Part Cooling Fan not working
    TRATOON
    My part cooling fan is always running at a certain speed and doesn't change at all with commands (M106) or using the DWC.
    Here is my config:
    ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
    ; generated by RepRapFirmware Configuration Tool v3.3.12 on Mon Sep 05 2022 02:51:18 GMT-0700 (Pacific Daylight Time)
    G4 S5
    M550 P"Duet 3" ; set printer name
    M569 P121.0 S0 ; physical drive 121.0 goes forwards
    M584 X0.0 Y0.1 Z0.2:0.3 E121.0 ; set drive mapping
    M92 X80.00 Y80.00 Z800.00 E409 ; set steps per mm
    M566 X900.00 Y900.00 Z60.00 E3000 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E7200 ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E6000 ; set accelerations (mm/s^2)
    M906 X800 Y800 Z800 E1100 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout ; Set idle timeout
    M671 X290:290:40:40 Y0:270:0:270 P0.5
    M208 X295 Y320 Z250 S0 ; set axis maxima
    M574 X2 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin io0.in
    M574 Y2 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io1.in
    M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
    M558 P9 C"121.io0.in" H5 F600 T12000 A2 S0.03 R0.4 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-50 Y-15 Z4
    M557 X15:295 Y5:315 S35 ; define mesh grid
    M591 D0 P3 C"121.io1.in" R60:140 S1 ; filament monitor
    M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
    M143 H0 S100 ; set temperature limit for heater 0 to 120C
    M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0
    M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
    M143 H1 S500 ; set temperature limit for heater 1 to 450C
    M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
    M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
    M563 P0 S"E3D Hemera with Volcano" D0 H1 F0 ; define tool 0
    M912 P0 S-10
    G4 S5
    M591 D0
    M570 H1 P15 T30 ; An anomaly on heater 1 must persist for 4 seconds, and must be greater or less than 15C from the setpoint, to raise a heater fault.
    M501
      Have you used that fan successfully elsewhere to know that it accepts PWM speed control?
      You can try altering the M950 Q parameter higher or lower to see if you get better control.
      undefined 1 Reply Last reply 5 Jan 2023, 04:39 Reply Quote 0
        TRATOON @Phaedrux
        @Phaedrux I have already tried increasing Q value (250, 10, 5000, 1000, 10000, 100000, etc.) I have tried a known good fan, still 100%. I just read this post https://forum.duet3d.com/topic/18350/duet-toolboard-fan-issue and the user had a similar problem they said that they put their fan on the PWM pin. Right now, I have a two-wire fan on out 1 connected to GND and VOUT is this correct or do I switch wiring.
          3f6920da-0476-4f38-9659-b5fb9d072c02-Screen Shot 2023-01-04 at 10.47.59 PM.png Screen Shot 2023-01-04 at 10.47.59 PM.png
          How exactly is your fan wired?
          undefined 1 Reply Last reply 5 Jan 2023, 04:52 Reply Quote 0
            TRATOON @Phaedrux
            @Phaedrux My part cooling fan has + wire to out 1 +VOUT and the - wire to GND it's a two-wire fan.
              Then yes, you need to switch the - wire to the pin labeled "out1" on the wiring diagram, which is the pwm capable pin.
              Attaching the negative wire to ground will just be always on.
              • undefined TRATOON marked this topic as a question 5 Jan 2023, 06:02
              • undefined TRATOON has marked this topic as solved 5 Jan 2023, 06:02
              1 out of 6
