    DuetLapse3
    Third-party software
    20
    296
    30.1k
    • stuartofmtundefined
      stuartofmt @Proschi3D
      @Proschi78
      "Insufficient images for video to be created"
      In this case zero images. So the program threw an error.
      I'll see if I can clean up the logic / message in the popup.
      stuartofmtundefined 1 Reply Last reply Reply Quote 0
        stuartofmt @stuartofmt
        @stuartofmt
        While you are testing:
        -seconds 15 -dontwait will try to capture images every 15 seconds without the need to run a print job.
          @Proschi78 said in DuetLapse3:
          @stuartofmt
          I see the current layer, etc. only pictures are not made
          If you see current layer > 1 and no images then the images are not being captured.
          I need to see ther logfile (make sure you have -verbose set)
          The logfile can be downloaded by clicking on the logfile name in the Files tab.
          Proschi3Dundefined 1 Reply Last reply Reply Quote 0
          • Proschi3Dundefined
            Proschi3D @stuartofmt
            @stuartofmt
            The problem was the usb port. The snapshot works with camera2, but the picture is so dark that you can't see anything
            Love my Duet 3 Mini.
            https://www.instagram.com/proschi3d
            https://youtube.com/@proschi3d
            https://www.proschi3d.de
              @stuartofmt
              I would like to help but you need to provide details of what you are doing. At a minimum, please post the logfile with -verbose.
              If you are using usb then fswebcam is being used.
              If you are not getting images from the stream, then likely you have the wrong url in the commandline.
              In both cases - the quality of the image is down to the settings on the program that is serving those images. DuetLapse does not manipulate the images, it only copies and shows what is there.
              if fswebcam now works (before it did not) then something has changed.
              What do you want to use: fswebcam (usb) or streaming ? Lets stick with one as jumping around just muddies the waters.
              There are just too many combinations of software settings and cameras - some work together, some do not. This is all BEFORE DuetLapse.
              Proschi3Dundefined 2 Replies Last reply Reply Quote 1
                @stuartofmt I'll save the log today. I actually want to use the stream to take the pictures. The dark image was not made with the mjpeg streamer. It looks like he used something else. No idea why
                2023-01-14 11:29:12,549 - MainThread - DUETLAPSE3 LOGFILE
                2023-01-14 11:29:12,549 - MainThread - /home/pi/Duetlapse/RepetierServer/192-168-178-91/startup.log
                2023-01-14 11:29:12,549 - MainThread - -------------------------------------------------------------------------------
                2023-01-14 11:29:12,550 - MainThread - ################### Options at start of this print job  #####################
                2023-01-14 11:29:12,550 - MainThread - # Environment
                2023-01-14 11:29:12,550 - MainThread - -duet  =  192.168.178.91
                2023-01-14 11:29:12,550 - MainThread - -basedir  =  /home/pi/Duetlapse
                2023-01-14 11:29:12,550 - MainThread - -poll  =  12
                2023-01-14 11:29:12,551 - MainThread - -instances  =  single
                2023-01-14 11:29:12,551 - MainThread - -logtype  =  both
                2023-01-14 11:29:12,551 - MainThread - -nolog  =  False
                2023-01-14 11:29:12,551 - MainThread - -verbose  =  True
                2023-01-14 11:29:12,552 - MainThread - -host  =  0.0.0.0
                2023-01-14 11:29:12,552 - MainThread - -port  =  8025
                2023-01-14 11:29:12,552 - MainThread - -keeplogs  =  False
                2023-01-14 11:29:12,552 - MainThread - -novideo  =  False
                2023-01-14 11:29:12,552 - MainThread - -deletepics  =  False
                2023-01-14 11:29:12,553 - MainThread - -maxffmpeg  =  2
                2023-01-14 11:29:12,553 - MainThread - -keepfiles  =  False
                2023-01-14 11:29:12,553 - MainThread - # Execution
                2023-01-14 11:29:12,554 - MainThread - -dontwait  =  False
                2023-01-14 11:29:12,554 - MainThread - -seconds  =  0
                2023-01-14 11:29:12,555 - MainThread - -detect  =  layer
                2023-01-14 11:29:12,555 - MainThread - -pause  =  no
                2023-01-14 11:29:12,555 - MainThread - -movehead  =  [0, 0]
                2023-01-14 11:29:12,555 - MainThread - -rest  =  1
                2023-01-14 11:29:12,556 - MainThread - -standby  =  False
                2023-01-14 11:29:12,556 - MainThread - -restart  =  False
                2023-01-14 11:29:12,556 - MainThread - # Camera
                2023-01-14 11:29:12,556 - MainThread - -camera1  =  usb
                2023-01-14 11:29:12,556 - MainThread - -camera2  =  stream
                2023-01-14 11:29:12,556 - MainThread - -weburl1  =  http://192.168.178.70:8081/?action=stream
                2023-01-14 11:29:12,557 - MainThread - -weburl2
                2023-01-14 11:29:12,557 - MainThread - # Video
                2023-01-14 11:29:12,557 - MainThread - -extratime  =  0
