    Scara Setup
    13.8k
    • Billhc83undefined
      Billhc83
      After removing XY offset the web interface reports x11 y13 when the arm is rotated to the 0 angle( both arms in line in the middle of the movement range)
      Here is a video of the behavior of a g1 s2 x move after homing. as you can see the distal angle does not remain the same. I believe the C parameter in the video was set to -1 I have tried a variety of values without any change.
      https://youtu.be/vuMC6BDucdE)
      Another video showing homing behavior and crash after using jog button
      https://youtu.be/8wLSmmAf0dg
        I was wrong about G1 S2 moves. These moves are defined as raw motor moves. So it is correct that the distal joint arm angle changes when you do a G1 S2 X move.
        During proximal homing, to avoid the possibility of the distal joint reaching the end of its travel, I suggest you command both motors. For example:
        G91 ; relative movement
        G1 S1 X300 Y-300 F3000 ; home proximal joint
        One possible issue I can see with this is that the distal endstop switch will be active too, so if the distal arm is at the end of its travel against the endstop switch when you start the homing move, then the proximal homing move will not be completed. You could command a small anticlockwise movement of the distal arm first to avoid this possibility.
        In the second video, you pressed the Z-10 button. So it tried to move the arm down into the bed. However, any software axis limits you set with M208 ought to be obeyed.
        The x11 y13 position reported after homing is obviously wrong, so I think this explains the unwanted distal arm movement in your second video. Please share your config.g file. Also, please can you home all axes, check that the homing buttons are all blue at the end, and report the output of M114.
        • Billhc83undefined
          Billhc83
          After homing all buttons do indeed turn blue. This is the positions of the axis when sitting at the endstops after homing:
          11:18:24 AM
          M114
          X:95.221 Y:-58.365 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 Count -5695 -2401 0 User 95.2 -58.4 0.0
          The second video was not great At the end when I press the z-10 the arms also moved quickly as well and crashed.
          Config:
          M111 S0 ; S0 Debugging off S1 Debugging on
          M550 scara ; Machine name (can be anything you like)
          M551 Preprap ; Machine password (used for FTP)
          M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x42 ; MAC Address
          ;*** Adjust the IP address and gateway in the following 2 lines to suit your network
          M552 P192.168.1.118 ; IP address (0 = use DHCP)
          M554 P192.168.1.254 ; Gateway
          M553 P255.255.255.0 ; Netmask
          G21 ; Work in millimetres
          G90 ; Absolute moves
          M83 ; Relative extrusion
          ;Limits
          M208 X0 Y0 Z0 S1 ; Min
          M208 X100 Y100 Z150 S0 ; Max
          M574 X1 Y1 Z1 S1 ;
          ; Drives - Axis and motor configuration
          M569 P0 S0 ; Drive 0 (X) goes forwards
          M569 P1 S1 ; Drive 1 (Y) goes forwards
          M569 P2 S0 ; Drive 2 (Z) goes forwards
          M569 P3 S0 ; Drive 3 (E0) goes forwards
          M92 X67 Y28.25 ;Steps per degree
          M92 Z400 E550 ; Steps per mm
          M566 X300 Y300 Z15 E75 ; Set maximum instantaneous speed changes (mm/min)
          M203 X2000 Y2000 Z300 E1500 ; Set maximum speeds (mm/min)
          M201 X300 Y300 Z250 E800 ; Set accelerations (mm/s^2)
          M906 X1000 Y1000 Z1000 E1000 I60 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M669 K4 P111.4 D100.4 A-85:85 B-85:85 C-1:0:0 S150 T0.1 X0 Y0;
          • Billhc83undefined
            Billhc83
            Davis is machinePos the coordinates reported in the web interface? Trying to work through the math….
              Hi Bill,
              One problem I have spotted is that the crosstalk factors must currently be specified in motor steps, not amounts of movement. In other words, your proximal to distal crosstalk factor of -1 means that each forward step of the proximal motor needs to be countered by one reverse step of the distal motor. As you are using different steps/mm for your proximal and distal arms, -1 is not correct for your machine. I think the correct value is -67/28.25 instead.
              Thinking about it, it would be more logical to make the crosstalk based on amount of movement instead so as to be independent of the steps/mm. I'll make this change in the next 1.20 beta version.
              • Billhc83undefined
                Billhc83
                Ok thanks I'll give it a shot
                I think I will try this on my duet Wi-Fi just to make sure it is not just a problem with using the 0.6 board
                • Billhc83undefined
                  Billhc83
                  I agree that cross talk based on movement would be better.
                  I think there may be a issue with the minRadius calculation (I could be wrong of course). When I input my values into the calculation I come up with a number that I do not believe is correct. Since my scara has limited movement (everything forms a right angled triangle at the limits because it can only rotate 90 degrees from 0) it is very easy to calculate some of the values. For instance the minRadius of my arm I believe is just the hypotenuse of the triangle it forms. I have a value of 150 or so for min radius based on this. When i put my numbers into the code I get a value of 211 or so(I may have done this wrong who know's just trying to pick away at things). My max radius is only 210.8. Let me know what you think about this.
                    You are right, the minimum radius calculation is wrong. Thanks for pointing this out. I've just corrected it in the source code and the next 1.20 beta will include the fix. I've also changed the way the crosstalk factors work, to relate the distances moved instead of the motor steps - in degrees for the arms and in mm for Z.
