    Idiot's Guide To Upgrading Duet Firmware
    Firmware installation
    5.1k
    • gbartschundefined
      gbartsch @Phaedrux
      @Phaedrux said in Idiot's Guide To Upgrading Duet Firmware:
      While you're in there you can make sure there is a firmware folder as well.
      There is a firmware folder:
      Custom cartesian dinosaur machine; it's a tank but just works so I just keep tweaking it. / Duet Ethernet 1.02 or later / RepRapFirmware for Duet 2 WiFi/Ethernet: 3.4.5 / SuperSlicer
      • gbartschundefined
        gbartsch @Phaedrux
        Download that zip file and extract the contents into the WWW folder on the SD card. You can remove any files that exist there already.
        Is this right?
        • gbartschundefined
          gbartsch @Phaedrux
          Ok it looks like you're successfully running 3.4.5
          How's this?
            I think that's looking ok.
            @gbartsch said in Idiot's Guide To Upgrading Duet Firmware:
            Now you'll need to place the DWC files on the SD card so that the web interface will work. While you're in there you can make sure there is a firmware folder as well. You can place your config files on the SD card in the sys folder too.
            Can I do this over YAT (I have no one to help me at the moment so can't move the MicroSD card back and forth to a PC)? I'm looking for commands to use in YAT.
            Sadly no. Must be done on a PC to copy over the files.
            gbartschundefined 1 Reply Last reply Reply Quote 0
            • gbartschundefined
              gbartsch @Phaedrux
              But this can't be right?
              • gbartschundefined
                gbartsch
                5476ae8f-3c6a-4076-9f98-61bfe08ee517-image.png 😄 😄 😄 😄
                • gbartschundefined
                  gbartsch
                  Now to see what doesn't work .. haha
                  • gbartschundefined
                    gbartsch
                    Thank you so much to everyone who helped me through this upgrade; especially @Phaedrux who spent a disproportionate amount of time on my problems. You guys are awesome!
                    I've learned a lot going through this process and have lost a lot of the trepidation I felt when I used to think of making changes to the firmware. Now I have an up-to-date firmware and future upgrades should be easy.
                    I PID tuned the bed and hotend heaters (that was so easy and the Duet calibration guide is clear and very well done), adjusted the homez.g and homeall.g files a bit to make Z drop a bit after hitting the endstop (I home to the top), and I am making a few tweaks to the fans. There might be more but I did make a nice short print already.
                    Tomorrow I'll try adjusting pressure advance again and start tweaking other settings. And I'll make backups.
                    Thank you all again! I'm so happy to be back printing.
                    tasundefined 1 Reply Last reply Reply Quote 2
                    • tasundefined
                      tas @gbartsch
                      @gbartsch
                      Very pleased your printer is working again.
                      Please let us know how the pressure advance is working in your other topic. Very interested to see if this upgrade fixed your issue.
                      gbartschundefined 1 Reply Last reply Reply Quote 2
                        🤘 Glad you got it all up and going.
                        Now that you're up and running, I would suggest uploading the 3.4.5 zip file once more in DWC. This will make sure you have all the needed files for the next update in place. These files would have been missed when doing the manual upgrade path.
                        Let us know how you get on.
                        gbartschundefined 2 Replies Last reply Reply Quote 1
                        • gbartschundefined
                          gbartsch @tas
                          @tas said in Idiot's Guide To Upgrading Duet Firmware:
                          I will soon; I'm having some success ... 👍
                          • gbartschundefined
                            gbartsch @Phaedrux
                            Thanks! I uploaded that .zip file and everything went up but when I clicked install (I hope I was supposed to) this error appeared:
                            • gbartschundefined
                              gbartsch @Phaedrux
                              😃 I could not have done it without you. Thank you again!!
                              I looked at your profile and funnily enough we're almost neighbors; I live in Alberta. If you ever are in Edmonton stop by and visit.
                              • gbartschundefined
                                gbartsch
                                Aside from making some adjustments to some acceleration and speed change settings I believe everything is working except the part cooling fans won't turn on automatically; I can turn them on manually in DWC.
                                The definitions are as follows:
                                ; Fans. The comments are mixed up I think. They dont match the definitions
                                M950 F0 C"fan1" Q500                                  ; create fan 1 on pin fan1 and set its frequency / this is the hotend fan
                                M106 P0 S0 H1 T45                                     ; set fan 1 value. Thermostatic control is turned on
                                M950 F2 C"fan0" Q500                                  ; create fan 0 on pin fan0 and set its frequency
                                M106 P2 S0 H-1                                        ; set fan 0 value. Thermostatic control is turned off
                                I think something is mixed up.
                                I also think the fans may be wired to wrong pins on the board but wasn't the one who set up the board and can't check on my own.
                                The hotend fan works properly. The two part cooling fans spin as one.