                2023-01-14 11:29:12,557 - MainThread - -fps  =  10
                2023-01-14 11:29:12,557 - MainThread - -minvideo  =  5
                2023-01-14 11:29:12,558 - MainThread - -maxvideo  =  0
                2023-01-14 11:29:12,558 - MainThread - # Overrides
                2023-01-14 11:29:12,558 - MainThread - -camparam1
                2023-01-14 11:29:12,559 - MainThread - -camparam2
                2023-01-14 11:29:12,559 - MainThread - -vidparam1
                2023-01-14 11:29:12,559 - MainThread - -vidparam2
                2023-01-14 11:29:12,560 - MainThread - # UI
                2023-01-14 11:29:12,560 - MainThread - -hidebuttons  =  False
                2023-01-14 11:29:12,560 - MainThread - # Special Functions
                2023-01-14 11:29:12,560 - MainThread - -execkey
                2023-01-14 11:29:12,561 - MainThread - -----------------------------------------------------------------------
                2023-01-14 11:29:12,561 - MainThread - ##########################################################
                2023-01-14 11:29:12,562 - MainThread - Will start capturing images on first layer change
                2023-01-14 11:29:12,562 - MainThread - ##########################################################
                2023-01-14 11:29:12,562 - MainThread - Video will be created when printing ends
                2023-01-14 11:29:12,563 - MainThread - or if requested from the browser interface or M117 DuetLapse3. message
                2023-01-14 11:29:12,563 - MainThread - ##########################################################
                2023-01-14 11:29:12,563 - MainThread - If running from a console using the command line
                2023-01-14 11:29:12,564 - MainThread - Press Ctrl+C one time to stop the program and create a video.
                2023-01-14 11:29:12,564 - MainThread - ##########################################################
                2023-01-14 11:29:12,564 - MainThread - url: http://192.168.178.91/rr_model?key=boards post: False
                2023-01-14 11:29:12,580 - MainThread - ###############################################################
                2023-01-14 11:29:12,580 - MainThread - Connected to printer at 192.168.178.91
                2023-01-14 11:29:12,580 - MainThread - Using Duet version 3.5beta1
                2023-01-14 11:29:12,580 - MainThread - Using  API interface rr_model
                2023-01-14 11:29:12,581 - MainThread - url: http://192.168.178.91/rr_gcode?gcode=M117 "" post: False
                2023-01-14 11:29:12,593 - MainThread - ##########################################################
                2023-01-14 11:29:12,593 - MainThread - ***** Started http listener *****
                2023-01-14 11:29:12,594 - gcodeLoop - ###########################
                2023-01-14 11:29:12,594 - gcodeLoop - Starting gcode Listener
                2023-01-14 11:29:12,595 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:12,595 - MainThread - Initiating with action set to start
                2023-01-14 11:29:12,595 - gcodeLoop - Getting Status
                2023-01-14 11:29:12,596 - MainThread - ++++++ start state requested ++++++
                2023-01-14 11:29:12,599 - MainThread - nextAction requested stopCaptureLoop
                2023-01-14 11:29:12,600 - MainThread - captureLoop is not running
                2023-01-14 11:29:12,600 - MainThread - nextAction satisfied waitforCaptureLoop
                2023-01-14 11:29:12,601 - MainThread - ++++++ Determining next logical action ++++++
                2023-01-14 11:29:12,596 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:12,604 - captureLoop - Starting Capture Loop
                2023-01-14 11:29:12,609 - MainThread - ++++++ Entering start state ++++++
                2023-01-14 11:29:12,609 - captureLoop - ****** Duet status changed to: Not yet determined *****
                2023-01-14 11:29:12,609 - MainThread - nextAction exiting normally
                2023-01-14 11:29:12,610 - captureLoop - ****** Print State changed to: Waiting *****
                2023-01-14 11:29:16,036 - Thread-1 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:17,625 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:17,626 - gcodeLoop - Getting Status
                2023-01-14 11:29:17,631 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:22,036 - Thread-2 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:22,657 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:22,657 - gcodeLoop - Getting Status
                2023-01-14 11:29:22,660 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:24,622 - captureLoop - ****** Duet status changed to: processing *****
                2023-01-14 11:29:24,623 - captureLoop - ****** Print State changed to: Capturing *****
                2023-01-14 11:29:24,624 - captureLoop - ****** Print State changed to: Capturing *****
                2023-01-14 11:29:24,624 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:29:24,625 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:29:24,643 - captureLoop - Calling function Status from Check for Pause with rr_model
                2023-01-14 11:29:24,643 - captureLoop - Getting Status
