    SBC Problem
    512
    • Macwolfundefined
      Macwolf @dc42
      @dc42 said in SBC Problem:
      Do you mean that it runs OK in standalone mode, but doesn't run properly in SBC mode? If that's what you mean, are you certain that the config.g and homing files you are using on the SD card in the SBC are identical to the ones you used on the SD card in the Duet when you ran in standalone mode?
      Yes the files are idendical
      the config is of course a bit different (lan settings)
      • Macwolfundefined
        Macwolf
        with the 3.5beta 1 the SBC mode works.
        Z moves, but there are still bugs.
        I'm looking forward to the 3.5 final
          dc42 administrators @Macwolf
          @Macwolf I'm not certain this is the problem, however M92 takes only a single Z parameter even if you have multiple Z drivers.
          Macwolfundefined 1 Reply Last reply Reply Quote 0
          • Macwolfundefined
            Macwolf @dc42
            what do you mean by a parameter? a small example?
            M92 Z640 ; only ?
              Phaedrux Moderator @Macwolf
              @Macwolf said in SBC Problem:
              M92 Z640 ; only ?
              correct
              • Macwolfundefined
                Macwolf @Phaedrux
                the error message is gone, only the speed of the Z axis is at 0.5mm/s is that due to the beta status?Z-Speed.jpg
                  M566 X566.00 Y566.00 C2 Z25.00:25.00:25.00 E300:300:300:300		                ; Set maximum instantaneous speed changes (mm/min)
                  M203 X35000.00 Y35000.00 Z3000.00:3000.00:3000.00 C5000 E7200:7200:7200:7200  ; Set maximum speeds (mm/min)
                  M201 X6000.00 Y6000.00 Z300.00:300.00:300.00 C500 E10000:10000:10000:10000			      ; Set accelerations (mm/s^2)
                  M906 X2000 Y2000 Z1500:1500:1500                            ; Set motor currents (mA) Idle motion motors to 30%
                  You should remove the multiple values for the Z axis in all of these commands. It is set per axis. The only time multiple values are required is for extruders as they are independent axis.
                  At what point are you seeing this speed?
                  Macwolfundefined 2 Replies Last reply Reply Quote 0
                  • Macwolfundefined
                    Macwolf @Phaedrux
                    @Phaedrux said in SBC Problem:
                    when homing above at "requested speed"
                    and of course the bed that moves in slow motion. Z also moves at 0.5mm/s when moving
                    • Macwolfundefined
                      Macwolf @Phaedrux
                      Great problem solved
                      • Phaedruxundefined Phaedrux has marked this topic as solved
                        Great. If you have any more questions, start a new thread and we'll be glad to help.
