    reduce the driving speed of the z-axis via the DWC
    Duet Web Control wishlist
    • axiomundefined
      axiom
      how can I reduce the driving speed of the z-axis when controlled via the DWC without affecting the speed of other functions (e.g. homing).
      OwenDundefined T3P3Tonyundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • OwenDundefined
        OwenD @axiom
        @axiom
        You can adjust the feed rate in "settings-Machine specific" but it applies to all axes
        You could also create a couple of macro buttons to temporarily reduce max speed on Z and restore as needed
        • T3P3Tonyundefined T3P3Tony moved this topic from Using Duet Controllers
          T3P3Tony administrators @axiom
          @axiom I have moved this to the wishlist section as @chrishamm may want to consider having feed rate by for the button settings in a future version.
            dc42 administrators @axiom
            @axiom said in reduce the driving speed of the z-axis via the DWC:
            Is there a reason why you want to reduce the speed of moving the axis below the maximum speed for that axis that you set in M203?