                2023-01-14 11:29:24,644 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:24,663 - captureLoop - Layer - Camera1: capturing frame 1 at layer 3 after layer change
                2023-01-14 11:29:24,664 - captureLoop - Created working directory: /home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1
                2023-01-14 11:29:24,666 - captureLoop - Calling function Jobname from renameworkingDir with rr_model
                2023-01-14 11:29:24,667 - captureLoop - url: http://192.168.178.91/rr_model?key=job.file.fileName post: False
                2023-01-14 11:29:24,684 - captureLoop - Renaming working directory: /home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts
                2023-01-14 11:29:24,712 - captureLoop - Command Failure: fswebcam --quiet --no-banner /home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts/Camera1_00000001.jpeg
                2023-01-14 11:29:24,712 - captureLoop - Error selecting input 0
                VIDIOC_S_INPUT: Device or resource busy
                2023-01-14 11:29:24,713 - captureLoop - !!!!!  There was a problem capturing an image !!!!!
                2023-01-14 11:29:24,713 - captureLoop - elapsed: 12.148980379104614
                2023-01-14 11:29:24,713 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:29:24,713 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:29:24,729 - captureLoop - Calling function Status from Check for Pause with rr_model
                2023-01-14 11:29:24,729 - captureLoop - Getting Status
                2023-01-14 11:29:24,730 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:24,745 - captureLoop - Layer - Camera2: capturing frame 1 at layer 3 after layer change
                2023-01-14 11:29:25,015 - captureLoop - Command Exception: ffmpeg -threads 1 -loglevel quiet -y -i  -vframes 1 -threads 1/home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts/Camera2_00000001.jpeg
                2023-01-14 11:29:25,015 - captureLoop - Command 'ffmpeg -threads 1 -loglevel quiet -y -i  -vframes 1 -threads 1/home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts/Camera2_00000001.jpeg' returned non-zero exit status 1.
                2023-01-14 11:29:25,016 - captureLoop - !!!!!  There was a problem capturing an image !!!!!
                2023-01-14 11:29:25,016 - captureLoop - elapsed: 12.45192813873291
                2023-01-14 11:29:25,016 - captureLoop - Calling function Status from unPause with rr_model
                2023-01-14 11:29:25,016 - captureLoop - Getting Status
                2023-01-14 11:29:25,016 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:27,686 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:27,687 - gcodeLoop - Getting Status
                2023-01-14 11:29:27,690 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:28,038 - Thread-3 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:32,714 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:32,715 - gcodeLoop - Getting Status
                2023-01-14 11:29:32,718 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:34,041 - Thread-4 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:37,037 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:29:37,038 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:29:37,055 - captureLoop - elapsed: 24.49109148979187
                2023-01-14 11:29:37,056 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:29:37,056 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:29:37,072 - captureLoop - elapsed: 24.507537603378296
                2023-01-14 11:29:37,072 - captureLoop - Calling function Status from unPause with rr_model
                2023-01-14 11:29:37,073 - captureLoop - Getting Status
                2023-01-14 11:29:37,073 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:37,742 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:37,743 - gcodeLoop - Getting Status
                2023-01-14 11:29:37,745 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:40,037 - Thread-5 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:42,771 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:42,771 - gcodeLoop - Getting Status
                2023-01-14 11:29:42,774 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:46,044 - Thread-6 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:47,801 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:47,806 - gcodeLoop - Getting Status
                2023-01-14 11:29:47,807 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:49,103 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:29:49,103 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:29:49,114 - captureLoop - Calling function Status from Check for Pause with rr_model
                2023-01-14 11:29:49,115 - captureLoop - Getting Status
                2023-01-14 11:29:49,115 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:49,128 - captureLoop - Layer - Camera1: capturing frame 1 at layer 4 after layer change
                2023-01-14 11:29:49,143 - captureLoop - Command Failure: fswebcam --quiet --no-banner /home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts/Camera1_00000001.jpeg
                2023-01-14 11:29:49,143 - captureLoop - Error selecting input 0
                2023-01-14 11:29:49,143 - captureLoop - !!!!!  There was a problem capturing an image !!!!!
