    M600 - prevent power cut of motors
    289
    • tak21undefined
      tak21
      I want to use M600 in my slicer to make color changes with a single extruder.
      It works flawless - if I am fast enough / close enough to the printer to do the change before "something" shuts down the motors and cuts the temperatures.
      What I do not know (and do not find information about) is this "something".
      What script / service / ... is shutting down the heaters and motors after some time if "nothing happens"?
      Can I change the behaviour? (E.g. motor shut down: NOOOO, bed shutdown: please not, extruder shutdown: yes).
      Thank you in advance!
      chrishammundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @tak21
        @tak21 Sounds like you have a motor idle current factor configured, try to set it to 100% in your config. See M906 I.
        Duet software engineer
        tak21undefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @tak21
          @tak21 idle current reduction will reduce current to the motor after 30 seconds by default. However, if the heaters are shutting down, that must be something else. Does your filament-change.g file if you have one, or your pause.g file if you don't, turn heaters off?
            Can you share your config.g and pause.g or filament-change.g file? Can you also share your firmware version?
            • tak21undefined
              tak21 @Phaedrux
              @Phaedrux
              config.g
              pause.g
              filament-change.g
              03-Change_Filament.txt
              Duet Web Control 3.4.4
              RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.4
              @all: From your reactions I assume, that this is not a standard behaviour. As I used - as a base a configuration - a Caribou3d 320 config including macros I will now search for a macro / service which is not comming ootb and triggers this behaviour.
              Question please: if I would want to implement a "shut down the heaters if nothing happens for some time", where would I start to implement it?
              • tak21undefined
                tak21 @chrishamm
                @chrishamm I think I did not configure this as the documentation says: do not use it.
                  @tak21 said in M600 - prevent power cut of motors:
                  In daemon.g
                  • tak21undefined
                    tak21 @dc42
                    @dc42 Thank you! I found it 🙂
                    • Phaedruxundefined Phaedrux has marked this topic as solved
