    Setting up Eclipse to Develop Firmware
    Firmware developers
    5.8k
    • jmlundefined
      jml
      I really just need to make some small firmware changes and some custom g-code commands.
      I purchased the DuetWifi, PanelDue, and am waiting for the Duex5. Hoping to have it solved by the time it arrives! If I can't get it to work on Mac or Windows, I may just uninstall everything and try again when firmware version 1.2 is out.
      Thanks for all the help you've provided so far!
      • fmaundefined
        fma
        I had no problem installing/compiling under linux. You may try to install a linux system in a Virtualbox env, and compile from there.
        Frédéric
        • jmlundefined
          jml
          Ok, I will try. I'm using a decently powered Mac using Parallels to run windows and I assume I can put Linux on here too. Which Linux OS/distribution do you recommend? Ubuntu? I have limited experience with Linux, but I can learn!
          • jmlundefined
            jml
            So strange though. It seems like the only thing I need to fix is these empty quotation marks and it will fix everything:
            -Wl,–start-group ""
            The file it is looking for is 100% in the right folder. And the command line pattern is exactly how dc42's is.
            • fmaundefined
              fma
              I run debian, but I think ubuntu is fine too (all dev libs exist).
              About the missing path, you can try to replace:
              ${CoreName}
              by
              CoreNG
              or ${workspace_loc:/${CoreName}
              by
              /Users/John/eclipse-workspace/CoreNG
              to see if it fixes the problem.
              Frédéric
              • jmlundefined
                jml
                LOL, I literally just tried it before reading your post AND IT WORKED!!!!!!
                Just in case someone in the future has this problem, this is what I changed:
                ${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "${workspace_loc:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}" ${INPUTS} ${LINK_FLAGS_2}
                changed it to:
                ${COMMAND} ${FLAGS} ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${LINK_FLAGS_1} "/Users/John/eclipse-workspace/CoreNG/SAM4E8E/cores/arduino/syscalls.o" ${INPUTS} ${LINK_FLAGS_2}
                (make sure the quotes are there but the curly brackets and dollar signs removed).
                Thanks everyone!
                • jmlundefined
                  jml
                  I'm so happy
                  • fmaundefined
                    fma
                    Good!
                    But I think I found the issue. The string:
                    should be :
                    "${workspace_loc}:/${CoreName}/SAM4E8E/cores/arduino/syscalls.o}"
                    There where a missing bracket at the end of the workspace_loc var…
                    Can you confirm?
                    Frédéric
                    • jmlundefined
                      jml
                      When I browse around in the settings, the way that all of the Includes are is like this:
                      "${workspace_loc:/${CoreName}/asf/common/utils}"
                      So I don't think that was the issue.
                      • jmlundefined
                        jml
                        Eg. when you write it like this:
                        you have an extra curly bracket because there is one on the far right 2nd last to the end.
                        • fmaundefined
                          fma
                          Mmm, you're right, they are all defined this way… Strange.
                          Frédéric
                          • vschundefined
                            vsch
                            If it is of any help, I was getting the exact same error because I made the mistake of having the projects not under the workspace directory.
                            When I created the workspace in the parent directory of the project sources (CoreNG and RepRapFirmware directories) the error went away as expected. The ${workspace_loc:} is expecting them to be under the workspace directory.
                            However, I am getting undefined reference errors during linking for: lprintf, sqrtf, floorf, etc.
                            I am running under OS X with gcc-arm-none-eabi-6-2017-q2-update tools. Is there a library missing from the linker options that the IDE should include based on dependencies?
                            • vschundefined
                              vsch
                              My problem of unresolved references was solved by resetting .cproject and .settings/language.settings.xml in RepRapFirmware project to repository version and then changing the project properties as per instructions. Subsequent build was successful.
                                @fma:
                                Good!
                                should be :
                                Can you confirm?
                                Recently I was getting this issue intermittently. I think it is an Eclipse bug. So in the latest commit I changed the path to this:
                                "${workspace_loc}/${CoreName}/SAM4E8E/cores/arduino/syscalls.o"
                                This seems to have resolved it.