                2023-01-14 11:29:49,144 - captureLoop - elapsed: 36.57973766326904
                2023-01-14 11:29:49,144 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:29:49,144 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:29:49,158 - captureLoop - Calling function Status from Check for Pause with rr_model
                2023-01-14 11:29:49,159 - captureLoop - Getting Status
                2023-01-14 11:29:49,159 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:49,172 - captureLoop - Layer - Camera2: capturing frame 1 at layer 4 after layer change
                2023-01-14 11:29:49,429 - captureLoop - Command Exception: ffmpeg -threads 1 -loglevel quiet -y -i  -vframes 1 -threads 1/home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts/Camera2_00000001.jpeg
                2023-01-14 11:29:49,430 - captureLoop - Command 'ffmpeg -threads 1 -loglevel quiet -y -i  -vframes 1 -threads 1/home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts/Camera2_00000001.jpeg' returned non-zero exit status 1.
                2023-01-14 11:29:49,430 - captureLoop - !!!!!  There was a problem capturing an image !!!!!
                2023-01-14 11:29:49,430 - captureLoop - elapsed: 36.866106033325195
                2023-01-14 11:29:49,430 - captureLoop - Calling function Status from unPause with rr_model
                2023-01-14 11:29:49,431 - captureLoop - Getting Status
                2023-01-14 11:29:49,431 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:52,043 - Thread-7 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:29:52,829 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:52,829 - gcodeLoop - Getting Status
                2023-01-14 11:29:52,832 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:57,859 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:29:57,859 - gcodeLoop - Getting Status
                2023-01-14 11:29:57,862 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:29:58,041 - Thread-8 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:30:01,457 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:30:01,458 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:30:01,477 - captureLoop - elapsed: 48.913480281829834
                2023-01-14 11:30:01,479 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:30:01,479 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:30:01,496 - captureLoop - elapsed: 48.932276010513306
                2023-01-14 11:30:01,497 - captureLoop - Calling function Status from unPause with rr_model
                2023-01-14 11:30:01,498 - captureLoop - Getting Status
                2023-01-14 11:30:01,499 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:30:02,888 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:30:02,888 - gcodeLoop - Getting Status
                2023-01-14 11:30:02,891 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:30:04,035 - Thread-9 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:30:07,918 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:30:07,919 - gcodeLoop - Getting Status
                2023-01-14 11:30:07,922 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:30:10,037 - Thread-10 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                2023-01-14 11:30:12,450 - Thread-11 - !!!!! http call: {'displayFiles': ['true']} !!!!!
                2023-01-14 11:30:12,451 - Thread-11 - list_dir called with path = /home/pi/Duetlapse/RepetierServer/192-168-178-91
                2023-01-14 11:30:12,451 - Thread-11 - Finished parsing the files directory
                2023-01-14 11:30:12,944 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:30:12,945 - gcodeLoop - Getting Status
                2023-01-14 11:30:12,948 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:30:13,530 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:30:13,530 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:30:13,549 - captureLoop - elapsed: 60.98456144332886
                2023-01-14 11:30:13,549 - captureLoop - Calling function Layer from oneInterval with rr_model
                2023-01-14 11:30:13,550 - captureLoop - url: http://192.168.178.91/rr_model?key=job.layer post: False
                2023-01-14 11:30:13,567 - captureLoop - elapsed: 61.002771615982056
                2023-01-14 11:30:13,568 - captureLoop - Calling function Status from unPause with rr_model
                2023-01-14 11:30:13,568 - captureLoop - Getting Status
                2023-01-14 11:30:13,568 - captureLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:30:14,677 - Thread-12 - !!!!! http call: {'displayVideo': ['true']} !!!!!
                2023-01-14 11:30:15,608 - Thread-13 - !!!!! http call: {'displayFiles': ['true']} !!!!!
