Connecting thermocouple(s) to Sammy C21 Board
Is it possible to attach thermocouples through the daughterboards or otherwise to the Sammy C21 board or any other board apart from the 3HC?
The requirement is to attach 15 thermocouples and adding 3HC boards is not ideal since extra stepper outputs are not required. -
@sotpurk yes you could connect Duet3D thermocouple daughter boards to a SAMMYC21.
It should also be possible to connect more than two thermocouple daughter boards to a single Duet main board, if you have a spare iox.out pin to use as the CS pin for each additional thermocouple.