                                  Phaedrux Moderator @gbartsch
                                  Small world. I have two brothers living in Edmonton actually. I don't get down there very often anymore though.
                                    Can you post the full config.g as it is now? Would need to see the tool definition as well. Also ideally know which is connected where.
                                    Are they wired together in parallel to a single header, or one to each?
                                    • gbartschundefined gbartsch referenced this topic
                                    • gbartschundefined
                                      gbartsch @Phaedrux
                                      @Phaedrux I'm thinking they are wired together in parallel. I can't look but my friend who set up the machine might be able to take a look at the wiring in a little over a week. Then I could say for sure.
                                      I played with the fan definitions after looking at the old working definitions and came up with this:
                                      M950 F0 C"fan0" Q500                      ; create fan 0 on pin fan0 and set its frequency
                                      M106 P0 S0 H-1                                  ; set fan 0 value. Thermostatic control is turned off
                                      M950 F1 C"fan1" Q500                       ; create fan 1 on pin fan1 and set its frequency / hotend fan
                                      M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
                                      The fans are working now but DWC looks like this ...
                                      Aren't Tool Fan and Fan 0 different things? 35% is the part cooling speed I set in the slicer. The hotend fan is spinning 100%.
                                      Here's my entire config.g ..
                                      ; Configuration file for Duet WiFi (firmware version 3.3)
                                      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Sun Jan 29 2023 19:52:14 GMT-0700 (Mountain Standard Time)
                                      M575 P1 S1 B57600                                  ; enable support for PanelDue
                                      G90                                                ; send absolute coordinates...
                                      M83                                                ; ...but relative extruder moves
                                      M550 P"Brutus"                                     ; set printer name
                                      M552 P0.0.0.0 S1                                   ; enable network and acquire dynamic address via DHCP
                                      M586 P0 S1                                         ; enable HTTP
                                      M586 P1 S1                                         ; enable FTP
                                      M586 P2 S0                                         ; disable Telnet
                                      M569 P0 S1                                         ; physical drive 0 goes forwards
                                      M569 P1 S1                                         ; physical drive 1 goes forwards
                                      M569 P2 S1                                         ; physical drive 2 goes forwards
                                      M569 P3 S1                                         ; physical drive 3 goes forwards
                                      M584 X0 Y1 Z2 E3                                   ; set drive mapping
                                      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                                      M92 X99.96 Y100.07 Z400.00 E523.52                 ; set steps per mm
                                      M566 X1000.00 Y1000.00 Z24.00 E3000.00             ; set maximum instantaneous speed changes (mm/min)
                                      M203 X30000.00 Y30000.00 Z900.00 E2700.00          ; set maximum speeds (mm/min)
                                      M201 X1000.00 Y1000.00 Z200.00 E3000.00            ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E500 I30          		       ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30                                            ; Set idle timeout
                                      ; Dimensions
                                      M208 X-10 Y0 Z0 S1                                 ; set axis minima
                                      M208 X214 Y214 Z218.315 S0                         ; set axis maxima
                                      M574 X2 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
                                      M574 Y2 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
                                      M574 Z2 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
                                      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
                                      M557 X40:195 Y5:195 S20                            ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092        ; configure sensor 0 as thermistor on pin bedtemp
                                      M950 H0 C"bedheat" T0                                 ; create bed heater output on bedheat and map it to sensor 0
                                      M307 H0 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
                                      M140 H0                                               ; map heated bed to heater 0
                                      M143 H0 S120                                          ; set temperature limit for heater 0 to 120C
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4267         ; configure sensor 1 as thermistor on pin e0temp
                                      M950 H1 C"e0heat" T1                                  ; create nozzle heater output on e0heat and map it to sensor 1
                                      M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                                      M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                                      M950 F1 C"fan1" Q500                       ; create fan 1 on pin fan1 and set its frequency / this is the hotend fan
                                      M563 P0 S"E3D-V6" D0 H1 F0                         ; define tool 0
                                      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
                                      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
                                      ; Custom settings
                                      M912 P0 S1.6                                       ; 2020.06.15 - Calibrate the MCU temp
                                      M501                                               ; load saved parameters from non-volatile memory
                                      T0                                                 ; select first tool
                                      • gbartschundefined
                                        gbartsch @Phaedrux
                                        Small world.
                                        Wow, that's cool. It's surely is a small world.
                                          Nope. The tool fan slider is the same as your part cooling fan of the currently selected tool, so if you had multiple tools, that slider would work for whichever tool was selected.
                                          That sounds correct for your config.
                                          • gbartschundefined
                                            gbartsch @Phaedrux
                                            Awesome! Thank you for checking that. Then this firmware upgrade is a success!
                                            I'm printing now and can see some differences immediately. Infill is now connecting to perimeters; that was a thorny issue I could not solve for a long time but is much better now.
                                            tasundefined 1 Reply Last reply Reply Quote 1
