    End stop to trigger event or Multiple Filament sensor events
    • chickenwomanundefined
      chickenwoman
      I need an endstop switch to trigger a series of gcodes for an external buffer for the Palette Pro. I'm using a Duet Wifi with a Deux5 running Reprap3.4.5. I have it set up as a filament sensor M591 D0 P1 C"duex.e2stop" S1 which calls the filament-error.g file that has
      M220 S5 ; set speed 5%
      G4 S5 ;delay 5 seconds
      M220 S100 ; set speed 100%
      This works great but then I cant configure a normal filament runout sensor. Is there a way to have multiple runout sensors with different events or to configure the endstop to trigger an event? Here's the external buffer I'm using. https://www.thingiverse.com/thing:4815921
        jay_s_uk @chickenwoman
        @chickenwoman could you not just program a trigger using M581?
        chickenwomanundefined 1 Reply Last reply Reply Quote 0
          chickenwoman @jay_s_uk
          @jay_s_uk
          Thanks! I think I have this right. It seems to be slower executing the M220 S100 in my trigger file. I think I have this set right. There might be a better way but it works!
          M950 J0 C"duex.e2stop"
          M581 T7 P0 S0
          In my trigger7.g file I have