                2023-01-14 11:30:15,608 - Thread-13 - list_dir called with path = /home/pi/Duetlapse/RepetierServer/192-168-178-91
                2023-01-14 11:30:15,610 - Thread-13 - Finished parsing the files directory
                2023-01-14 11:30:17,972 - gcodeLoop - Calling function Status from gcodelistener with rr_model
                2023-01-14 11:30:17,973 - gcodeLoop - Getting Status
                2023-01-14 11:30:17,978 - gcodeLoop - url: http://192.168.178.91/rr_model?key=state post: False
                2023-01-14 11:30:19,410 - Thread-14 - !!!!! http call: {'getfile': ['/home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts.log']} !!!!!
                2023-01-14 11:30:19,412 - Thread-14 - Trying to get file /home/pi/Duetlapse/RepetierServer/192-168-178-91/7123_1_Speed_rechts.log
                2023-01-14 11:30:19,444 - Thread-14 - application/octet-stream
                  @stuartofmt thanks for your help, i got it working
                    @Proschi78
                    Its important for other people reading these posts that they benefit from what works. That feedback is very helpful.
                    I can see, from the logfile that the usb camera ( -camera1 usb) was failing AND the stream camera (-camera 2 stream) was failing.
                    How did you get it working? Did you us the command line that I recommended ? If no - what did you use?
                      @stuartofmt use the following for the mjpeg streamer
                       python3 DuetLapse3.py -port 8025 -duet 192.168.178.91 -detect layer -weburl1 http://192.168.178.70:8081/?action=snapshot -camera1 web
                      How do I enable it to automatically generate a video when it ends?
                      pi@RepetierServer:~/Duetlapse $ 192.168.178.91 terminate - Terminating
                      192.168.178.91 nextAction - ++++++ Entering terminate state ++++++
                      192.168.178.91 terminate - captureLoop is not running
                      192.168.178.91 nextAction - nextAction exiting normally
                      192.168.178.91 terminate - Wait for video to complete
                      192.168.178.91 terminate - makeVideo is not running
                      192.168.178.91 terminate - *****  Cleaning up files for phase:  terminate  *****
                      192.168.178.91 terminate - ********* gcodeLoopState is 0 - Waiting to complete *********
                      192.168.178.91 Thread-332 - !!!!! http call: {'displayStatus': ['true']} !!!!!
                      192.168.178.91 terminate - !!!!! http listener stopped  !!!!!
                      192.168.178.91 terminate - Program Terminated
                      Killed
                      ^C
                        stuartofmt
                        I am pleased to announce the release of version 5.0.0 of DuetLapse3.
                        Thanks to the good graces of the Duet3D team, I will soon be developing against an SBC. This release is the first step towards a plugin. The UI is completely refactored and there are some new features as well (e.g. being able to set the maximum video length).
                        See the first post for download links
                        VERSION 5.0.x
                        Note .x releases are issued without documentation to correct minor issues e.g. a typo or edge-case logic error.
                        [1] Completely revised UI
                        [2] Added display of last captured image to UI
                        [3] Added ability to specify a config file with -file option This avoids the need for long command lines. Options in command line over-write those in config file
                        [4] Added -maxvideo. Limits the maximum length of video by varying fps as needed
                        [5] Added ability to change -fps -minvideo and -maxvideo in the UI
                        [6] UI gives indication of video creation status
                        [7] Changed logfile name on startup
                        [8] Sequential jobs are numbered
                        [9] Misc bug fixes
                        Enjoy and as always, feedback and suggestions are welcome.
                          @Proschi78
                          I have no idea. You did not use -verbose.
                          Instead of copy paste the log file its best to upload the logfile.
                          The logfile can be downloaded by clicking on the link for the logfile. The currently running logfile is the one at the top (shown highlighted in this example). Previous logfiles are below. You can use the -keepfiles option to maintain some history.
                            Proschi3D
                            ok i do it again with verbose
                            stuartofmtundefined 2 Replies Last reply Reply Quote 0
                              Version 5.0.3 has been posted to github. It has a few changes from the version I gave you access to. Mostly these are cosmetic but its best to be on this version.
                                stuartofmt @osterac
                                @osterac
                                Wanted to bring to your attention Verson 5.0.x.
                                I got side-tracked with some significant code re-arangement ( same functionality). The ability to set max video length is formally included.
