    Return to position gcode
    Gcode meta commands
    562
    • Jeredundefined
      Jered @Jered
      @Jered
      What about using:
      G1 60 XYZ S2
      G1 60 XYZ R2
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • Jeredundefined
        Jered
        Doesn't seem to work 😞
        • OwenDundefined
          OwenD @Jered
          @Jered
          When you start a tool change, the positions are stored in slot 2 automatically.
          See G60
          So to get back there use
          G1 R2 X0 Y0 Z0 You probably don't need the XYZ as there's no offset being used
          If you wanted to go to a point 2mm above the Z position use
          G1 R2 X0 Y0 Z2
          Jeredundefined 1 Reply Last reply Reply Quote 0
          • Jeredundefined
            Jered @OwenD
            @OwenD
            So I added that and it looks like it is moving xyz to the 0,0 position every tool change.
            • Jeredundefined
              Jered @Jered
              @Jered
              Z is also going to zero.
              • OwenDundefined
                OwenD @Jered
                @Jered
                Please post the firmware version you're using and the macro you are calling the tool changes from.
                Also your tpre*.g tfree*.g tpost*.g files for the two tools
                • Jeredundefined
                  Jered @OwenD
                  @OwenD
                  firmware version 3.3
                  Original macro is:
                  G1 E-5 F5000
                  G91
                  G1 Z2 F1000
                  G90
                  G1 X328 Y306 F6000
                  G1 E10 F300
                  G1 E-30 F5000
                  G1 E-50 F500
                  G1 E-175 F5000
                  {IF NEWTOOL=0}T0
                  {IF NEWTOOL=1}T1
                  {IF NEWTOOL=2}T2
                  {IF NEWTOOL=3}T3
                  {IF NEWTOOL=4}T4
                  {IF NEWTOOL=5}T5
                  {IF NEWTOOL=6}T6
                  G1 E200 F5000
                  G1 E60 F1500
                  G91
                  G1 Y100 E50 F1000
                  G1 Y-100 F3000
                  G1 Z-2 F1000
                  G1 E3 F5000
                  G90
                  I am not using any of the Tool.g files currently. I am using simplify3d's tool change tab to add this to my gcode files. I added the command you sent me to the end of my tool change code to see what would happen.
                  To test the command G1 R command I added an extra 10 to the Z movement at the top of the macro to see if it would return back to the correct Z height. It does not. Just keeps adding.
                  Jeredundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                  • Jeredundefined
                    Jered @Jered
                    @Jered
                    Firmware now 3.4.5
                    Just upgraded.
                    • OwenDundefined
                      OwenD @Jered
                      @Jered
                      I really don't know anything about S3D or what happens if you don't use the tool change files, but...
                      Try this
                      Note: I don't know if you're using a tool changer so I don't know what you have to do to safely move to and from the pickup point
                      G60 S3 ; save position to slot 3
                      G1 E-5 F5000
                      G91
                      G1 Z2 F1000
                      G90
                      G1 X328 Y306 F6000
                      G1 E10 F300
                      G1 E-30 F5000
                      G1 E-50 F500
                      G1 E-175 F5000
                      {IF NEWTOOL=0}T0
                      {IF NEWTOOL=1}T1
                      {IF NEWTOOL=2}T2
                      {IF NEWTOOL=3}T3
                      {IF NEWTOOL=4}T4
                      {IF NEWTOOL=5}T5
                      {IF NEWTOOL=6}T6
                      G1 E200 F5000
                      G1 E60 F1500
                      G91
                      G1 Y100 E50 F1000
                      G1 Y-100 F3000
                      G1 Z-2 F1000
                      G1 E3 F5000
                      G90
                      G1 R3 X0 Y0 Z0 ; move back to slot 3 position
                      • Jeredundefined
                        Jered
                        Ok,
                        So when I use:
                        G1 R3 X0 Y0 Z0
                        I think it is causing it to go to 0,0,0 However, when I use:
                        G1 R3 X Y Z (I used your G60 S3 at the top) is seems to work!
                        That being said, the picture of the slicer generates is all kinds of F'd up. See pic bellow:
                        Should look like this:
                        I decided to run this anyway, with no filament and with a Z offset from the bed (don't want a crash) and it looks right. The slicer doesn't know how to handle the code apparently.
                        I also waited for the layer height to change before sending this.
                        I did have this tool change process in the tool.g files, and it works fine, however, if there is a problem, such as a filament jam, it makes it a pain to recover from. Everytime I click on a different tool, it runs the process. If there was a software switch to turn off the tool.g files for recovering a failed print or jam, then I would move this tool change process to the tool.g files.
                        Anyway, let me test this for a while and get back to you. Seems good though!
                        Ultimate goal is to add a purge/dump area to the printer.
                        I may make a video about this so that you can see more details if needed later.
                        • OwenDundefined
                          OwenD @Jered
                          @Jered
                          You can avoid running the tool change macros by using the P0 parameter
                          e.g T1 P0
                          Refer to the docs here
                          • Jeredundefined
                            Jered @OwenD
                            @OwenD
                            Thanks,
                            I guess I can write a macro for turning them on and off.
                            • OwenDundefined
                              OwenD @Jered
                              @Jered
                              You don't "turn it off"
                              You need to use the P0 parameter on every tool change where you don't want to run the tool change macros.
                              If you did this ....
                              T1 P0 ; select tool 1 but don't run the tool change macros
                              T0 ; select tool zero and run tool change macros
                              T-1 ; deselect all tools and run tool change macros
                              T0 P0 ; select tool 0 but don't run tool change macros
                              • Jeredundefined
                                Jered
                                I understand. I think this can be closed. I get it now.
                                I really appreciate your help!
                                You guys are the best!
                                • Phaedruxundefined Phaedrux has marked this topic as solved
