    Scara Setup
    13.8k
      The error messages that pop up in DWC can be viewed on the GCode Console page. You can also configure how long they remain as popups before they time out.
      The jog buttons should jog the XY coordinates.
      SCARA support is currently working well on at least 2 printers that do not require crosstalk parameters in the M669 command.
      As you are now running on a Duet WiFi, I'll make a pre-release 1.20beta7 release available for you to try when I am back in the office.
      • Billhc83undefined
        Billhc83
        As my arms only turn 90 degrees i would expect my home position to be something like x -110 (proximal arm length)y -100(distal arm length). Does this make sense to you?
          With zero X and Y origin offset in the M669 command, X0 Y0 is the location of the proximal joint, and +X is the direction that the proximal arm points at angle zero. So if both arms home to 90 degrees clockwise, then X= -distal arm length and Y= -proximal arm length sounds right to me. This is assuming that you don't have any other arm movement commands in homeall.g after the homing move, and that you have corrected the crosstalk factor to allow for the different steps/mm as we discussed previously.
          Please try the following:
          1. With power off, set both arms at 0 degrees. This is the position that the firmware assumes at power on.
          2. Power on. The web interface should report the position as X= sum of arm lengths, Y= 0. Does it? M114 should report the step counts as zero.
          3. Send G91 followed by G1 S2 Y90 to move the distal arm clockwise 90 degrees. Does the web interface report the correct position?
          • Billhc83undefined
            Billhc83
            With the arms at 0 the printer turns on and reports x = 210.7 y = 0. Lengths of the arms would be 211.8 as defined in config.
            I think this happens on this command
            maxRadius *= 0.995; Which gives the 210.741
            M669 K4 P111.4 D100.4 A-85:85 B-85:85 C-2.37:0:0 S150 T0.1 X0 Y0;
            7:52:36 PM
            M114
            X:210.741 Y:0.000 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count -365 -41 0 User 210.7 -0.0 0.0
            Sending g91 followed by g1 s2 y90 rotates the distal arm clockwise 90 degrees. The web interface reports x = 100.3 y=89.3. I would expect x=111.4 y=100.4 or something close to this?
              I can see what's happened. The original position is outside maxRadius, so the firmware has "corrected" it to be within maxRadius as if it were a position commanded by the user, by assuming the distal arm is rotated clockwise a few degrees (hence the motor step count of -41) and the proximal arm is rotated the same number of degrees clockwise. That's why the reported position doesn't agree exactly with the actual position.
              When you home the printer, what is the reported position now?
              • Billhc83undefined
                Billhc83
                11:18:00 AM
                M114
                X:95.221 Y:-58.365 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count -5695 -2401 0 User 95.2 -58.4 0.0
                This is with the printer sitting at the homing switches, same as before.
                  Your config says the homing positions are at -85deg for each arm. So by my calculations the position should be:
                  X = P * cos(85) + D * cos(85+85) = -89.17mm
                  Y = P * sin(85) + D * sin(85+85) = -128.41mm
                  Do you agree?
                  I think I see what is happening. When the distal homing switch is triggered, the firmware is setting the distal motor position without allowing for the effect that the proximal motor has on the distal joint position. I'll fix this in the next beta.
                  As a temporary workaround, try this in your homeall.g file:
                  1. G1 S1 X… move to home the proximal joint.
                  2. G2 S2 X85 move to put the proximal joint at zero degrees.
                  3. Then home the distal joint.
                  • Billhc83undefined
                    Billhc83
                    There is a point where the crosstalk parameter starts to cause erratic movement. I will wait till I try your new release for further testing.
                      OK, I've just built the new version, so I'll test it with a view to releasing it shortly.
                      • Billhc83undefined
                        Billhc83
                        Installed new firmware this is results of M114 which is now right.
                        8:47:37 PM
                        M114
                        X:-89.163 Y:-128.423 Z:0.000 E0:0.0 E1:0.0 E2:0.0 E3:0.0 E4:0.0 E5:0.0 E6:0.0 E7:0.0 E8:0.0 Count -5695 -8092 0 User -89.2 -128.4 0.0
                        Homing then rotating back to 0 angle results in x211.8 y0 which is right. Sometimes says y0.1 ?
                        OK David very good. I am able to send coordinates that make sense and it draws lines that are close to accurate. Can I expect the robot to change arm positions when just sending g1 commands or will it only work when running files?
                          Once you have homed all axes, it should respond to normal G1 commands from any source. G1 moves will be in straight lines. G0 moves will generally be curved.
                          • Billhc83undefined
                            Billhc83
                            I knew that was not clear enough question. If I were to command it to move to a coordinate that would require the use of the opposite distal/proximal arm angle should it switch. Also should I be able to manually command it to go to positions past the min radius.
                              If you give it a G0 command that requires an arm mode switch, then it should switch. A G1 command won't because G1 commands are supposed to be straight line movements. However, my own SCARA printer is only capable of one arm mode, so that is untested.
                              Positions below the min radius or above the max radius are unreachable, so if you command movement to such a position, the destination coordinate will be changed to an achievable position.
                              • Billhc83undefined
                                Billhc83
                                Just wanted to thank you again for helping with this David. I was able to get things dialed in fairly well using M579 to scale the y axis by 1.06. Further testing needed but I have confidence that this will work for me. Cross talk seems to be working with a value of -1, anything too far away from -1 get out whack? I have test printed (with a pen) a number of cubes rectangles and other shapes and designs with good results. Thanks again.
