    Need Help CRtouch, update. Ender 3 Duet2 wifi
    322
    • Flynbrdundefined
      Flynbrd
      Got my system to home all with no issue. When running bed leveling I'm getting this error. I'm sure something in config is off.
      Warning: the height map has a substantial Z offset. Suggest use Z-probe to establish Z=0 datum, then re-probe the mesh.
      90 points probed, min error -0.608, max error 0.005, mean -0.318, deviation 0.144
      Height map saved to file 0:/sys/heightmap.csv
      2/1/2023, 11:24:10 AM Warning: Skipping grid point X=200.0, Y=180.0 because Z probe cannot reach it
      Warning: Skipping grid point X=200.0, Y=200.0 because Z probe cannot reach it
      2/1/2023, 11:23:29 AM Warning: Skipping grid point X=200.0, Y=140.0 because Z probe cannot reach it
      Warning: Skipping grid point X=200.0, Y=160.0 because Z probe cannot reach it
      2/1/2023, 11:22:47 AM Warning: Skipping grid point X=200.0, Y=100.0 because Z probe cannot reach it
      Warning: Skipping grid point X=200.0, Y=120.0 because Z probe cannot reach it
      2/1/2023, 11:22:04 AM Warning: Skipping grid point X=200.0, Y=60.0 because Z probe cannot reach it
      Warning: Skipping grid point X=200.0, Y=80.0 because Z probe cannot reach it
      2/1/2023, 11:21:22 AM G29
      Warning: Skipping grid point X=200.0, Y=20.0 because Z probe cannot reach it
      Warning: Skipping grid point X=200.0, Y=40.0 because Z probe cannot reach it
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Tue Jan 31 2023 16:20:49 GMT-0800 (Pacific Standard Time)
      M550 P"Ender3" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards
      M92 X80.00 Y80.00 Z400.00 E136.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z300.00 E1500.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X400 Y400 Z400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S300 ; Set idle timeout
      M208 X-5.5 Y-10 Z0 S1 ; set axis minima
      M208 X235 Y235 Z250 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H2.5 F150 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P25 X-48 Y-10 Z0.6 ; set Z probe trigger value, offset and trigger height
      M557 X20:215 Y20:215 S20 ; define mesh grid
      M106 P1 S1 H0 T45 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H0:1 T45 ; set fan 2 value. Thermostatic control is turned on
        Please share your homing files and bed.g as well.
        The offset warning means you may not be homing with the probe or loading a heightmap before homing.
        The skipping point message just means that the probe can't physically reach points on the bed that you've asked it to probe. You can either ignore it, or adjust the M557 so that you're only asking it to probe points it can reach.
        Flynbrdundefined 1 Reply Last reply Reply Quote 1
        • Flynbrdundefined
          Flynbrd @Phaedrux
          @Phaedrux (btw I test and adjusted G31 to Z1.180 trigger height)
          Homeall.G
          G91 ; relative positioning
          G1 H2 Z2.5 F6000 ; lift Z relative to current position
          G1 H1 X-245.5 Y-250 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F6000 ; go back a few mm
          G1 H1 X-245.5 Y-250 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G90 ; absolute positioning
          G1 X68 Y30 F6000 ; go to first bed probe point and home Z
          ;G91 ; relative positioning
          ;G1 Z2.5 F100 ; lift Z relative to current position
          ;G90 ; absolute positioning
          homex.g
          G1 H1 X-245.5 F1800 ; move quickly to X axis endstop and stop there (first pass)
          G1 H2 X5 F6000 ; go back a few mm
          G1 H1 X-245.5 F360 ; move slowly to X axis endstop once more (second pass)
          G1 H2 Z-2.5 F6000 ; lower Z again
          homey.g
          G1 H1 Y-250 F1800 ; move quickly to Y axis endstop and stop there (first pass)
          G1 H2 Y5 F6000 ; go back a few mm
          G1 H1 Y-250 F360 ; move slowly to Y axis endstop once more (second pass)
          homez.g
          G1 X68 Y30 F6000 ; go to first probe point
            Phaedrux Moderator @Flynbrd
            @Flynbrd said in Need Help CRtouch, update. Ender 3 Duet2 wifi:
            At what point do you get that error?
            Can you post your slicer start gcode?
            Can you take a screenshot of your heightmap being displayed?
            Borgtribbleundefined 1 Reply Last reply Reply Quote 0
            • Borgtribbleundefined
              Borgtribble @Phaedrux
              @Phaedrux
              It's at the end of the run. I believe at the around the last probe point it flashes that error. Last time didn't generate a map.
              On the other note, you mention redefining my mesh. Looking at the errors the probe is having issues at 200x. Should I adjust the M557 to
              Old
              New
              M557 X20:180 Y20:215 S20 ; define mesh grid
                Your mesh range should be your axis minima and maxima values added with the G31 X and Y values.
                M208 X-5.5 Y-10
                M208 X235 Y235
                G31 P25 X-48 Y-10
                For X- the probe is on the left side, so it can reach all the way to the X minima. In other words, the probe can reach all the way to the left side of the bed. How far from the edge is up to you. Let's try 10mm.
                M557 X10
                For X+ the probe can only ever reach 48mm away from the right side. So X235 + (-48) = 187. Let's say 180.
                M557 X10:180
                For Y, same thing, it's on the front side of the nozzle and can reach all the way to the Y minima. So Y10
                M557 Y10
                For The Y max, it can only ever reach 10mm away from the edge. So Y235 + (-10) = 225.
                M557 Y10:225
                Putting it all together.
                M557 X10:180 Y10:225 P5
                I used P5 here instead of a S value. P has the firmware choose 5 equally spaced points between the min and max values giving a 5x5 grid.
                S defines an exact spacing, which means you have to find a spacing that maximizes the available size yourself. Easier to just tell it how many points to use.
                Borgtribbleundefined 1 Reply Last reply Reply Quote 2
                  @Phaedrux
                  Thank you, it's up and running. My current mesh
                  With a glass bed
                  Only other issue I'm getting is a,
                  Directory 0:/macros/ not found
                  Not sure why, 😕 and I no macros in that folder. I wonder is somewhere in my configuration it's calling for a macro?
                    Do you have a macros folder in the root of the SD card?
                    Flynbrdundefined 1 Reply Last reply Reply Quote 0
                    • Flynbrdundefined
                      Flynbrd @Phaedrux
                      @Phaedrux
                      No, there was no macros folder so I added one.
