    Duet mini5+ forgets config after power off >30secs
    Firmware installation
    351
    • Simon 4undefined
      Simon 4
      I have the problem that the board with paneldue 7i forgets my settings when I turn it off for lonnger, short on/off works mostly.
      what I did:
      -generate the firmware with online tool
      -connect duet mini 5+ with usb cable to pc
      -starting terminal programm YAT--> connect-->OK
      -type m552-->ethernet is disabled
      -type m552 S1--->Ethernet is enabled, configured IP address: 0.0.0.0, actual IP address: 0.0.0.0 have to wait some time until dhcp gives me a ip--> getting connected with web browser
      -click system --> then click upload system files --> choosing my downloaded zip file generated with online tool--> system unpacks the the files
      -system asks for installing --> click yes --> system installs and panel due changes the look.
      at this point I am able to do motor movement, pid tuning hotend and buld plate...
      but if i turn off the system for more than 30-60 seconds the system starts up likefor the first time an I have to do the whole prcess again.
      I noticed that the file config.g is missing in the beginning in the web control, after update process I have one.
      The firmware update from 3.4 to 3.45 is still the actual one, this seems to be remembered.
      this is my config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Mon Feb 06 2023 14:47:19 GMT+0100 (Mitteleuropäische Normalzeit)
      M550 P"Simplex 2" ; set printer name
      M669 K1 ; select CoreXY mode
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M84 S30 ; Set idle timeout
      M208 X220 Y190 Z190 S0 ; set axis maxima
      M574 X1 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io6.in
      M574 Y1 S1 P"io5.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io5.in
      M574 Z2 S1 P"io3.in" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io3.in
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:190 S20 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S100 ; set temperature limit for heater 0 to 100C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M143 H1 S270 ; set temperature limit for heater 1 to 270C
      M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
      M106 P0 S1 H1 T45 ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
      M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned off
      • chrishammundefined
        chrishamm administrators @Simon 4
        @Simon-4 Sounds like an issue with the microSD card. Can you format and/or replace it?
        Duet software engineer
        Simon 4undefined 1 Reply Last reply Reply Quote 0
        • Simon 4undefined
          Simon 4 @chrishamm
          @chrishamm
          I had two boards one with wifi and one ethernet. I tried it with both sd cards, but same behaviour.
          But I will do the format procedure as described in your wiki.
            Can you gather an M122 report from it with a known working SD card inserted?
            MJLewundefined 1 Reply Last reply Reply Quote 0
            • MJLewundefined
              MJLew @Phaedrux
              @Phaedrux Could this be related to the bug that blitzed the config.g file on my machine?
                Possibly. Did the config.g file disappear again?
                The M122 report would tell if the SD card is actually being detected properly or not.
                • Simon 4undefined
                  Simon 4 @Phaedrux
                  this was displayed with M122
                  M122
                  RepRapFirmware for Duet 3 Mini 5+ version 3.4.5 (2022-11-30 19:41:16) running on Duet 3 Mini5plus Ethernet (standalone mode)
                  Board ID: H1VW7-XT8LU-F65J0-409NG-JM03Z-70AG8
                  Used output buffers: 1 of 40 (19 max)
                  Static ram: 103652
                  Dynamic ram: 104780 of which 0 recycled
                  Never used RAM 33280, free system stack 192 words
                  Tasks: NETWORK(ready,25.9%,213) ETHERNET(notifyWait,0.1%,560) HEAT(notifyWait,0.0%,358) Move(notifyWait,0.0%,363) CanReceiv(notifyWait,0.0%,942) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(notifyWait,0.6%,115) MAIN(running,72.1%,397) IDLE(ready,0.4%,30) AIN(delaying,0.8%,263), total 100.0%
                  Owned mutexes:
                  Last reset 00:00:36 ago, cause: software
                  Last software reset at 2023-02-13 15:08, reason: User, GCodes spinning, available RAM 33208, slot 0
                  Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU revision 3, ADC conversions started 36522, completed 36520, timed out 0, errs 0
                  Step timer max interval 752
                  MCU temperature: min 30.6, current 31.8, max 31.8
                  Supply voltage: min 23.7, current 23.7, max 23.8, under voltage events: 0, over voltage events: 0, power good: yes
                  Events: 0 queued, 0 completed
                  Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 22, reads 1899, writes 9, timeouts 0, DMA errors 0, CC errors 0
                  Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 22, reads 1898, writes 9, timeouts 0, DMA errors 0, CC errors 0
                  Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 22, reads 1898, writes 9, timeouts 0, DMA errors 0, CC errors 0
                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 1898, writes 9, timeouts 0, DMA errors 0, CC errors 0
                  Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 19, reads 1899, writes 9, timeouts 0, DMA errors 0, CC errors 0
                  Driver 5: not present
                  Driver 6: not present
                  Date/time: 2023-02-13 15:09:30
                  Cache data hit count 61969902
                  Slowest loop: 10.88ms; fastest: 0.13ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 3.4ms, write time 0.0ms, max retries 0
                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  Movement lock held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  SBC is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Aux2 is idle in state(s) 0
                  Code queue is empty
                  === CAN ===
                  Messages queued 328, received 0, lost 0, boc 0
                  Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 18 (min 18), ts 183/0/0
                  Tx timeouts 0,0,182,0,0,144 last cancelled message type 4514 dest 127
                  === Network ===
                  Slowest loop: 20.38ms; fastest: 0.03ms
                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 1 of 8
                  = Ethernet =
                  State: active
                  Error counts: 0 0 0 0 0 0
                  • Simon 4undefined
                    Simon 4 @Simon 4
                    seems to work with the formated and the "hand crafted" sd file
                      Phaedrux Moderator @Simon 4
                      @Simon-4 said in Duet mini5+ forgets config after power off >30secs:
                      SD card media can be fickle. Let us know if you encounter any other issues.
                      • Phaedruxundefined Phaedrux has marked this topic as solved
