BLTouch not really working
@jay_s_uk Yes they say M280 P0 S90 ; retract BLTouch and M280 P0 S10 ; deploy BLTouch
@modl so does using M401 and M402 by themselves work every time?
I tried reverting from RFF3.4.5 to 3.4.4 following the advice in the release notes because of some potential homing issues. It didn't solve the issue
@jay_s_uk They work every time at startup, but not after homing x and y
@modl that indicates that you either have a wiring issue or you have something in your homing files thats causing issues.
can you post homex.g and homey.g? -
@jay_s_uk So M401 and 402 actually work after homing x alone.
; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Mon Jan 09 2023 14:50:13 GMT+0100 (Central European Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-360 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 H2 X5 F6000 ; go back a few mm G1 H1 X-360 F360 ; move slowly to X axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.15 on Mon Jan 09 2023 14:50:13 GMT+0100 (Central European Standard Time) G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-1000 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 H2 Y5 F6000 ; go back a few mm G1 H1 Y-1000 F360 ; move slowly to Y axis endstop once more (second pass) G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
@modl so theres nothing in there that should stop M401 and M402 from working.
next is to look at your wiring and make sure nothing is being pulled etc -
Ok M401 and M402 don't work after homing y alone, could there be a short somewhere with y endstops or motors ? Or could an overload cause this?
@jay_s_uk Physically everything looks fine. And if i'm resetting the system, M401 and M402 will work at the exact same position
@modl can you home Y and then send
M558
and post the output? -
@jay_s_uk
At startupM558 Z Probe 0: type 9, input pin io4.in, output pin nil, dive height 5.0mm, probe speeds 120,120mm/min, travel speed 6000mm/min, recovery time 0.20 sec, heaters normal, max taps 1, max diff 0.03
After homing Y
@jay_s_uk I found the culprit !! I actually had an extruder wired the wrong way when i first powered the machine, I rewired it as soon as i found out but it's been getting really hot even if idle since then. I unplugged it from the board and the probing now works. How to know if the stepper is cooked ?
Thank you very much for all your replies and your guidance
Hope i didn't cook the driver...
@modl glad you found the culprit! if it gets very hot even when not in use thats not a very good sign at all. is RRF generating any warnings?
@jay_s_uk No RRF doesn't ring. I tested the coils resistance though one is .4 ohms the other is 4.8. I guess this one's cooked. Any way to know how the driver is doing except plugging in an other axis an changing config.g?
@modl thats probably the easiest way to test the driver. Thats the way i usually test drivers
@jay_s_uk OK I'll try that. Again thank you very much!
It was actually pretty fast, and the driver is doing fine
@modl fantastic!
