    Power recover wrong last position
    3.9k
    • DR8undefined
      DR8
      Yeah I know but it's like is not respecting this. Another huge problem that I have is that after X Y Z are positioned, the extruder is trying to extrude a huge amount of filament at a huge speed. The filament is getting grinded and that's all. Hmm, I really don't know where should I start with everything
      • resamundefined
        resam
        The extruder thing sounds like you are mixing absolute vs. relative extruder moves: M82 and M83.
        • DR8undefined
          DR8
          @resam:
          i have M83 everywhere… Is power recover working for you?
          • resamundefined
            resam
            What slicer are you using? Cura defaults to absolute extruder moves - but you are using relative in your code.
            • DR8undefined
              DR8
              yes I was thinking about this that this is my problem. i ll give a try tmr using slic3r. but… i don t know what to say, there must be a solution for working with any slicer available.
              • DR8undefined
                DR8
                So I've tried power failure feature with a gcode generated by slic3r and the extruder does not have any problems now. But the problem with the X axis persist. If i have G28 in ressurect-prologue.g the print will be resumed about 2mm into the print so it will hit the print. If I have G28 X Y the print will restart about 2 mm above the print.
                  Are you certain that the resurrect.g file was created when you lost power, and not some time earlier when you paused the print? If there isn't enough power to move the head up 3mm, perhaps there isn't enough power to save the resurrect.g file either. This line in resurrect.g:
                  M26 S48738 P0.000
                  tells me that the print was stopped between moves, rather than in the middle of a move as I would expect with a power failure. Also the header:
                  ; File "cilindru5.gcode" resume print after print paused at 2017-11-06 13:04
                  says it was created due to a pause, not a power failure.
                  Try removing the M913 X0 Y0 from the start of your power fail script. This should be OK in beta 6 but wasn't in beta 4.
                  • DR8undefined
                    DR8
                    I tried again. This is the gcode. I'm sure ressurect.g has time to be created
                    ; File "cubsl.gcode" resume print after power failure at 2017-11-07 10:36
                    M140 S55.0
                    G10 P0 S200 R0
                    T0 P0
                    M98 Presurrect-prologue.g
                    M106 P0 S1.00
                    M106 P2 S1.00
                    M106 P3 S0.00
                    M106 P4 S0.00
                    M106 P5 S0.00
                    M106 P6 S0.00
                    M106 P7 S0.00
                    M106 P8 S0.00
                    M106 S255.00
                    M116
                    M290 S0.000
                    G92 E0.00000
                    M83
                    M23 cubsl.gcode
                    M26 S22706 P0.430
                    G0 F6000 Z5.001
                    G0 F6000 X116.30 Y99.47
                    G0 F6000 Z3.001
                    G1 F2400.0 P0
                    M24
                    I placed a piece of sticky band where my Z level was when the power droped. And with G28 in ressurect-prologue.g clearly the Z is going way down when the print is restarting.(I'm testing without extruding filament to not damage something). Can my resume.g file somehow influent this?
                    ; resume.g
                    ; called before a print from SD card is resumed
                    G1 R1 Z5 F6000 ; go to 5mm above position of the last print move
                    G1 R1 ; go back to the last print move
                    M83 ; relative extruder moves
                    G1 E1 F3600 ; extrude 1mm of filament
                    • DR8undefined
                      DR8
                      I have changed my last part of ressurect.g code from:
                      G0 F6000 Z5.001
                      G0 F6000 Z3.001
                      G1 F2400.0 P0
                      M24
                      to
                      G0 F6000 Z5.001
                      G0 F6000 Z5.001
                      G1 F2400.0 P0
                      M24
                      So the height of the object at the moment of power outage is 3mm(from DWC) . After G28 ressurect.g tells to the head to go 2mm above the print (5mm) but now 5mm from DWC is actually the height of the print( witch was 3mm in reality. So datas from DWC does not correspond with reality). Now, this is when the problem begin. Ressurect.g tells to the head to go down by 2mm and the print head will hit the print. I tried to change G0 F6000 Z5.001 with G0 F6000 Z7.001 and G0 F6000 Z3.001 with G0 F6000 Z5.001 and the print head now will go for real 2mm above the print, it will come down at 5 (in reality is 3) and start printing and everything is fine but after two seconds or so something is telling to the head to go again 2 mm down. So it's like DWC is always offset with 2mm from the real values. This happens only after the power outage. Otherwise everything is fine. My steps/mm are calibrated and the gantry is not going down when the power drops.
                        It sounds to me that there is a difference of 2mm in where the printer thinks Z=0 is after you home it in resurrect-prologue.g. If you turn the printer on and send "M98 Presurrect-prologue.g" instead of pressing the home all button, does it home correctly - in particular, is the Z height correct?
                        • DR8undefined
                          DR8
                          I turned on the printer, I sent M98 Presurrect-prologue.g and the printer did a normal home procedure. My normal home all procedure is this:
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool on Sat Oct 28 2017 12:36:25 GMT+0300 (GTB Daylight Time)
                          ; Relative positioning
                          G91
                          ; Lift Z
                          G1 Z5 F6000
                          ; Course home X or Y
                          G1 X-205 Y-205 F6000 S1
                          ; Course home X
                          G1 X-205 S1
                          ; Course home Y
                          G1 Y-205 S1
                          ; Move away from the endstops
                          G1 X5 Y5 F1000
                          ; Fine home X
                          G1 X-205 F360 S1
                          ; Fine home Y
                          G1 Y-205 S1
                          ; Move Z down until the switch triggers
                          G1 Z-255 F1000 S1
                          ; Absolute positioning
                          G90
                          ; Tell the firmware where we are
                          G92 Z2.5
                          ; Uncomment the following line to lift the nozzle after probing
                          G1 Z5 F100
                          So after "M98 Presurrect-prologue.g" Z axis stays at 5mm height because this is what homeall.g is telling to do. After I run ressurect.g the Z axis is rising from 5mm (home position of Z) to let's say 10 mm where the print was intrerupted. And then goes gown at 8. This is totally wrong. It should go up at 12 and then go down at 10.
                          It's frustrating. I have 30 intrerruptions to make this work and I still can t manage what s wrong.
                            After homing Z, do you normally use the Z probe to do any sort of calibration or bed compensation or to set the Z=0 height before printing?
                            • DR8undefined
                              DR8
                              Ok, so the problem was
                              G92 Z2.5
                              this line of gcode from homeall.g .I have disabled it and now it's working great. I can't believe, such a thiny detail… But now I understand the point.
                              Now, how can I make to have the ressurect.g file to be saved automatically to SD Card?
