quality of life things that impress me daily.
                      hayseed_byte
                      I began installing the Duet Wifi on my printer on Friday. I've worked on it all weekend and all day today and still haven't managed a single successful print. Current problem is nozzle height. I've adjust my z-stop and leveled (trammed) my bed over and over again today. It seems like the z axis homes to a different place when I click "Home Z" than it does when it homes to start printing. When I click "Home Z" it'll barely touch the limit switch lever and stop. When it's printing, it smashes the lever all the way down against the body of the limit switch. Just now figured that out. But it's been one thing after another.
                      EDIT: Also, what is the deal with using the molex connectors? Luckily I had a pair of the special crimpers because I like buying tools but man, what a pain in the ass. I don't see any advantage molex connectors have over the green terminal block/header plugs like these:
                      Crimping molex, dupont and jst connectors is pretty fiddly. Seems like there should be a bench-mounted press for those instead of hand-held crimpers. After crimping new molex connectors for everything on my printer, I don't see why those connectors exist at all.
                      • Billhc83undefined
                        Billhc83
                        What type of printer is it?
                          hayseed_byte
                          @Billhc83:
                          It's a cheap ebay i3 clone. A Geeetech i3 pro B knockoff made by CTC. Though there is very little left of the original machine.
                            Some of the early Duet 06 boards were manufactured with screw terminals throughout. They were not popular. With screw terminals, you can't disconnect and reconnect motor cables, endstop cables etc. quickly. There is also a much greater chance that users will mis-wire the board, especially after disconnecting and reconnecting several cables.
                              deckingman
                              @dc42:
                              ….....and the risk of stray strands causing shorts - unless ferrules are used throughout (which need to be crimped).
                                hayseed_byte
                                The green connectors have screw terminals in a housing and then plug into a header. Alot of the more technical equipment where I work uses them. Maybe I just need practice with the molex/dupont crimper but twisting a wire nice and neat to get it in a terminal sure seems a lot easier than trying to hold those tiny pins by the end to get them to sit in the crimper just right, then close it enough to hold the pin while you try to stick the wire through and try to get it lined up with the wings correctly. But maybe I just suck at it. πŸ˜„ My clumsy mechanic hands just better suited to turning a screw driver.
                                EDIT: Oh, I hope I'm not coming off as too combative or disgruntled. I really am enjoying the board and all the neat things it makes possible. Also, you guys are great and super helpful. I'm extremely grateful. Sometimes I play "devil's advocate" without realizing it just to get/keep a discussion going. I often learn a lot from discussions and learning is always a good thing.
                                • Billhc83undefined
                                  Billhc83
                                  I typically buy the arduino DuPont connector kits and just cut the leads in half and solder the wires together then wrap with heatshrink rather than trying to crimp the pins. I guess there is a chance the solder will break down at some point but I havent had trouble thus far. I usually give the wires a good twist together before soldering. I'm all thumbs so crimping pins turns into @!#Γ—$!! If you know what i mean…lol
                                    deckingman
                                    @hayseed_byte,
                                    Hang on in there - you'll get there. If a 64 year old carpenter (me) can get get there, so will you. The best advice I can give is just to read through the documentation https://www.duet3d.com/wiki and if you can find the time have scan through this https://duet3d.com/wiki/G-code or at least book mark it for easy reference.
                                    Oh and as you've discovered, we're a pretty well behaved bunch on this forum on the whole - but yes, sometimes playing "Devil's advocate" as you put it, isn't the best way to elicit help.
                                    About the firmware. The Duet team actively seek user input and suggestions for features or improvement. These tend to get acted on promptly which results in frequent firmware updates and new features being added on a fairly regular basis. Whilst this is good for seasoned users, it can make it seem to be a bit daunting for new users who have to try and pick it all up from scratch. Just remember that because a feature exists, it doesn't mean you have to use it. Stick to the basics to start with then play around with some of the more advanced features once you get the machine up and running.
                                    BTW, using a pair of needle nosed pliers to make the initial crimp then finishing off with the proper tool works well for me. I can never get the cable, connector and crimping tool all in the right place to start with.
                                    HTH
                                    • elmoretundefined
                                      elmoret
                                      I think a bigger issue with those connectors is that they're quite a bit larger in footprint. It is already difficult to fit a Duet into some printers, and changing to those connectors would probably add a half inch in each direction.
                                      Also a lot of printers come with Dupont or Molex KK connectors already, so they'd have to be cut off to use those terminals. All of the stepper motors we sell come with Dupont connectors on the cable, for example.
                                      We at Filastruder are working on a solution, a 6 inch pigtail with Molex KK on one side and screw terminals on the other. That way folks that don't already have compatible connectors and don't want to crimp have a solution without forcing everyone else to larger boards and/or cutting off perfectly good connectors.
                                        hayseed_byte
                                        @elmoret:
                                        Ok, the footprint thing makes sense. I'm in the planning stages of building a control panel for my printer with panel-mount connectors for the wiring so pigtails would be useful. Probably use those green connectors (should really find out the name of 'em).I've got about 500 feet of 22/4 AWG shielded alarm cable and tons of 20/2 AWG sensor cable so I'm probably covered. πŸ™‚ I'll definitely be going back to Filastruder (that's where I bought my Duet Wifi) when I decide what I'm upgrading next.
                                        Also, I just managed to print a bed calibration thing so thanks so much for all the help. My homeall.g file had "G92 Z2.5" at the end of it for some reason. Changed it to "G92 Z0.3" and it's working great. Now I need to think of something to print. Thanks again, guys.
                                        • PlasticMetalundefined
                                          PlasticMetal
                                          I don't know if it's the "common" name, but equipment I used to work on used those green connectors under the "Phoenix Contact" brand. Ever since, I have since just referred to them as "Phoenix" connectors.
                                          • JRDMundefined
                                            JRDM
                                            Molex calls those pluggable terminals "RF" series. They're good for 10 to 16 amps depending on the specific variation. It's overkill for motors, hot ends, fans and switches which run 3amps or less. KK looks to be good for up to 4A, likely depending on product variants. KK is a lot cheaper than RF too, some RF go for $1 per contact on the plug side, a little less on the receptacle side, so the costs can really add up for 5 motors, 2 hot ends and lots of fans and switches.