                                  I'm glad it's working for you. From what I understand of your machine, a crosstalk value of -1 should be exactly right.
                                  It should also work on your Duet 06, although the trig calculations will be somewhat slower so the maximum speed and/or segments/sec you can use may be lower.
                                  • Billhc83undefined
                                    Billhc83
                                    Ok I will switch it back over to the 0.6 and see what happens
                                    • DannyDefeundefined
                                      DannyDefe
                                      David
                                      it was interesting to see your Scara project from robotdiggs. I guess I was thinking along the same line and purchased this Scara from robotdiggs.
                                      I have it all wired up and I purchase a Duet wifi which should arrive tomorrow.
                                      https://www.robotdigg.com/product/1193/Closed-loop-Stepper-Motor-SCARA-Robot-Arm
                                        @DannyDefe:
                                        David
                                        It will be interesting to compare our experiences. You may find that you can get rid of the distal arm backlash just by replacing the distal arm belts with ones from the UK supplier that I used for the proximal arm belt, instead of replacing the belts and pulleys by GT2 ones. I suggest you still replace the 20 tooth pulley by a 16 tooth one, to get a higher steps per degree.
                                        Another upgrade I am considering is to replace the proximal and distal motors by 0.9deg ones.
                                          DannyDefe
                                          Thanks for your comments about backlash, but this model has virtually zero backlash. I'm using hybrid closed loop stepper motors which should be quite accurate for the scara
                                          Have a look at the photo and you can see some initial setup parameters.
                                          Do you have the config file for your current robotDiggs Scara, this might be helpful.
                                          I'm using external driver signals off of the header, how do you reassign these to x y and z.
                                          thanks Danny
                                          https://www.dropbox.com/s/27ekssq1lk9ntzd/scara%20robotdiggs.jpg?dl=0
                                          https://www.aliexpress.com/item/Smart-Closed-Loop-NEMA-23-Integrated-Stepper-Motor-with-Driver-Step-direction-57mm-36VDC-2N-M/32668576448.html
                                            Extern drivers must be connected to the expansion connector (I hope that is what you mean by "the header"). Use M584 to remap the XYZ axes to them, see https://duet3d.com/wiki/G-code#M584:_Set_drive_mapping. Depending on the drivers and how you have connected them, you may need to use the R1 parameter in the M569 commands to invert the Enable signal.
                                            Here is my config.g file:
                                            ; Configuration file for Duet Ethernet in SCARA printer (firmware version 1.19)
                                            M111 S0 ; Debug off
                                            M550 PRobotdigg SCARA ; Machine name
                                            M551 Preprap ; Machine password
                                            M552 S1 ; Enable networking
                                            M555 P2 ; Set USB output to look like Marlin
                                            M575 P1 B57600 S1 ; Set aux port baud rate and require checksum, for PanelDue
                                            M569 P0 S0 ; Drive 0 goes backwards X
                                            M569 P1 S1 ; Drive 1 goes forwards Y
                                            M569 P2 S0 ; Drive 2 goes backwards Z
                                            M569 P3 S0 ; Drive 3 goes backwards E
                                            ; Movement
                                            M669 K4 P160 D159.5 A-130:22 B-27:157.5 C0:0:0 X65 Y-175 S100 ; set SCARA mode and parameters
                                            M574 X2 Y2 Z1 S1 ; Define active high homing switches
                                            M92 X71.1111 Y100 ; Steps/degree for proximal and distal joints
                                            M92 Z1600 E106 ; Steps/mm for Z and E
                                            M208 S1 X0 Y-120 Z-1 ; Axis minima
                                            M208 X200 Y330 Z150 ; Axis maxima
                                            M350 X16 Y16 Z16 U16 E16:16 I1 ; x16 microstepping with interpolation
                                            M566 X500 Y500 Z100 E500 ; XYZE jerk (mm/min)
                                            M203 X4500 Y4500 Z600 E3600 ; Maximum speeds (mm/min)
                                            M201 X300 Y300 Z50 E1000 ; Accelerations (mm/s^2)
                                            M906 X1000 Y1000 Z1000 E1300 I30 ; Motor currents (mA) and motor idle percent
                                            M143 H1 S260 ; Maximum heater temperature
                                            M140 H-1 ; No bed heater
                                            M305 P1 T100000 B4138 C0 R4700 ; Thermistor parameters for heater 1
                                            M307 H1 A577.0 C199.0 D9.8 S1.00 B0
                                            M563 P0 D0 H1
                                            G10 P0 R00 S00 ; Set initial tool 0 active and standby temperatures to 0C
                                            M106 P1 S0 I0 F200 H1 T45 ; Fan 1 frequency, thermostatic control
                                            ; Z probe
                                            M558 P1 X0 Y0 Z0 F600 T10000 R0.4
                                            G31 P500 Z1.75
                                            M557 X25:175 Y-100:325 S25 ; grid for G29 probing
                                            M671 X-45:-300:-45 Y0:175:350 P1.0 ; adjusting screw positions, M6 screw = 1mm pitch
                                            ; Power fail not configured
                                            ; Pressure advance
                                            M572 D0 S0.5
                                            ; Misc
                                            M83
                                            T0