                    • Billhc83undefined
                      Billhc83
                      So I have switched everything over from the v0.6 to my wifi and I won't say everything works as expected but everything works. So there is definitely something that doesn't work with the v0.6. Jogging buttons on the web interface do not result in crazy movements, but still not the movements I would expect. Are the jog buttons going to arm move angles or coordinates? I still have not been able to get the proper movements I am expecting. Homing coordinates still do not seem right to me. Homing now reports the same numbers as before
                      2:38:58 PM
                      M114
                      X:95.221 Y:-58.365 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count -5695 -2401 0 User 95.2 -58.4 0.0
                      I am running all the latest firmware and web control files. When I try to print a test file I get a bunch of errors from DWC, and cannot connect until the file is finished. Is there a way to see what the errors say? They seem to go away before I can copy them.
                      I will keep playing with this now that I can get some movements.
                      Thanks again
                        The error messages that pop up in DWC can be viewed on the GCode Console page. You can also configure how long they remain as popups before they time out.
                        The jog buttons should jog the XY coordinates.
                        SCARA support is currently working well on at least 2 printers that do not require crosstalk parameters in the M669 command.
                        As you are now running on a Duet WiFi, I'll make a pre-release 1.20beta7 release available for you to try when I am back in the office.
                        • Billhc83undefined
                          Billhc83
                          As my arms only turn 90 degrees i would expect my home position to be something like x -110 (proximal arm length)y -100(distal arm length). Does this make sense to you?
                            With zero X and Y origin offset in the M669 command, X0 Y0 is the location of the proximal joint, and +X is the direction that the proximal arm points at angle zero. So if both arms home to 90 degrees clockwise, then X= -distal arm length and Y= -proximal arm length sounds right to me. This is assuming that you don't have any other arm movement commands in homeall.g after the homing move, and that you have corrected the crosstalk factor to allow for the different steps/mm as we discussed previously.
                            Please try the following:
                            1. With power off, set both arms at 0 degrees. This is the position that the firmware assumes at power on.
                            2. Power on. The web interface should report the position as X= sum of arm lengths, Y= 0. Does it? M114 should report the step counts as zero.
                            3. Send G91 followed by G1 S2 Y90 to move the distal arm clockwise 90 degrees. Does the web interface report the correct position?
                            • Billhc83undefined
                              Billhc83
                              With the arms at 0 the printer turns on and reports x = 210.7 y = 0. Lengths of the arms would be 211.8 as defined in config.
                              I think this happens on this command
                              maxRadius *= 0.995; Which gives the 210.741
                              M669 K4 P111.4 D100.4 A-85:85 B-85:85 C-2.37:0:0 S150 T0.1 X0 Y0;
                              7:52:36 PM
                              M114
                              X:210.741 Y:0.000 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count -365 -41 0 User 210.7 -0.0 0.0
                              Sending g91 followed by g1 s2 y90 rotates the distal arm clockwise 90 degrees. The web interface reports x = 100.3 y=89.3. I would expect x=111.4 y=100.4 or something close to this?
                                I can see what's happened. The original position is outside maxRadius, so the firmware has "corrected" it to be within maxRadius as if it were a position commanded by the user, by assuming the distal arm is rotated clockwise a few degrees (hence the motor step count of -41) and the proximal arm is rotated the same number of degrees clockwise. That's why the reported position doesn't agree exactly with the actual position.
                                When you home the printer, what is the reported position now?
                                • Billhc83undefined
                                  Billhc83
                                  11:18:00 AM
                                  M114
                                  This is with the printer sitting at the homing switches, same as before.
                                    Your config says the homing positions are at -85deg for each arm. So by my calculations the position should be:
                                    X = P * cos(85) + D * cos(85+85) = -89.17mm
                                    Y = P * sin(85) + D * sin(85+85) = -128.41mm
                                    Do you agree?
                                    I think I see what is happening. When the distal homing switch is triggered, the firmware is setting the distal motor position without allowing for the effect that the proximal motor has on the distal joint position. I'll fix this in the next beta.
                                    As a temporary workaround, try this in your homeall.g file:
                                    1. G1 S1 X… move to home the proximal joint.
                                    2. G2 S2 X85 move to put the proximal joint at zero degrees.
                                    3. Then home the distal joint.
                                    • Billhc83undefined
                                      Billhc83
                                      There is a point where the crosstalk parameter starts to cause erratic movement. I will wait till I try your new release for further testing.
                                        OK, I've just built the new version, so I'll test it with a view to releasing it shortly.
                                        • Billhc83undefined
                                          Billhc83
                                          Installed new firmware this is results of M114 which is now right.
                                          8:47:37 PM
                                          M114
                                          X:-89.163 Y:-128.423 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count -5695 -8092 0 User -89.2 -128.4 0.0
                                          Homing then rotating back to 0 angle results in x211.8 y0 which is right. Sometimes says y0.1 ?
                                          OK David very good. I am able to send coordinates that make sense and it draws lines that are close to accurate. Can I expect the robot to change arm positions when just sending g1 commands or will it only work when running files?
                                            Once you have homed all axes, it should respond to normal G1 commands from any source. G1 moves will be in straight lines. G0 moves will generally be curved.