                                Please let me know what you think.
                                osteracundefined 1 Reply Last reply Reply Quote 0
                                  Is everything running correctly now ?
                                    @stuartofmt I couldn't try it anymore. But the new version didn't start at all
                                      A logfile with -verbose will reveal all.
                                      • osteracundefined
                                        osterac @stuartofmt
                                        @stuartofmt said in DuetLapse3:
                                        @osterac
                                        @stuartofmt Thanks, I'll take a look!
                                        • osteracundefined
                                          osterac
                                          It doesn't seem to be making any videos for me. I see that the temporary folder is created during the print but no video. I'll attach a log file.
                                          481_1_overhang_test_mini.log.txt
                                            stuartofmt @osterac
                                            @osterac
                                            Thanks for the logfile. There may be two problems and a "condition".
                                            The likely problem.
                                            You start Duetlapse in standby state but nothing tells it to go to start state. As a result there is no attempt to capture images hence no video can be created.
                                            In the options:
                                            2023-01-24 17:40:55,863 - terminate - -standby  =  True
                                            The logfile shows DuetLapse entering standby state:
                                            2023-01-24 17:40:55,944 - terminate - ++++++ Entering standby state ++++++
                                            But there is nothing that takes it out of standby state. In fact, throughout most of the log, DuetLapse is simply looking for a command.
                                            In the logfile, towards the end of the print (I'm assuming), there is a command to DuetLapse
                                            2023-01-25 16:48:23,135 - gcodeLoop - M117 Command: DuetLapse3.completed
                                            Did you intended the gcode to take DuetLapse out of standby mode with:
                                            M117 DuetLapse3.start   ; start
                                            G4 S10
                                            Either , the command is missing from the gcode or DuetLapse did not "see" the command.
                                            The condition
                                            There are a few instances where there are network issues in the log. Most are sub-second (not uncommon in my experience). It is possible that DuetLapse did not see the start command because it was sent during a network issue. This would be plain bad luck 😞
                                            There is a network disconnect that lasts about 3 minutes. On reconnect, DuetLapse goes back to its previous (standby) state :
                                            2023-01-25 10:39:05,717 - gcodeLoop - Cannot connect to the printer
                                            <snip>
                                            2023-01-25 10:42:52,139 - checkforConnection - -----------------------  Reconnected to printer ----------------------
                                            <snip>
                                            2023-01-25 10:42:57,145 - nextAction - nextAction resuming after reconnect target = standby
                                            The same pattern occurs at 11:50
                                            The second problem
                                            At the end after the command to complete the print job; DuetLapse tries, correctly (for the first time), to get an image and make copies to satisfy the -extratime 2 option.
                                            There is an error because this command failed
                                            wget --auth-no-challenge -nv -O /home/pi/ftp/files/DuetLapse/octopi/192-168-1-8/481_1_overhang_test_mini/Camera1_00000102.jpeg "http://cam.local:8765/picture/1/current/"
                                            i.e. it could not get an image from the camera.
                                            I'm concerned about this for two reasons (1) Is the camera working / are the parameters correct and (2) I do not expect to see the image file being requested as number 102
                                            I recommend you verify that you can capture images using the following from the command line:
                                            wget --auth-no-challenge -nv -O ./test.jpeg "http://cam.local:8765/picture/1/current/"
                                            I will take a look and see why the image number is not what I expect. Its possible that I have a bug that somehow prevented attempts to capture images but the code logic does not change based on camera type.
                                            2023-01-25 16:48:31,220 - nextAction - Command Exception: wget --auth-no-challenge -nv -O /home/pi/ftp/files/DuetLapse/octopi/192-168-1-8/481_1_overhang_test_mini/Camera1_00000102.jpeg "http://cam.local:8765/picture/1/current/"  > /dev/null 2>&1
                                            2023-01-25 16:48:31,221 - nextAction - Command 'wget --auth-no-challenge -nv -O /home/pi/ftp/files/DuetLapse/octopi/192-168-1-8/481_1_overhang_test_mini/Camera1_00000102.jpeg "http://cam.local:8765/picture/1/current/"  > /dev/null 2>&1' returned non-zero exit status 1.
                                            2023-01-25 16:48:31,222 - nextAction - !!!!!  There was a problem capturing an image !!!!!
                                            2023-01-25 16:48:31,222 - nextAction - Copying last frame to extend video by 2 seconds
